the areas in red are about 5 inches wide 19 tall.. I am going to glass it.. what mat, resin etc should i use? how should i attach it to the box
Ca.com
Bought from: Sctattooer, Korn4Life, wgsj_fortvalley, bk12321, Queball, bumpincrv, Splmaster, 310w6, Buck, liljojo4711
Everyone I have Bought from has been awesome.. feel safe with any of them..
Sold To: Iakona, dustinr, squeak12, Worstenemy453, BeAlLsTaR13, rmzsuzuki89, c_b_, mendon mafia, dropped_tb, SPLluminator, violence., power-fanatic07, schackel, michaellane, aviator08, kodak314, dropped_tb
Ref Link
Tamparacing
-b15spec, 727kid, pshull727, Nt_Hardcore
Want/Need ANL fuses cheap 150a 200a 250a 300a CLICK ME
bumpity bump
Ca.com
Ref Link
Tamparacing
plywood, much easier and faster to shape and secure, then foam if you want permanent, weather strip if you dont
plywood is easy to shape??
Ca.com
Ref Link
Tamparacing
Ca.com
Ref Link
Tamparacing
Use plywood to get the general area, then use weather strip to cover the edges to seal it.
how should i connect the plywood on the port side?
Ca.com
Ref Link
Tamparacing
get some poster board to make your templates then use MDF or plywood. Weatherstrip tape on the edges, so it seals. Attach to the box with "L" brackets...
Ca.com
Ref Link
Tamparacing
main reason i wanted to glass was I am not too handy with a saw.. I can sand/drill/dremel w/e.. not so good with a saw..
Ca.com
Ref Link
Tamparacing
You dont need fvckin 3" screws to attach a seal/beauty panel to your box. 3/4" screws would be more than enough, using 2 L shelf brackets per side would be plenty
I used these, there like 50cents to 2 bucks each depending on size
And yeah use plywood or mdf whatever you have kickin, who cares if your no good with a saw, I sure dont get my beauty panels a perfect seal first try everytime, who cares if it takes 10 cuts, just keep making adjustments til you get a tight fit.
Jigsaw would obviously be best, with carbboard template to get the initial shape.
Cheap easy and effective
well if you your dead set on glass i would mae a frame/structure out of dowel rods use like hot glue to put it together and stretch fleece over that and use hotglue to secure it and just add resin.
[/SIGPIC][/SIGPIC]
93 Ford Ranger
full fiberglass panels and a-pillars
XS d6500/ Mechman 260A
2 SA15s
Sundown 1500dv1
Toolmaker plexi, dual inputs, distro blocks.
Bookmarks
