Page 20 of 20 FirstFirst ... 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20
Results 286 to 300 of 300
Reload Thread: Bumpin Buicks NW build
  1. #286
    audioarsonal's Avatar
    audioarsonal is offline JaMarcus
    May 2007
    close to home...
    4,166
    Re: Bumpin Buicks NW build
    Quote Originally Posted by bumpin buick View Post
    Yes
    where it matters
    Bought from:whiteram,Pyro_by_nature,AudioXtremes,Slab,IA2
    Sold to:annarbor84,ssackett,tapout383
    built for:skeptikal,Raid3r89
    SHADY SELLER:memphisman00
    Subs:4 Incriminator Audio Death Row 15's
    amps: Memphis 4K
    154.8@34hz
  2. #287
    GearGuy2001's Avatar
    GearGuy2001 is offline CarAudio.com Veteran
    Apr 2006
    South Beloit, IL
    24
    2,369
    1 Post(s)
    Sounded **** good for being tuned to low 50s
    Cant wait to hear it with the correct ports in
    Team D.O.A.
    Car: 97 Mercury Grand Marquis LS
    Deck: Alpine CDA-9887
    Speaker Amp: American Bass SQ780
    Front Stage: Image Dynamics CTX65CS @ 125w RMS
    Sub Amp: Sundown SAZ-2000D
    Sub Stage: 2 Sundown SA-10s
    Box: 4th Order (2.0 Ported, .8 Sealed)
    Wire: Knu 1/0 Amp Kit and Big Three
    References: http://www.caraudio.com/forum/showthread.php?p=4811364
  3. #288
    bumpin buick's Avatar
    bumpin buick is offline Science is everything
    Jul 2007
    Appleton, Wisconsin
    11,024
    Quote Originally Posted by GearGuy2001 View Post
    going from 55-56hz to 43hz will be a nice change, I cant wait to hear the difference either.
    http://www.caraudio.com/forums/buyer-seller-feedback/305521-official-bumpin-buick-feedback-thread.html
  4. #289
    Jul 2007
    Appleton, Wisconsin
    11,024
    http://www.youtube.com/watch?v=qQyj1iIdzPw
    tunned to 55hz in this vid
  5. #290
    tEh ShOcKeR's Avatar
    tEh ShOcKeR is offline Banned
    Jul 2009
    Gotham City
    989
    Nice.
  6. #291
    Jul 2007
    Appleton, Wisconsin
    11,024
    thanks once the tuning is fixed, alt is on, and D .7 recones are it, it should be even more impressive.
  7. #292
    dtbrown's Avatar
    dtbrown is offline CarAudio.com Elite
    Aug 2006
    morton grove, il
    35
    919
    6" aeros, with about 6" clearance from the box, they are being changed though as my tuning is a bit too high.
    I thought it was four 4" aero. Now it makes sense why you're tuned so high. You have two options. Make ports longer to about 3" off the bottom or plug one port and go to three 6" aeros. Plug one up for now to see how well it works and then later make a new baffle for the three. Four 6" aero is 112 si which is a lot for size of your box. To give you an idea our box is using 71si with the single 10" tuned to 44hz. So with three 6" at 84si of port area would probably be a lot better. I'm sure you already though of this but I just wanted to try and give some suggestions.
    So far loudest Toyota Yaris with two 10's.
    2008
    154.1 certified (new rules) on termlab Db Drag Street A. Equipment: DD 9510's and one Stetsom 7k2d on a small Stinger 1750
    2007
    155.3 on termlab Db Drag Street A 2007 WF 4th place. Equipment: DD 9510's and two Stetsom 7kd's with a Cacuts Sounds CS9000 Battery.
  8. #293
    Jul 2007
    Appleton, Wisconsin
    11,024
    Quote Originally Posted by dtbrown View Post
    I thought it was four 4" aero. Now it makes sense why you're tuned so high. You have two options. Make ports longer to about 3" off the bottom or plug one port and go to three 6" aeros. Plug one up for now to see how well it works and then later make a new baffle for the three. I'm sure you already though of this but I just wanted to try and give some suggestions.
    I appreciate it Jeff. I have thought about it, but unsure of how to make a port plug that would correctly seal it off, I will try that though and see what happens.
    I got slot ports being made tonight along with the front logo, should have it ready for Madison show.
  9. #294
    dtbrown's Avatar
    Aug 2006
    morton grove, il
    35
    919
    A couple ways you can do it. If the port is mounted to mdf you can make a mdf cover plate and as long as it's perfectly flush with the wood it'll seal perfect. Other option that is really easy to do quickly to see if it sounds better/louder by ear is just roll up and stuff a towel in it very tightly. You'll know right away by ear if it helped or not. And don't give up on the aeroports. They just need to be tuned. Good luck with weekend.
    2008
    2007
  10. #295
    Jul 2007
    Appleton, Wisconsin
    11,024
    Thanks, I always appreciate the help, due to short time and little equipment I will try the towel trick. Its worth a shot at least. I measured what I will need to to do for my aeros to get them to the right tuning roughly. Right now they are only like 10" total, I need them to be about 14" which only leaves about 3.25" from the bottom of the box though, which is what worries me. So we shall see, hope to see you at Madison or Oshkosh
  11. #296
    Millertime1028's Avatar
    Millertime1028 is offline CarAudio.com Veteran
    Jan 2008
    Long Island, New York
    2,770
    1 Post(s)
    I'm liking this build alot. Looking nice man.
    References : lostdaytomorro ,wu501(x3), rednas, gladiator_jai , duece212, Kumquatism, dub22, kovemaster559, mpt947, kramers04 , Phlipbak, Bassbumper15, 1mtx1(x2), kylecanthurdle, DDbump, 88irocZ , Litunerkid, teen, cvjp417, micheallane, jonny101abc, SlappnCentury, brucebruce1546, audioqueboy
  12. #297
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    9,586
    12 Post(s)
    Nerf football or rubber playground ball should make a nice port plug...
  13. #298
    Jul 2007
    Appleton, Wisconsin
    11,024
    Quote Originally Posted by Millertime1028 View Post
    Thanks I am enjoying it too, its all up and running, just go to update/upgrade a few things and it will be here to stay I am super happy with the box, even with the high tunning though I love the thing.
    Quote Originally Posted by mlstrass View Post
    hmmm, ill have to dig around in the garage for a nerf football, thanks never would have though of that lol. You guys have fun at Zion tommorow, rep for me cause I cant be there
  14. #299
    Jul 2007
    Appleton, Wisconsin
    11,024
    realized the link was bad heres the new one http://www.youtube.com/watch?v=453gipbqKag
  15. #300
    Annnarbor84's Avatar
    Annnarbor84 is offline Banned
    Nov 2008
    Live with your girl!!!
    31
    8,636
    Looks loud
