Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 31 to 45 of 66
Reload Thread: 1st timer DIY Fiberglass Kick Panels
  1. #31
    Jared530's Avatar
    Jared530 is offline Drop bombs
    May 2006
    Sacramento, Ca
    2,259
    Re: 1st timer DIY Fiberglass Kick Panels
    Ok so i got back from studying and layed a few layers of glass down. The f-ed up one doesn't look bad at all. One thing i learned when laying glass is that when its all down, go over it and tap out the bubbles and mat the stray hairs down it will save a ton of time in the long run.
    Ill post pics once photobucket is up
    OH and I put them in my car just to check fit and it looks too good
    Refs: Kevokrook77, Cheapo, Killahbean, Coolwazabi, ShinyChromes(SCAMMER), Jnoel, matrxx dude, ssackett, Josh #44(SCAMMER), tc3k101, matrxx dude
  2. #32
    here to buy's Avatar
    here to buy is offline Crescendo
    Dec 2008
    Florida
    1,277
    use
    NYLON/SPANDEX BLEND
    no wrinkles and overlaps just stretch and takes 3 minutes to wrap that size pod
  3. #33
    Jared530's Avatar
    May 2006
    Sacramento, Ca
    2,259
    Quote Originally Posted by here to buy View Post
    use
    NYLON/SPANDEX BLEND
    no wrinkles and overlaps and takes 3 minutes to wrap that size pod
    I did on one. The other i used a tshirt cause the fit was giving me probs
  4. #34
    Jared530's Avatar
    May 2006
    Sacramento, Ca
    2,259
    wow edit that to fuckin 100x
  5. #35
    Jared530's Avatar
    May 2006
    Sacramento, Ca
    2,259
    should i stuff my pods?
  6. #36
    Dec 2008
    Florida
    1,277
    Quote Originally Posted by Jared530 View Post
    no you wont notice a diff, we tried doing that.
    if you want though, after you are done, if your pods resonate within certain frequencies, etc., which they will probably, most do, you can lower the resonance by layering the inside of the pod with modeling clay here and there. or applying some deadener to the inside walls.
  7. #37
    kingadaparknlot's Avatar
    kingadaparknlot is offline reekin havoc near you
    Aug 2009
    Nawfside, Triple D Tx
    34
    41
    I have a '04 dodge stratus coupe and currently run 2 cvr 12's in a 4.5 cuft enslosure. I sold my hifonics 1200 and picked up a helluva deal on a MMATS 3000.05, now I am wondering what 2 12" subs or 1 bad *** 15" sub I can run to maximize the power of the amp without starting a financial depression for myself?
  8. #38
    Blue Fury's Avatar
    Blue Fury is offline Quagmire's Chin
    Aug 2008
    Fresno Area, Ca
    2,312
    good job so far but you had me scared when you covered just about the entire floor
    ***My build: 2 SSA Xcons, Sundown, Vifa, TB, Hertz, 880prs, etc.***
    http://www.caraudio.com/forum/showthread.php?t=359675
    CA Refs: bought from: Jacka, bones22, civicman07, Zeuslicious, 90accordman, DesertDawg(<---EXCELLENT seller)
    Sold to: 97accordalpine, Jgyolai, brenTgrillzem, nicksredline, lantz, bagged97tacoma, Plottin4success, microhaxo
    ROE Refs: Bought from delvryboy, jnralp00, dcmcki, Mxman38, Excessive Amperage, GoinDef154, blackdragonx118, Assman.
    Currently For sale: Everything
  9. #39
    tylork92's Avatar
    tylork92 is offline CarAudio.com Veteran
    Nov 2008
    North Carolina
    2,304
    1 Post(s)
    they look nice man....and i used fleece to wrap my tweeter pods and door pods and didnt have ne problems stretching it..i just started from the mdf ring, then stretched teh corners out as tight as they would go then bit by bit stretched the sides....are you gonna wrap the final pod in something or paint them?
    [/SIGPIC][/SIGPIC]
    93 Ford Ranger
    full fiberglass panels and a-pillars
    XS d6500/ Mechman 260A
    2 SA15s
    Sundown 1500dv1
    Toolmaker plexi, dual inputs, distro blocks.
  10. #40
    Jared530's Avatar
    May 2006
    Sacramento, Ca
    2,259
    wet:
    dry:
    Im going to bondo to kinda smooth everything out and be uniform. Then im going to stretch vinyl over it so it matched the interior of my car. I have spray painted pods/boxes, they look way to glossy
  11. #41
    ramos's Avatar
    Dec 2001
    Virginia
    48
    10,311
    5 Post(s)
    Not bad my man, not bad at all. You will probably need to ease some of those curves you have to vinyl them though. Vinyl on curvy arse kicks isn't fun lol
    5 % equipment
    90 % install
    5% beer
  12. #42
    audioarsonal's Avatar
    audioarsonal is offline JaMarcus
    May 2007
    close to home...
    4,166
    GL with the viynal.
    Bought from:whiteram,Pyro_by_nature,AudioXtremes,Slab,IA2
    Sold to:annarbor84,ssackett,tapout383
    built for:skeptikal,Raid3r89
    SHADY SELLER:memphisman00
    Subs:4 Incriminator Audio Death Row 15's
    amps: Memphis 4K
    154.8@34hz
  13. #43
    snb778's Avatar
    snb778 is offline blaugh!!!!
    Oct 2004
    ex. Los Angeles, CA
    29
    8,030
    bet your grad you tried this yourself instead of paying someone 200+ to do em for you, which I bet you were contemplating just doing.
    Refs: Projectpat, XylerB, decipha, blados, protonman, Wlmrs, Nucleareskimo, gl0ck, mobeious, JBizzle (picked up box) mlstrass (box design) Mazzasec (bought 18" RD Alpha from him) SKMFKR: Traded subs Wrenchguy: Sold 18" Q to him. psychoacoustics: bought some bullet horn tweets from him Shinju: bought some 0awg wire from him. Sold a box and 18" HDC318 to chitown_impala. Bought my 2 custom 15's from 99Vic on steave meade forum. NJTStang11- picked up 18" SSX and box from him krispy cream SCAMMED ME $200!!!
    2 Pistol Shrimps in a 4.0 cu^ft box tuned to 32 hz for the WIN !!
    "You can't compare, don't stare, cause I got the ultimate Mary Jane"
  14. #44
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    9,602
    13 Post(s)
    textured satin paint would hide a lot of imperfections and not be shiny. I use that for sail panels when I glass in tweeters. Saves a lot of time on the finish sanding as it doesn't have to be perfect...
  15. #45
    DB-Audio's Avatar
    DB-Audio is offline Syko DJ music producer
    Mar 2009
    Newtown, CT
    2,526
    1 Post(s)
    looks good so far
    2001 Honda Civic EX
    power acoustik 8" over sized touch screen
    doors Stock
    1- Atmos Audio 18
    1- Audiopipe 1000d mini @2 ohms
    Electrical stock for now
    http://www.youtube.com/watch?v=Cl_ardHXEkg"]My old System
    http://www.myspace.com/sykodjthereal"]If you Need Beats click this
    http://www.carstereoforum.net"]http://www.carstereoforum.net
