Re: FInally getting around to showing a build (PICS)
Originally Posted by
its_bacon12
I would also use different screws and bolts when fastening the Atomic amp so nobody can get it out easy if someone decides to break in.
good call. Only thing is, the way the mounting feet are you only need to remove 2 screws and the other 2 the amp will just slide out from
Its only screwed into the fiber board its mounted on. the screws dont go all the way into the metal.
there is really no good way to mount it unless i drill through the fiber board and deck and bolt it through but that will be a pain. Probably what in going to do though eventually.
refs: ebaker, its_bacon12, jando86, thedukey42 , WrenchGuy, jaredspl, teenapp, MisterGrubbs, BushJ311, fozzy2134
System: Poineer 590ib headunit (soon upgrading to 790bt)
2 12" RD Alpha V.3's (soon upgrading to konaki 9512 hybrids) powered by 2 Atomic 3000.1d's
Polk mm6 front components powered by a Soundmagus CP-91 @ 4ohm bridged. JBL/Infinity Hybrid rear components. hu power
200 amp alt and 2 stinger spv 70's (more pending voltage drop)
Current output: 144.9 db using new 09 alpha v3's - on music with 1 3k - song: haters everywhere-two five, Chrysler 300M.
Bookmarks
