Page 5 of 5 FirstFirst 1 2 3 4 5
Results 61 to 69 of 69
Reload Thread: My Lancer OZ build Log ess queue
  1. #61
    captainobvious!'s Avatar
    captainobvious! is offline Senior VIP Member
    Feb 2003
    Philadelphia
    255
    27 Post(s)
    Re: My Lancer OZ build Log ess queue
    Here are some updates.
    I definitely needed to do some more work. Leaving them like that would have really bugged me. Also keep in mind that they will still be shot with the thicker textured SEM after these panels get to the point that I'm satisfied enough with them. I did some more work this afternoon since I had a good 4-5 hours of time to attack them. Heres some more updated pics:
    Spot filled to get those trouble areas...
    After sanding and a wipe down. I also sanded down the scuffed up areas on the panel that you could see highlighted above.
    In the photo below, I highlighted some of the unusual looking spots in the photo above. The two spots in the top right are actually very smooth. The one on the right is a bit shiny because of he paint, making it stand out. The one on the left just didnt get hit with a good coat of paint so some of the filler color still shows through which is why its visible. The section in the lower part of the panel is going to be tough to make much better as the panel in stock form actually has a raised section there. Im hoping it will look better once I get some texture on there. The little dark spots are spray paint 'spatter' where the can wasnt cooperating. A little light wet sand will cure that.Thoughts?
  2. #62
    Fuknmovin's Avatar
    Fuknmovin is offline CarAudio.com Elite
    Nov 2008
    Palm Desert, CA
    591
    7 Post(s)
    You might be better off sanding the whole panel where its not taped off so it all looks the same, then apply your texture paint in a few good solid coats so its nice and even, just a thought....Looks real good though! I am getting ready to tackle my pods sson for some three way Hertz comps and I hope it turns out as good as yours is!
    A 10 that thinks it's a 15!
    I build and design boxes! PM me for details..
    bballstarx124x Quote: Got it running today. Sounds amazing! I'm getting a lil windshield flex on only 500 watts!
    Refs: MTX9515, [email protected], MSW Danny, 95Prober
    http://www.caraudio.com/forum/showthread.php?t=395576"]http://www.caraudio.com/forum/showthread.php?t=395576
    http://www.caraudio.com/forum/showthread.php?t=394806"]http://www.caraudio.com/forum/showthread.php?t=394806
  3. #63
    Feb 2003
    Philadelphia
    255
    27 Post(s)
    Yeah someone had mentioned to me that it might be worthwhile to spray the entire panel with a high build primer and sand down the entire door. I may just end up doing that to ensure a consistent finish. Thanks.
  4. #64
    BlackMaxima's Avatar
    BlackMaxima is offline CarAudio.com Elite
    Jul 2006
    LA
    852
    nice work
    these sls 8 look good, they are big woofers
    References: ME,
    Quote Originally Posted by CRAZYCORNUTS18 View Post
    the JL 500/1 is good and JL actually puts out like 185% so that would be good
    Quote Originally Posted by Buffalohed View Post
    My mom is the ultimate SPL woofer.
    Cheapest too.
    Quote Originally Posted by dpom View Post
    i was wondering if this site was legit, im not sure if im allowed to post it or not so let me know if i can.
    (www.caraudio.com)
  5. #65
    jerseyboy's Avatar
    jerseyboy is offline Team DC
    Dec 2008
    newark,nj
    2,029
    50 Post(s)
    this is some good ish right here.. very informative stuff with a lot od detaild pictures.. good work my man..
    head Unit- JVC double din dvd w/ipod & detachable face plate
    front stage- 4 8" silverflutes and 2 crescendo ft1 super tweeters
    front stage amp- 2 soundstream 900.4
    Subs- 2- 12" XL M2 w/CF caps @31hz
    Sub's Amp- DC 5k (.6 ohm)
    Wires- All Shok Power and ground wires & Knu RCA's
    Electrical- DC Power 275ah alt, xs d3400 (front) & xp 2500's (x3) (rear)
    "my feed back thread"
    http://www.caraudio.com/forums/buyer-seller-feedback/407753-jerseyboy-feedback.html
  6. #66
    xseveredveganx's Avatar
    xseveredveganx is offline CarAudio.com Elite
    Aug 2007
    Utah
    547
    Quote Originally Posted by jerseyboy View Post
    I was just going to post this in your thread on the other forum!!!
    This is definitely a nice build! When I first saw how you were building the door pods, I hoped someone would get you in the right direction on how to get it done! And it looks like it! A bit more work and it'll look awesome!
    I'd definitely scuff up the plastic a bit and hit it with primer, then the SEMS texture, then the dye. IMO that would work better. Unless of course the texture doesn't require primer!
  7. #67
    memphisguy87's Avatar
    memphisguy87 is offline CarAudio.com Elite
    Aug 2008
    Kinston, NC
    747
    Nice build man, can't wait to see more pics.
  8. #68
    DB-Audio's Avatar
    DB-Audio is offline Syko DJ music producer
    Mar 2009
    Newtown, CT
    2,654
    96 Post(s)
    doors look good what are you throwing in there sorry if i missed it
    2001 Honda Civic EX
    power acoustik 8" over sized touch screen
    doors Stock
    1- Atmos Audio 18
    1- Audiopipe 1000d mini @2 ohms
    Electrical stock for now
    http://www.youtube.com/watch?v=Cl_ardHXEkg"]My old System
    http://www.myspace.com/sykodjthereal"]If you Need Beats click this
    http://www.carstereoforum.net"]http://www.carstereoforum.net
  9. #69
    Xprime4's Avatar
    Xprime4 is offline ****in' canadian
    Jul 2008
    Quebec, Canada
    32
    2,728
    It looks awesome. i wish i had fiberglassing skill
