Page 6 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 76 to 90 of 101
Reload Thread: 6th Order bandpass for DD1508
  1. #76
    westman995's Avatar
    westman995 is offline CarAudio.com Elite
    Apr 2008
    Minnesota
    900
    7 Post(s)
    Re: 6th Order bandpass for DD1508
    Sweet box. So the 6th order is basically an spl box? If so, i wouldnt mind building one of those myself. How much harder would it be to do two 1508s in a 6th order?
  2. #77
    iamamp3pimp's Avatar
    iamamp3pimp is offline Bass Heads Entertainment
    Nov 2003
    Tampa FL
    36
    13,103
    21 Post(s)
    Quote Originally Posted by DNick454 View Post
    By the way, might be the wrong place to ask about this, it should probably be a thread in it self, but how does a 6th order work exactly? I mean, I understand the basic principle, it's like a 4th order, except two ported instead of 1 sealed, so you get two different ported enclosures basically making the pass band range of the box wider with less of a one note wonder peak. My question is... wouldn't the box sound like two subwoofers working out of phase? When the sub moves one direction, one port inhales while the other exhales, the sub moves the other direction and it repeats just backwards and vice versa. Wouldn't this just sound like alot of rushing air with no actual sound pressure being created? Where is 80 to explain?
    if that were true then all ported boxes would be playing out of phase because as the subs move out the port "inhales"
    depending on the freq at times the port is perectly in phase with the sub, and thats generally right at or just above tuning.
    means nothing for this setup....just droppping some theoritical knowledge even though im too tired to spell it correctly
    www.BassHeadsENT.net for all your custom enclosure needs
    Offering build service and expertise in the Tampa area as well as enclosures shipped nationwide!
    [email protected]
    Check this thread for all the build logs being posted.
    http://www.caraudio.com/forums/suppo...ks-thread.html
  3. #78
    Flipx99's Avatar
    Flipx99 is offline Violator of Terms
    Aug 2005
    Building 100
    24,132
    390 Post(s)
    Quote Originally Posted by westman995 View Post
    Not harder, just a bigger box. I think this was was 3.xx net, so you are looking at ~7net
    Black cat, white cat...all that matters is that it catches mice. -Deng Xiaoing
    I do homework for money. I specialize in finance. PM me for estimates.
    If someone uses me as a reference, please contact me first.
  4. #79
    westman995's Avatar
    Apr 2008
    Minnesota
    900
    7 Post(s)
    Quote Originally Posted by Flipx99 View Post
    Dam.n, thats alot of space for two 8s. I dont even have close to the room for that, but im looking at getting another car.
  5. #80
    Nov 2003
    Tampa FL
    36
    13,103
    21 Post(s)
    you dont hAVE to use all that area.....
    you can get away with much much less....80 just used this area because it was avail im sure...
    [email protected]
  6. #81
    westman995's Avatar
    Apr 2008
    Minnesota
    900
    7 Post(s)
    Either way its impossible to put a 6th order in my trans am im pretty sure, very limited space. If i get another car i will look into doing this.
  7. #82
    bones22's Avatar
    bones22 is offline CarAudio.com Veteran
    Mar 2007
    in my house
    8,193
    you can make it happen. would be harder but its not impossible
  8. #83
    westman995's Avatar
    Apr 2008
    Minnesota
    900
    7 Post(s)
    Well i suppose i could, but not without taking out the view through the back window i am guessing?
  9. #84
    WOT's Avatar
    WOT
    WOT is offline Banned
    Nov 2007
    Toronto,CANADA
    3,667
    Who gives a **** about seeing about the rear view??
    PFFF, I havent had a rear view in 3 years, no troubles
  10. #85
    80INCHES's Avatar
    80INCHES is offline EPICENTERGLUED 2 ME
    Jan 2005
    WESTCHESTER, NY
    37
    6,962
    5 Post(s)
    u can do a 4th order in a trans am..6th order for 1 8 yea it can be done
    80
  11. #86
    westman995's Avatar
    Apr 2008
    Minnesota
    900
    7 Post(s)
    Quote Originally Posted by WOT View Post
    Cool story bro.
    Quote Originally Posted by 80INCHES View Post
    80
    How about for two, think it would be hard? And would it get loud as *** in a hatch like that? Or would there not be much benefit over a regular slot ported box? Id really like to use both of them i already have. I dont really want to take up the rear view tho. If i was gona do that i would get some bigger subs.
  12. #87
    Nov 2003
    Tampa FL
    36
    13,103
    21 Post(s)
    not enough room in there for a pair.
    [email protected]
  13. #88
    RKPsk8er's Avatar
    RKPsk8er is offline CarAudio.com Elite
    May 2008
    ATL
    911
    3 Post(s)
    seems like a box like this would be easier to build using aero's
    Refs: damonhargroves, mazzasec, na rsx, mistergrubbs, mike465, astrolade, rival904
  14. #89
    Canaan's Avatar
    Canaan is offline Beatin' the block down
    Mar 2006
    Monroe, Louisiana
    1,511
    83 Post(s)
    Quote Originally Posted by RKPsk8er View Post
    Not in many cases.
    It is often easier to design a normal slot-vented box when dealing w/ 4th and 6th orders. The ports can act as walls in the box and separate the chambers or allow for proper box volume.
    Here is a series tuned 6th order I designed and built for 2 DD1508's last week:
    Canaan White...'04 Avalanche
    HU Eclipse 7200MkII
    AMPS DD C4a(front active), 2 DD M2B
    SPEAKERS (Front) DD AT28, DD VO-M65
    SUBS...SOMETHING LOUD SOON!!?
    WIRES XSCORPION
    TEAM SOUTH
    Desiard Street Pawn and Car Audio, Monroe, La...XScorpion and DD Audio Dealer.
    Shop Phone 318-343-8283
  15. #90
    DNick454's Avatar
    DNick454 is offline Honda + Subs = Rattles :(
    Sep 2008
    Valparaiso, IN
    1,235
    That's interesting to say the least. I'm a tad bit confused as to how it's a 6th order though. I usually picture 6th orders as a sub firing into two chambers, each with a port. This looks more like an 8th order? The one chamber's port actually fires into another ported chamber, that's an 8th order right?
    ----My Two 10's Flexin' ----
    http://www.youtube.com/watch?v=hLrj5PmrKVM
    Quote Originally Posted by mossberg385t View Post
    im calling goob greedy because the ad revenue was suppost to go to site maintenance and upkeep, i havent seen anything but a slow *** server, a virus, self centered mods, and excuses to be expected from steve meade. I just hope the money is going to a good cause such as a heroin addiction
    I design and build boxes.
    References
    http://www.caraudio.com/forum/showthread.php?t=404022
