Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
Reload Thread: aq hdc3 10 sub box 1.44 @ 38hz L Port
  1. #16
    rumblebee2's Avatar
    rumblebee2 is offline I'm Higher Than You
    Apr 2007
    Florida
    1,256
    Re: aq hdc3 10 sub box 1.44 @ 38hz L Port
    Quote Originally Posted by mlstrass View Post
    x2 on taking the extra few minutes to tape off the top/bottom, so you're not gluing over paint. Glue is now bonded to the paint and not the wood and has little strength.
    Also it looks like you did 16^2 per cube of port area, so you're tuned around 33Hz with that port length...
    Steve should be happy as I heard his box didn't turn out so good.
    where did he say his port length? still a very nice box.
    refs:blkmrideon22s,skrilla22,eatank,ampjunkielikem e,werd,snoopysnooper,team3d, 350zspl, finkster
    Feedback Thread:
    http://www.caraudio.com/forum/showthread.php?t=383386
    '05 Reg. Cab 1500
    H.U.- pioneer deh-6800mp
    Sub Amp- saz-1500d
    Sub- tc3k 12" Quad 1.4ohm
    Front Stage- pioneer garbage
    Front Amp-
    Wires- Knu Flex 1/0
    Rca's- Knu Krystal
    Fuse holder- kicker
  2. #17
    GearGuy2001's Avatar
    GearGuy2001 is offline CarAudio.com Veteran
    Apr 2006
    South Beloit, IL
    29
    2,395
    1 Post(s)
    Quote Originally Posted by rumblebee2 View Post
    Port Length is 22" if I recall correctly
    Port is 2" wide
    Since Im not an amazing box designer, atleast not yet, I used RE Audio's L Port Calculator to figure out the dimensions. Thats where I got the 1.44 @ 38hz, The double baffle took away a bit from the cubes but not much.
    Also It held up good to the hdc3 10 @ 2kw and if it does blow apart from the paint Id fix it for free.
    Team D.O.A.
    2009 BMW 335xi
    System to come?
    References: http://www.caraudio.com/forum/showthread.php?p=4811364
