Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 46 to 60 of 63
Reload Thread: My build log: Acura Legend Coupe
  1. #46
    Apr 2008
    lolz
    472
    Re: My build log: Acura Legend Coupe
    That's a really cool idea.. I might try that
    Headunit: Alpine CDE 9874
    Front Stage: PG RSD5.25
    Front Amp: PG Ryval V1502
  2. #47
    Silver-N-Black's Avatar
    Silver-N-Black is online now CarAudio.com Elite
    Aug 2007
    SoCal
    930
    24 Post(s)
    Looking really good can wait too see more pix.
    Bought From : CrazedCat, motley, the727kid, JJones, TheLow, adas, Goindeaf, Reflecting,93dakota
  3. #48
    momuzykent's Avatar
    momuzykent is offline Xclusive
    Nov 2006
    Cashville Tenn-a-key
    101
    Ok here is a little more progress and by the way thanks for all the comments on my build so far. Well not any room to display x-overs and I wanted to get them out of the way I'm going to mount them on a board that will sit under the sub box:
    Next was going to keep it simple on this build but couldnt (not my style)..lol so I decided to mount my x-over, eq & epicenter(whenever I find it, I've put it somewhere so I would know where it was...lol). The equipment will sit on a piece of plexi I frosted to spread the neon light which will be under it:
    clear plexi:
    frosted plexl:
    I love this because the equipment is thin enough that I can still have my spare tire and jack sit underneath it with no problem (I didnt even have to raise the height of the floor)! Next I started working on false floor. I used 2 sheets 1/4in mdf glue together and mounted plexi from the back:
  4. #49
    momuzykent's Avatar
    Nov 2006
    101
    Then started working on beauty panel. This was my first panel flush with sides of the trunk and I have to say it took me forever to get it just right. 3 wasted sheets of 1/2 mdf I finally got it right. I had to use a router so that it would sit flush against the box since I used hex bolts on the box. Making the beauty panel was harder than making the box...
    Ok next since all the wood is finally cut, I can start wiring this thing up finally and once its playing, then Ill go back and start upholestering everything.
  5. #50
    528hz's Avatar
    528hz is offline Everything'sMiscellaneous
    Oct 2007
    In the Space between Space in NM
    4,329
    That looks sick, man! I really wish I would have done a blowthrough.
    Can't wait to see some vids from it!
  6. #51
    KyngHype's Avatar
    KyngHype is offline Bass head to SQ convert
    Jan 2009
    Las Vegas
    790
    coming along great! I'm getting some ideas from you...
    Denon ~ Butler ~ DLS
    This forum is making me racist.
    Quote Originally Posted by caps View Post
    you mean my EX? the one I dumped? just remember every time you kiss her that i used to *** in her mouth
    and BTW your girl just called me
    and im done dumping on this guys thread
    He wins
    I'm looking for McIntosh amps- PM me
    Refs: 1indatrunk, Kast2L
  7. #52
    80INCHES's Avatar
    80INCHES is offline EPICENTERGLUED 2 ME
    Jan 2005
    WESTCHESTER, NY
    32
    6,963
    aww man this is looking really really good
    80
  8. #53
    CJL's Avatar
    CJL
    CJL is offline CarAudio.com Veteran
    Mar 2006
    oZone
    3,790
    How did I miss this?
    We NEED more update and vids!
    Sick setup.
    REFS:
    eatank,mikescanlon,BoominBeast,Pistonsfan70,90accordman,bizflawless,Mazdakid,Boyle465,LiquidClen,dman4486,
    KickerSoItBump, SPY,1000101,infamous_e46
    Bought-Sold-Traded
  9. #54
    CobraStang98's Avatar
    CobraStang98 is offline 450whp+ and 150dbs+
    Feb 2009
    New England
    1,653
    Very nice build here, completely forgot about this one. Always been a huge fan of the Legend Coupe, wish i could find one w/ relatively low miles for a daily driver.
    **2005 GMC Yukon Denali XL Supercharged + Brembos**
    -- (4) 12" MMats Juggs
    -- Atomic 7000.1
    -- (2) Irraggi 300 amp Alts -- (4) Kinetik 2400s
    -- 152.9 @ 39hz --150.1 bassrace
    **2003 VW Jetta 1.8t w/ mods**
    --(2) 12" DC LVL4xl
    -- AQ 3500D @ 1ohm (soon to be 2)
    --149.3 @ 44hz 146.3 bassrace
    Quote Originally Posted by 169db View Post
    if you want that thunder in your trunk or to sound like you just kidnapped king kong and stuffed him in the trunk. All my windows are tinted with shatter prof plexy coated for that support ( trust you will need them) ive shatterd many resturant windows and set off alarms in side homes.
  10. #55
    momuzykent's Avatar
    Nov 2006
    101
    OK a few more updated pieces (I'm moving very slowly but :giggle::giggle. After putting the beauty panel in trunk I felt there was to much dead space from top to bottom so I cut out antoher opening that will house some type of plexi and engraving.
    They were upholstered in black suede in coming pics. Next painted bottom of eq/x-over rack where the fosted plex and led's will go. Also carpeted the floor piece & added plexiglass window as well.
  11. #56
    momuzykent's Avatar
    Nov 2006
    101
    My trunk was originally factory grey so I brought some SEM dye to change to black to match the interior of my car. Also added black suede to beauty panels as well.
    Next, waiting on plexi to be finished, screw beauty panel in & make some minor adjustments so all pockets will fit back in trunk and the trunk will finally be done.
  12. #57
    bigbangtheory's Avatar
    bigbangtheory is offline CarAudio.com Veteran
    Sep 2005
    Venus or Mars, just depends.
    36
    27,272
    Awesome craftsmanship on this.
    Very nicely done sir.
    Refs~Max Power(ST), bnevets27(ST), 99oldsintrigue(ST), matrxx dude(BF), Ficaraudio(BF), Zachzchw(BF), tigerf117(ST), 5.7TBI(BF), DBfan187(ST), Joesph M(ST), 97gp(ST), Cornbreadxd(ST), SlappinX(ST), nycspudz03(ST), bl0ckd(BF), Sctattooer(ST), hitman34608(ST), Wackdogg(ST), ggk(ST), 03F150MrSBF(STx2), Dye4metal(ST), Mikey7182(BF), Wu501(BF), Twisted_0912(BF), Crunklech(BF), psychoacoustics(BF), Tyler Chavez(ST), GTO Dave(ST), Thisistiny(ST), DarkScorpin(BF), davidtemple(BF), BassaddictJ(BF), Geoff_off_me(BF), Dragnix(BF)
    BF=Bought from
    ST=Sold too
  13. #58
    91Chevy's Avatar
    91Chevy is offline Resident Metalhead
    Oct 2008
    Vernon, BC
    675
    Looks awesome, well done.
    1991 Chevrolet S10 Tahoe | Extended cab | 4.3L (262ci) V6
    Head Unit: Pioneer DEH-P5100UB
    Wiring: Knu Konceptz Kolossus Fleks 4AWG
    Amplifier: Sundown SAX-100.4 - Shipping as we speak
    Components: Image Dynamics CXS62 V.2 - Shipping as we speak
    Subwoofers: Still need to be ordered
  14. #59
    80INCHES's Avatar
    Jan 2005
    WESTCHESTER, NY
    32
    6,963
    did u play it yet...im dying to know how it sounds
    remember the first song u should play is jamie foxx -overdose ...kuz it has a nice range of bass
    80
  15. #60
    iamamp3pimp's Avatar
    iamamp3pimp is offline Bass Heads Entertainment
    Nov 2003
    Tampa FL
    31
    13,134
    8 Post(s)
    that looks effin ridiculous bro, i love it.
    www.BassHeadsENT.net for all your custom enclosure needs
    Offering build service and expertise in the Tampa area as well as enclosures shipped nationwide!
    Robin@BassHeadsENT.net
    Check this thread for all the build logs being posted.
    http://www.caraudio.com/forums/suppo...ks-thread.html
