Results 1 to 13 of 13
Reload Thread: 99 Silverado Install_Need More Bass
    Omega3dog's Avatar
    Omega3dog is offline Que-rious
    Sep 2007
    Washington D.C
    62
    Let me know what you think of my 1st install.
    For starters, my Kicker 10L5 finally died after 6 years. Therefore, I needed to replace my sub stage with as much bass as possible, without altering the functionality and utility of my 1999 Silverado Ext Cab.
    I did not realized how large this task would become. My desire encountered multiple challenges, such as electrical, which sub brand, what size, ported vs sealed enclosure, SQ vs SPL, cost; all affected by space limitations.
    The install included:
    Eclipse 8v Head Unit - Re-used from my previous install
    Boston Acoustics 620 (6.5")_Front - Re-used from my previous install
    Boston Acoustics FX7 (4x6)_Rear - Re-used from my previous install
    Kicker KX600.4 - Re-used from my previous install
    Kicker SX1250 - Purchased on ebay
    Fi 12Q D2- Purchased on ebay
    DD3510 D2 - Purchased on ebay
    Xstatic Powerpack - Purchased on ebay
    Dynamat - Purchased on ebay
    1/0 AWG power/ground wire
    4AWG amp power wire
    3 Fuse holders
    2 Distibution boxes
    Tylonal
    Bunch of other stuff...
    Now, here are the pics...
    It took an entire day and tylonal to install 4 boxes of dynamat to the entire cabin. No vibrations or rattles at all. However, if you are looking for a quiet ride in a truck, consider covering up the vents behind the seat. I chose not to cover the vents. The ride is not as quiet as I wanted, but at least it does not sound like a bucket of bolts.
    I chose the Xstatic Powerpack (option 1)
    Omega3dog's Avatar
    Sep 2007
    Washington D.C
    62
    Re: 99 Silverado Install_Need More Bass
    Beneath the rear seat after installing the other equipment.
    Keep in mind, I did my own calculations and built the enclosures myself. My only disappointment is this...the vent calculator on the carstereo/help website http://www.carstereo.com/help/Articles.cfm?id=31 is not so accurate when calculating vent length. For example, tuning a 1.5^3 enclosure to 35HZ using a vertical slot vent 4"w x 9"h, the calculated length is ~46". If the same vent is turned horizontal, the calculated length is 43"; resulting in a 3" varience for identical port areas. If someone logically understands why, please share.
    The following two pics focus on the Fi 12Q enclosure...
    I'm so glad I paid attention during my high school geometry, algebra and wood shop classes.
    This is the DD3510 build project, with a bending slot port...
    Omega3dog's Avatar
    Sep 2007
    Washington D.C
    62
    I chose to design two systems. The variable surrounds two different sub setups. One setup included Fi 12Q sealed. And the other included a Digital Design 3510, ported at 38hz. I will keep the better sounding design and sell the other.
    The better sounding enclosure will receive carpet.
    [My benchmark is a Fi 15BL on 2000w in a hatchback.] The Fi 12Q sounds great, but it's still not enough bass. The Kicker 1250 gain is set at 6,5, with a 2.5db bass boost @ 35hz. I hope the system will produce a bit more bass with additional tweaking to the system. However, it sounds so much better than my old 10L5, bridged off of the 600.4.
    Unfortunately, there are no pictures of the 3510, because ebay member lifeinthe760 sold a sub that didn't work at all. Unfortunately, I didn't discover the problem until I returned from a long trip. By then it was too late to do anything about it. I sent it to DD to have it re-coned.
    So, what do you think?
    Ken448's Avatar
    Ken448 is offline Get off my lawn.
    Jan 2008
    Southeast MI
    43
    3,025
    why you run the ground all the way to the battery??
    KHARPS's Avatar
    KHARPS is offline CarAudio.com Veteran
    Jul 2008
    IL
    31
    3,332
    That's some nice work man....god job.
    REFERENCES
    cam5860, Godsmack, dropkick13, ls2poweredgoat, bunkerking09, ProjectPechkin, GavinVoy, kmanian, magnum21, natetate, gqjeff, mustangowner, ssackett, hazardous0388, Rusty...WCA, ohsosmooth, grassroots, Leister, Scott S, Pyro_by_Nature, teamsolo, jblcamry, pickup1, got_focus?, fasfocus00, Zellner, Goindef154, Darknight, orangelss, Thorshammer1, BigSix
    rumblebee2's Avatar
    rumblebee2 is offline I'm Higher Than You
    Apr 2007
    Florida
    1,256
    i like what yo udid with the 3510 box.
    refs:blkmrideon22s,skrilla22,eatank,ampjunkielikem e,werd,snoopysnooper,team3d, 350zspl, finkster
    Feedback Thread:
    http://www.caraudio.com/forum/showthread.php?t=383386
    '05 Reg. Cab 1500
    H.U.- pioneer deh-6800mp
    Sub Amp- saz-1500d
    Sub- tc3k 12" Quad 1.4ohm
    Front Stage- pioneer garbage
    Front Amp-
    Wires- Knu Flex 1/0
    Rca's- Knu Krystal
    Fuse holder- kicker
    Omega3dog's Avatar
    Sep 2007
    Washington D.C
    62
    Quote Originally Posted by Ken448 View Post
    Xstatic recommended running the ground directly to the battery. Is costs a bit more, but I do not want to be in a situation of saying "Why didn't I follow the instruction?"
    mklett33's Avatar
    mklett33 is offline Senior VIP Member
    Nov 2008
    MI
    417
    61 Post(s)
    Why two different subs?
  9. #9
    blackbonnie's Avatar
    blackbonnie is offline The Revolution
    Jan 2007
    Grand Rapids, MI
    10,146
    nice building skills...and the ground straight to the batt is way more efficient then to the chassis
    HU - Pioneer 800prs
    Mids - Peerless HDS nomex 6.5's
    Highs - Seas Prestige Alumi-domes
    Front Stage Amp - Sundown 100.4D
    Sub - SA-12
    Sub Amp - Saz-1000D
    Wire - Knukonceptz, Kicker Hyperflex
    Blackbonnie References/Feedback
  10. #10
    Omega3dog's Avatar
    Sep 2007
    Washington D.C
    62
    Why use two different subs?
    I did not know the difference between sq and spl setups, from experience. I've read of differences between the two, but I wanted to experience it for myself.
    Every so often, I lie to myself by saying I only want a great sounding system to beef up my jazz. However, reality eventually kicks in at some point. And, I find myself listening to deep bass from some of the dirty south artists.
    I figured the spacing limitaion would bring the two setups (sealed 12 vs ported 10) into similar output alignments. Therefore, I decided to test my theory.
  11. #11
    Omega3dog's Avatar
    Sep 2007
    Washington D.C
    62
    As for the other parts of the setup, it's designed to allow for expansion. Most of the bass heads I spoke with started out small and ended up replacing the entire system. This setup allows me to expand equipment in phases, if I chose, without replacing wiring, fuse holders, etc.
  12. #12
    GiganticPrune's Avatar
    GiganticPrune is offline Senior VIP Member
    Apr 2008
    Orland Park, il
    399
    i loved that sx1250.1 when i had it!
    2006 stage 2 wrx.
    eclipse cd5000
    mtx ta3404
    polk momo front components
    mtx audio rears
    sundown 3500d
    3 mach 5 audio ixl10.2.2s
    refs: rowdyt, bigredhybrid, robinson,jerry, cslother, patfitz9
  13. #13
    Omega3dog's Avatar
    Sep 2007
    Washington D.C
    62
    Quote Originally Posted by GiganticPrune View Post
    What db did you set your gains?
