Page 1 of 2 1 2 LastLast
Results 1 to 15 of 23
Reload Thread: Battery drops to 8 volts on startup, need a new one?
    Supergumby5000's Avatar
    Supergumby5000 is offline Project: F350 begins...
    Sep 2005
    Pullman, WA
    8,358
    1 Post(s)
    17 Post(s)
    My girlfriends car has been having some issues.
    1) The starter sticks if it hasnt been started in a while, makes a loud vacuum-type noise (needa open it up and clean it out)
    2) i tested the voltage on her battery when she starts up. I did it twice after jumping her and letting the car run for about 20 minutes
    The first time, the car didnt struggle turning over at all, but voltage on the battery dropped to about 9.5 volts
    I had her turn the car off, wait a couple seconds, and start it again. This time around, it turned over real slow, and voltage dropped all the way down to 8 volts.
    I am aware the car needs to have the starter cleaned up, but will this effect the battery at all? Am i safe going to get a new battery right now, and fixing the starter later, or will the starter cause wear on the battery?
    Project: Avalanche V1... http://www.caraudio.com/forum/showthread.php?t=345189
    Project: Avalanche V2... http://www.caraudio.com/forum/showthread.php?t=432321
    Project: F350... Coming Soon!
    Need a box or box design? -EMAIL- me for info/quotes, do NOT send a PM
    my username @ hotmail.com
    Sep 2005
    Pullman, WA
    8,358
    1 Post(s)
    17 Post(s)
    Re: Battery drops to 8 volts on startup, need a new one?
    wow, i definately postd in the wrong section lol
    wu501's Avatar
    wu501 is offline CarAudio.com Veteran
    Mar 2004
    N.Y
    4,154
    1 Post(s)
    you sure the alt is working correctly?
    AlpineUser's Avatar
    AlpineUser is offline Bumpin
    Mar 2006
    St. Charles Mo
    31
    549
    fyi dont keep trying to start your car after you have seen that it has been reading 8 volts...it will damage your computer which is expensive...it should read above 9.6 volts which is normal ummm...check grounds...your alt...anything like that...maybe even a bad battery you actually want to see around 10.6 volts
    1998 Monte Carlo
    Alpine CDA-9857 hu
    2 Alpine Type R 12" Subs
    Audioque 1200d
    diamond hex 5.25"s with 1" tweets
    diamond d3's 6X9"s
    rockford 450.4
    3ish cubes @ 33Hz
    bigger box coming soon!!
    Sep 2005
    Pullman, WA
    8,358
    1 Post(s)
    17 Post(s)
    Quote Originally Posted by wu501 View Post
    I havent checked the alternator yet.
    If i jump the car, and right after the car starts, i turn the car back off. It will slowly turn over and start again.
    I jumped it again today so i could bring it to my place to put in the garage. After i drove it here, i turned it off, and when i tried to turn it back on, it started right up.
    After a few off-and-ons though, it would gradually get bad until it would slowly turn over again.
    And aside form that, all the lights and whatnot work fine, 100%. After the car starts up, everything works 100%. Its just that initial startup thats rough.
    DBBOOM's Avatar
    DBBOOM is offline DWN4MYN
    Oct 2008
    eastcoast
    3,629
    5 Post(s)
    If it only does this after the car is hot or been repeatedly started, it could be a bad starter.
    Natural selection at work.
    CRXBMPN's Avatar
    CRXBMPN is offline ---> TEAM B.L.O. ME <---
    Jul 2004
    Maine
    37
    8,905
    45
    1 Post(s)
    344 Post(s)
    is your battery post corroded?
    go get a battery load tester, i have one and its a very very valuable piece of info
    Sep 2005
    Pullman, WA
    8,358
    1 Post(s)
    17 Post(s)
    Quote Originally Posted by DBBOOM View Post
    We've already established the starter is going. I know what the problem is, and i know how to fix.
    That shouldnt effect the voltage drop on the battery though, would it?
    This is whats up with her starter:
    http://forums.vwvortex.com/zerothread?id=2269482
    I havent decided if im going just replace it, or if i want to try to fix it first.
    It doesnt say anything about side effects regarding voltage and actual difficulties starting up, just the grind noise.
  9. #9
    natisfynest's Avatar
    natisfynest is offline Balls Deep In Your Mom
    Sep 2008
    da nati
    2,196
    your battery isnt holding a charge
    1 check the water level in the battery if needed fill it and see if that helps
    2 if that dont work replace the battery
  10. #10
    Sep 2005
    Pullman, WA
    8,358
    1 Post(s)
    17 Post(s)
    Quote Originally Posted by CRXBMPN View Post
    battery terminals are covered in something ot keep corrosion off. Looks like grease to me.
  11. #11
    Moe Lester's Avatar
    Moe Lester is offline 1/3 of TEAM PWNAGE
    Dec 2003
    Houston, TX
    31
    3,614
    A bad starter can pull much more current than a good one, so yes it may cause excessive voltage drop. Also, after driving around for a while what does the battery voltage float at with the car off and no lights/accessories on?
  12. #12
    teamsolo's Avatar
    teamsolo is offline CarAudio.com Elite
    Feb 2007
    Memphis
    806
    sounds like the alternator is not charging the battery
    SOLD TO:nutnbutcustm(massive d400x), hemi=22s(2 mt motors), JB513, lil_italy773, TSGP, NewAgeKing, jeres313, sjobas, hornedfrog1985
    BOUGHT FROM: RE XXX(mt motor), us3, brtnboarder3241, Thelow, lvfive.o, Paaco1981, CRXBMPN, infamous_e46, k_schutte,Grinder1989
    TRADED:ssackett
    SCAMMER:de81127, rdaudioman1256
  13. #13
    CRXBMPN's Avatar
    Jul 2004
    Maine
    37
    8,905
    45
    1 Post(s)
    344 Post(s)
    i have a cheap 2/6/10a black & decker battery charger that has an alternator tester on it, maybe he has something similar that would help
  14. #14
    Sep 2005
    Pullman, WA
    8,358
    1 Post(s)
    17 Post(s)
    Quote Originally Posted by Moe Lester View Post
    Im pretty sure the starter isnt necessiraly "bad" though. I've been doing some reading about the issue (its fairly common apparently) and the gears in the starter just need to be relubed to get rid of the startup grind noise.
    I mean, after a charge on the battery, the car starts right up no problems. The grind is only on the occasional start if it has been sitting for a while.
  15. #15
    95ZJ's Avatar
    95ZJ is offline The Resident Ginger
    Jul 2006
    Electric Lady Land
    29
    2,595
    I'm having the same problem and just took my truck in for maintenance, yet they found nothing wrong with it.
