Ok guys, I have started working on my car a couple f weeks ago, it has been a very slow process because I am working a ton of hours but soon it will go much faster.
The vehicle is a 2005 pontiac g6 that I bought for a daily driver, I want to do a loud semi loud daily set up with all of the provisions to get much louder with minimal effort.
Here is a list of current equipment that might or might not be going into the project depending on if I change direction during the build.
electrical will consist of stock 140 amp alternator until I can find a company that makes a high output for this car (let me know if you know of an option). 1 Optima yellow top under hood, and 2 in trunk. Big 3 upgrade with 1/0 gauge hyper flex, 2 runs of 1/0 for power, 1 run from ground on battery under the hood.
stock head unit to keep the stock look.
JL clean sweep for interface,
precision power deq-230 for front stage,
infinity kappa perfect 6.5" component system for front stage,
infinity kappa perfect 5.25" components for rear fill,
for front stage amp I have a precision power pc4100 but might have to use my jl 300/4 due to space limitations,
sub amp is a us amps usa-2000,
sub is a DD 9515 I think it is the b motor, I might go with a more sq type of sub stage, I would like to do 3-4 8's.
If I do run the 9515 for a while I will run at about 3.5 cubes @36-38hz.
here are a couple of pics, I will upload much more once the process starts moving a little more.
The car... has about 32k miles, pretty clean.
got the trunk gutted to get ready for deadener.
started tapping into stock wiring for the clean sweep, will take signal out of stock amp so I do not loose on star and other stuff.
location for amp rack
have more and will upload later, baby is waking up.
Register To Reply
. keep us updated and keep up the good work man.
Bookmarks
