lotsshould be loud..how much did everything total up to?. Somewhere between 4-5grand all said and done.
Yes. Avalanches are designed with a removable rear wall, essentially. There is a "midgate", where you can open that up, remove the rear window, and turn the bed of the truck into an 8 foot bed rather than just a 5 foot bed.In for the pics as this should be interesting.
You said box in the bed and you have an Avalanche, so IIRC, you can gain access through the back correct?
Should be sweet! And good luck!
I'll simply be removing the mid gate and replacing it with the box and adding a beauty panel.
Im not sure yetshould be interesting man! how ya gonna wire all those LED's?. The wiring itself for them seems pretty basic, just a power and ground loop, and i'll throw a switch in there so they arent always on.
The LED strips themselves have 3M tape on the back of them, so mounting them wont be an issue.
Register To Reply
hopefully i'll be out of class so i can sign for it.
Bookmarks
