Page 18 of 18 FirstFirst ... 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18
Results 256 to 270 of 270
Reload Thread: MazzaSEC Build log! Sundown, Fi, Deka, PG RSDS
  1. #256
    king ranch's Avatar
    king ranch is offline Banned
    Dec 2007
    fl
    5,671
    Re: MazzaSEC Build log! Sundown, Fi, Deka, PG RSDS
    Quote Originally Posted by mazzasec View Post
    I cant I only have d2 subs. Its just wierd cause before I was running 2 1500d's at .5 stock alt and 1 1400 under the hood and 1 2400 in the rear and was dropping to 11.7 with STOCK alt and 2 Batteries. Now with a 250 amp alt and like 4 batteries I gained .2 of a volt...
    u can run one sub at 1ohm since its a dual 2ohm but i dont think it can handle that much power haha, if you could possibly not sure but u could try 2 1500's at .5 ohms again or w/e ohms work for your sub and see wat u get for volts, those 3000d at .5 might take alot of amps and not so efficient only thing i can figure
    that or try to shorten your runs of 1/0 as in one day take everything out of the truck and run like a 5ft run from front to back batterys outside the truck, and hook everything up outside and see wat drop it is haha seems weird but if u get better voltage then u need more runs of 1/0 and lots of it possibly
  2. #257
    MikeyB's Avatar
    MikeyB is offline CarAudio.com Addict
    Jul 2005
    H-Town, MI
    7,727
    Bah, scratch some of the stuff I said way up top ^^^ about the initial runs you have. I wasnt thinking about it.
    With even a single 1/0 run, from the front batt to the rear bank, your not going to have more power on tap then you can flow through your wire, if the alts producing a maximum of 250 amps.
    You can get between 200 and 250 amps through a single 20-25ft run.
    Refs- hessdawg, Pepsifiend69, iltoivfe, ownage9, lifted95blaze, Buckshot, da box king, Po.Sic, baseballer1100, vetkilr, dkguitarist, Queball, qtipextra, LaserRed38, 350_regal, RidnClean, BushJ311 and a bunch more...
  3. #258
    MikeyB's Avatar
    Jul 2005
    H-Town, MI
    7,727
    What would cause a full 406amp draw though? With the frequency changing I am sure its not likely to happen on just music.
    I know, I was just giving you some numbers as far as worst case scenario draw is concerned
    I am measuring the drop at the amp. Reads 11.8 Front battery reads like 12.4
    Man, that just seems to me like you should double up on runs. But ****......Im stumped.
    lol well I tried, I can barely think anymore and its time for
  4. #259
    iamamp3pimp's Avatar
    iamamp3pimp is offline Bass Heads Entertainment
    Nov 2003
    Tampa FL
    35
    13,103
    21 Post(s)
    instead of going to the store and buying 70 bucks more worth of wire
    pull the batteries out and buy a battery charger
    either wire them up in the house, o charge them one at a time.
    get one thats autosensing, and just let em run on the charge for a couple of days
    that should help.
    i know what the issue is, you arent worried that the drop will hurt the amps, you are mad because you spent over a thousane in equipment, and gained .2 volts.
    if by chance i was thinking of getting an H.O. alt, you just reminded me not too....i always thought that it was a gimmick, UNLESS the alt(s) were strong enough to power the whole systems draw, which im guessing it isnt.
    www.BassHeadsENT.net for all your custom enclosure needs
    Offering build service and expertise in the Tampa area as well as enclosures shipped nationwide!
    Robin@BassHeadsENT.net
    Check this thread for all the build logs being posted.
    http://www.caraudio.com/forums/suppo...ks-thread.html
  5. #260
    MikeyB's Avatar
    Jul 2005
    H-Town, MI
    7,727
    Quote Originally Posted by iamamp3pimp View Post
    that should help.
    Yeah right when I turned my comp off last night I thought about posting that up for him.
    When did the batts last get a good solid charge? That might help get the voltage up......cuz thats the deal, the batts should be able to handle most of the draw, while the alt should maintain them.
    However, thats also why I dont mind a HO alt, never having to charge your bank, or atleast not as often. Unless your non stop wangin full tilt and never topping off the batts.
    All you guys with these crazy setups have to worry about all those issues Me and my measly KX2500 and 220amp alt have nothing to worry about
  6. #261
    mobeious's Avatar
    mobeious is offline what does 0hz feel like?
    May 2004
    Bartow, FL
    4,839
    26
    2 Post(s)
    a factory alt is designed to run 90% of its power for the cars electronics and 10% for accessories ( radar detectors, stuff to plug into ciglighter) in order to gain from a aftermarket alt that 10% would have to be enought to offset the current draw of the amp ur using.. this is why u see people run 2 alts 1 for the vehicle 1 for the system and it works very well... so in all saying if u have a factory 80amp alt and are runnin a amp that draws 300a of current u would need a 370amp alt to see a good gain
    Alpine CDA-9833
    (2)sets Cresendo ccx65
    Box Engineer for
  7. #262
    MikeyB's Avatar
    Jul 2005
    H-Town, MI
    7,727
    ^ Word.
  8. #263
    Nov 2003
    Tampa FL
    35
    13,103
    21 Post(s)
    Quote Originally Posted by MikeyB View Post
    thats the thing though
    i dont have to worry about that, i have had my setup in for a year, and just now i ned to top them off
    so ill buy a charger soon.
  9. #264
    MikeyB's Avatar
    Jul 2005
    H-Town, MI
    7,727
    ^ Well **** then lol
  10. #265
    mazzasec's Avatar
    mazzasec is offline Banned
    Dec 2007
    ATL
    6,875
    2 Post(s)
    The kinetiks are resting at 13 volts though...
  11. #266
    Nov 2003
    Tampa FL
    35
    13,103
    21 Post(s)
    i heard they can sit as high as 13.8
    hook em up to a charger (autosense) until the charger stops charging em
  12. #267
    LDW3RD's Avatar
    LDW3RD is offline CarAudio.com Elite
    Jun 2003
    PHILLY
    47
    1,293
    8 Post(s)
    Do you have any idea what imp rise your getting with music?
    And dont know if its been asked but wire your subs at a higher imp and see what happens.
    (still reading prev post indepth)
    All reggae all the time.....
  13. #268
    LDW3RD's Avatar
    Jun 2003
    PHILLY
    47
    1,293
    8 Post(s)
    Ya but with 3 **** batteries and a 250 amp alt why am i still dropping into the high 11's
    Dropping when, with music or without music?
    Time 4 a beer.
  14. #269
    Nov 2003
    Tampa FL
    35
    13,103
    21 Post(s)
    with music
  15. #270
    Rawr-DQ's Avatar
    Rawr-DQ is offline !!!!Vote Third Party!!!!
    Dec 2004
    Fort Myers, FL Posts:____________31,337,666,999
    29
    2,882
    hahahahha, taking pics of the ups guy rofl.
    Quote Originally Posted by kickerassman View Post
    i was thinking some thing like this..... get a reall fine but strong sharp cable like them tension cables tie it around your neck and tie it to something..... then get some supper supper supper glue and glue your hands to your head.when the glue dries jump of the building with the cable cutting your head off and you would have your head glued to your hands ...... some one would see that and be like wtf omg that dude ripped his head off ... he mst have been pisssed!!!
    My Current Build Log: (16 8" Sundown subwoofers)
    http://www.caraudio.com/forum/showthread.php?t=367352
