Page 8 of 8 FirstFirst 1 2 3 4 5 6 7 8
Results 106 to 108 of 108
Reload Thread: RyanM923's Dual Reflex 6th Order BP build...whew.
  1. #106
    squeak12's Avatar
    squeak12 is offline CarAudio.com Veteran
    Apr 2005
    Thomaston, GA
    3,671
    Re: RyanM923's Dual Reflex 6th Order BP build...whew.
    Id just give up on it and go back to ported. Sure you might get it right eventually, but unless you are planning on competing big time, its not worth the time IMO. Believe me I tried it, and this is how the box ended up...
  2. #107
    JG903's Avatar
    JG903 is offline CarAudio.com Elite
    Nov 2005
    Jacksonville, TX
    504
    4 Post(s)
    Whenever I used WinISD and modeled it out, I got that a simple ported box would peak higher.
    The white graph is ported box: 10 cu. ft. tuned to 52
    The colored line is the bandpass box.
  3. #108
    RAM_Designs's Avatar
    RAM_Designs is offline SketchUp Master
    Feb 2006
    Rockwall, TX
    31
    21,086
    4 Post(s)
    457 Post(s)
    Quote Originally Posted by squeak12 View Post
    Yeah, I'm going to try cutting the port for the rear chamber down, and if that doesn't work I'll just go back to ported...
    Quote Originally Posted by chronic_mka View Post
    Hm, I was using normal winISD, the beta version, and I was able to get a huge peak doing the bandpass design...I'll probably just go back to ported and use the 6 4" aeroports I just ordered.
    2,500+ designs since March 2011
