Page 3 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 31 to 45 of 85
Reload Thread: Project Sidewinder.... SQ Dodge Dakota install!
  1. #31
    tez4life's Avatar
    tez4life is offline CarAudio.com Veteran
    Nov 2006
    Mobile, Al
    3,906
    Re: Project Sidewinder.... SQ Dodge Dakota install!
    Increadible setup, I can only imagine with all that processing that it sounds even better.
    Looks truly amazing, my hats off to you sir.
    2004 Ford Crown Victoria
    Alpine 9887 HU
    Stock 5x7 door speakers
    System is a work in progress.
  2. #32
    energizedsbs's Avatar
    energizedsbs is offline Senior VIP Member
    May 2006
    tarpon springs
    450
    Quote Originally Posted by 00RedRT View Post
    Yeah, I had some fabrication help from Jeff Smith and James Stanton (formerly of Audio Designs of Atlanta) now working out of Sound Sensations in Marietta, GA. By using a shop also helped me to get JL Audio and Kinetik on board as sponsors, which is not an easy thing to do.
    Jeff Smith does some killer work... very nice install.
    just give the dj a break
    where are they hiding...SEDONA
  3. #33
    00RedRT's Avatar
    00RedRT is offline Sidewinder
    Oct 2007
    Atlanta, GA
    89
    Quote Originally Posted by 95BlackGA View Post
    Impressive, very impressive. What is the red snake skin made out of?
    The snakeskin pieces are created through a process called Hydrographics. It's essentially the same manner in which they make wood grain interior items. The item is painted a base color, for me they color matched to the exterior (PR4) Flame Red. Then the item is submersed in water and the pattern is laid on the water surface and the part is drawn up into the pattern. Once dried the piece is then clear coated and it wears as well as any other painted part.
    Darren Alcorn
    2000 Dodge Dakota "Sidewinder" R/T
    SQ Dakota install completed!
  4. #34
    jdc753's Avatar
    jdc753 is offline Truck Brigade
    Nov 2006
    Mass
    28
    1,891
    absolutely beautiful. How many magazines has this been in so far, cause it sure should be in some.
    Amazing work through and through, as others have said the tweeters in the doors stink, what about picking up some factory door panels that don't have the factory tweeters and redoing those to match what you got. Its really the only place to fault your amazing install and its not even remotely a major point. Must sound amazing.
    2005 F350 crew cab diesel 4x4
    -Work in Progress-
    HU: Alpine 9887 linked to 10.4" TS TruckPC
    Front Stage: Polk SR6500 Active
    Front Amp: Sundown Sax100.4
    Sub: Stereo Integrity Magnum V4 in the center console
    Sub amp: Sundown Saz-1500D
    Refs: low_end, Relax, SSon22s, Johnson, tyroneshoes, twisztdpunisher, flakko, djhn9, KINGDELL91, amoffitt, Justin89T, 01 S 10, Mazzasec
  5. #35
    elite08's Avatar
    elite08 is offline www.SoundAdviceTexas.com
    Oct 2006
    Houston, TX ( Alvin ) [281]
    673
    A+
    nice work~
    alpine typeR 10 w/ ported enclosure
    alpine m-605
    pioneer head unit
    kicker 8aug wiring kit
    REFS: Ka41,
  6. #36
    peas247's Avatar
    peas247 is offline Hookers on the Point
    Jul 2007
    buffalo, ny
    28
    2,892
    1 Post(s)
    f*ckin sick man, very impressive
    refs - dumple(x2), banginexplorer, r/t pimp (x2), select127, joey2714, rollerdj, lincolntc690, psychoacoustics, mk_, boltpride, SHiZNiLTi, pr-festiva, emaxaudio, yunvme666, Coolwazabi, ssackett, JBGabriel, Mike465, avs20, siddle, DDbump, Andrizzle, SPY, gentlejax, Act Audio, bagged97tacoma ...............
  7. #37
    req's Avatar
    req
    req is offline am a mod.
    Jul 2004
    Syracuse, NY
    27
    15,432
    21
    awesome work, id like to have seen some more on axis stuff from custom kicks and door panels, but as long as the end result is great and the h701 is taken to its potential then ill let it slide
    love the buckets too. they look comfertable.
  8. #38
    visitor's Avatar
    visitor is offline Banned
    Sep 2005
    IOWA
    29
    464
    cool.
  9. #39
    fbi90909's Avatar
    fbi90909 is offline Panty Thief
    Jun 2006
    Key West, FL
    30
    7,772
    beautiful. that was the first thing that came out of my mouth after i saw the first pic.
    the install looks amazing, the only dislike i have is the snake skin pattern. in the first pic i thought it looked like wood grain. either way, awesome work done on your car man.
    i will not put **** or outside links in my signature again. if i do i will be banned. all hail the moderators.
  10. #40
    blazinb2000's Avatar
    blazinb2000 is offline CarAudio.com Elite
    Mar 2008
    Arkansas
    1,419
    Very nice install with tons of attention to details, I like how the bottom of the batteries are made to fit perfectly to the bed floor. Overall truck looks amazing. Is there anything done to the engine? Any plans for the engine?
    Alpine/Phoenix Gold/Rockford Fosgate/RE Audio/Knukonceptz
    Sold to: NMBR1SPT, craigzter, hemi=22s, darkhunter139, Derrick824, thegreatestpenn, JBGabriel, audiobahnuser18, LBC99, Team H&K, BASS_WARRIOR, busabob, HawaiianBassHed, 01 S 10
    Bought from: TeamPSI, Twistid
    Feedback: http://www.caraudio.com/forum/showthread.php?t=330244
  11. #41
    NeverEnuffBass's Avatar
    NeverEnuffBass is offline Got Bass?
    Dec 2004
    Greenwich, CT
    29
    3,587
    Looks sick man, love seeing super clean custom installs. I've seen you post over on DakotaDurango.com forums.
    98 Durango
    REBUILDING
    4 MT 15's
    4 Powerbass XA3000's
    4 Kinetik 2400's & 1 1800
    12 Powerbass 4XL's & Beyma AST05 Tweets
    3 Powerbass XA-2150's
    03 Sierra Denali
    Pioneer PRS 880
    Orion HCCA-D1200 & 4800HP
    4 eD 9Kv.2's
    Beyma SCK 5.25 comps
    Dayton RS180 Midbass
    http://www.premiereautosport.com
  12. #42
    00RedRT's Avatar
    Oct 2007
    Atlanta, GA
    89
    Quote Originally Posted by blazinb2000 View Post
    Thank you! Yes, the engine has most of the performance bolt-ons on it, PCM, roller rockers, intake manifold, shaker CAI, throttle body, headers, etc... And certainly some cosmetic mods have been done as well.
    This is how a stock Dakota R/T 98-03 engine bay looks....
    and this is my engine bay....
    Darren Alcorn
  13. #43
    00RedRT's Avatar
    Oct 2007
    Atlanta, GA
    89
    Quote Originally Posted by NeverEnuffBass View Post
    Thanks man, I've been following your build as well and it looks to be coming along nicely!
    Darren Alcorn
  14. #44
    Mar 2008
    Arkansas
    1,419
    That engine looks great. A great improvement over the factory look, I bet it will run pretty good. Have you dynoed it ever?
  15. #45
    mobileaudio219's Avatar
    mobileaudio219 is offline Senior VIP Member
    Dec 2004
    Central, Missouri
    318
    I love your truck!!!!!!!!!!!!
    Seriously, its not over done, just flows really nicely.
    1998 Chevy Blazer, 2dr, 4wd.
    Head unit: Pioneer AVH-P3200BT
    Front Stage: Front Stage: PPI 356c's
    Front Stage Amp: Hifonics ZXI 6410
    Sub(s): DAILY - 10" RE SRI, COMP - (6) 10" Memphis SR's
    Sub Amp: Hypnotics 1000.1 (yeah, upgrading VERY soon)
