Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
Reload Thread: Not really a build log....but pics of the box i just built
  1. #16
    Pop da Hatch's Avatar
    Pop da Hatch is offline Can haz?
    Jun 2005
    Minnesota/North Dakota
    27
    3,581
    Re: Not really a build log....but pics of the box i just built
    Quote Originally Posted by bonesninja View Post
    lol.....i'll be buying a bad *** table saw later this year. Add a couple router tables equpped with the bits i use the most and i'll be able to put these out pretty quickly. I build alot of arts and crafts for my wife also.
    pics? ahha jk, bet she has a killer set of nunchucks!
  2. #17
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    9,586
    13 Post(s)
    VERY nice work...
    Sent you a PM
  3. #18
    jdc753's Avatar
    jdc753 is offline Truck Brigade
    Nov 2006
    Mass
    28
    1,891
    looks pretty sweet. Specially the lettering, any tricks you used to do the lettering? Like is it carpet with a backing on it or just standard carpet? I haven't done much carpet work but the last bit I did where I would cut it would fray a bit and such and probably wouldn't come out very good if I attempted to make letters like you did.
    That sucker must have some weight to it lol, should be loud though thats for sure.
    2005 F350 crew cab diesel 4x4
    -Work in Progress-
    HU: Alpine 9887 linked to 10.4" TS TruckPC
    Front Stage: Polk SR6500 Active
    Front Amp: Sundown Sax100.4
    Sub: Stereo Integrity Magnum V4 in the center console
    Sub amp: Sundown Saz-1500D
    Refs: low_end, Relax, SSon22s, Johnson, tyroneshoes, twisztdpunisher, flakko, djhn9, KINGDELL91, amoffitt, Justin89T, 01 S 10, Mazzasec
  4. #19
    bonesninja's Avatar
    bonesninja is offline CarAudio.com Veteran
    Oct 2004
    Lima, Ohio
    40
    14,802
    Quote Originally Posted by jdc753 View Post
    actually what i did was print off the lettering on the 'puter, traced them out and used a 1/8" bit in my router and routed about a 3/8" groove to tuck the ends of the carpet into. It's regular non-backed carpet from Parts Express. The charcoal carpet cuts much easier than the black carpet does and you have to use very sharp blades in a utility knife/razor
    Quote Originally Posted by chase007 View Post
    if u need a box...I'l taked 3 years of shop class so i know what im doing.
    after i explained to him there's more to a proper box than boards and glue and he should practice before trying to sell boxes to others
    yes personaly if it was some one elce that just starting making boxes but i'v taken shop for 3 years now...Making a lil box is nothing i don't need to pratice on a box to get it right i learned alot of stuff from 1 box and i can fix that in my next box
    after i told him that customers would care about the looks of the box
    if u want some thing that looks pretty why don't u find a black guy with a big d*ck.
  5. #20
    Ali1's Avatar
    Ali1 is offline e6300 FTW
    May 2006
    U.S.
    3,510
    thanks for the enclosure, plenty loud
    Quote Originally Posted by northside210 View Post
    seems like everybody is going for pyle, should i tune them to 63 for the lows or 87
    refrences:
    logan_searching, Big Rea$e, rfluvinmf, Davecubs14, reaudiofan, Krazed4Bass, SR20det, jbizzle x 4, bamaboy, mazdakid, mike11202,sbcaprice305, anotherguy(yes, that is his sn), ROE, coreyanderson, gebrochen, 528hz, bassmasta (x2), ustroops52, noob24,vrwm, lafanboy, explodftl,TheLow, tommythecat,dub22, hunterw, many more.....
    **** PATALPINE :: SCAMMER******
  6. #21
    Memphis4L's Avatar
    Memphis4L is offline Got Bass???
    Jun 2005
    Sarasota, FL
    1,282
    good job
    Under Construction
    References-Shinobi, KARLEON, connersdad19, woofercooker(x2), TeamPSI, iamamp3pimp, rollerdj, themommyvan, ampjunkielikeme, bumpin buick, woodels420, j1b1e1, skittlesRgood, holla105, prochobo, Seth_3515
