+ Reply to Thread
Page 38 of 50 FirstFirst ... 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 LastLast
Results 556 to 570 of 743
Reload Thread: AQhdc318 + AQ2200 in my 01 Jeep Grand Cherokee
  1. #556
    GrandCherokee's Avatar
    GrandCherokee is offline CarAudio.com Elite
    Mar 2008
    Orlando, FL
    21
    960
    Re: AQhdc318 + AQ2200 in my 01 Jeep Grand Cherokee
    Quote Originally Posted by Immacomputer View Post
    No. That is a bad box design, I don't care if Jesus designed it. The port wall extends too far back into the enclosure and your port area changes at the inside of the enclosure. The port will not be as effective as it could be and you could easily get port noise from it.
    I think you would be better off going with a different design. I could crank something out for you if you would like.
    anyone else agree???
    btw yea ill definitely apprecaite if you can hook me up
    oh and the noise i was talking about b4...its only on certain notes...
    and its gotta be at full tilt-so hopefully its not a big deal
    like i hear the strange noise when i play KICKA DOOR/PUT ON at full tilt after a minute.
    so i just dont play that song at full tilt for a long time.
    Headunit: Alpine iDA-x100
    Sub: AQ hdc3 18"
    Amp: AQ2200 1ohm
    Enclosure: 6ft^3 tuned to 35hz
    Wiring: Tsunami
    refs: brian84corvette andrew2006 TC2k15x2 skmfkr
  2. #557
    DJL's Avatar
    DJL
    DJL is offline Owner, Audioque
    Dec 2004
    Stafford MO
    418
    5 Post(s)
    your total port length should be 16", you will have to "bend the port 90 degrees 6" from the back wall.
  3. #558
    Mar 2008
    Orlando, FL
    21
    960
    Quote Originally Posted by DJL View Post
    bend the port 90 degrees 6 form the back wall?
    Sub: AQ hdc3 18"
    Amp: AQ2200 1ohm
    Wiring: Tsunami
  4. #559
    01 S 10's Avatar
    01 S 10 is offline LOUD
    Jan 2008
    Central Florida
    25
    4,278
    16" long port in a 17" deep box? not gonna work, bend it 6" from the back like said above. if you keep the port 16" long, then you only need the port wall 10" long, the bend will make up the other 6" difference. Im tired, so correct me if im wrong, i only took a quick look at that pic
    -2005 GMC Sierra SLE crew cab
    -Pioneer Avic-d3, factory BOSE
  5. #560
    audiobahnuser18's Avatar
    audiobahnuser18 is offline CarAudio.com Veteran
    Nov 2005
    Mi
    25
    10,086
    15
    When i even been talkn to Dj about a enclosure for it he said in the net of 40hz.
    Refs
    Bigjon47 , JohnnyBussa , Mike Dressure , BTLking , Myjaja , Tapout , prowler573 , mommyvan , R-sosa , Audio Master , 95BlackGA , wu501 , Nismos14 , HawaiianBassHed , ECS23 , Bagged96Chevy, Donpisto , the other mike kmanian bumpin buick dumple wrench , guy , blazinb2000 , teen , phl1ser , Loud3 , Plyer3 , LazyRider , Jk32sho , MacQ32
    TreZ0r Is a lieing piece of sh*t scum bag SCAMMER!!!!
    REBUILDING IT ALL
    REFS:http://www.caraudio.com/forum/showthread.php?t=353034
  6. #561
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    9,601
    13 Post(s)
    tune your box to 35hz if you insist on listening to crap like put on and gucci...
  7. #562
    mlstrass's Avatar
    Jul 2006
    Illinois
    9,601
    13 Post(s)
    Your problem sounds like it might be the suspension popping problem that many HDCs seem to have and that AQ blames on an improper break in.
    Where are all these HDC's with noise problems that you speak of? I built boxes for around 12 of them this year and NO ONE has any noise issues. Of course we all broke them in properly to avoid damaging the spiders
  8. #563
    Freelander's Avatar
    Freelander is offline CarAudio.com Elite
    Jun 2007
    Jacksonville. FL
    533
    I would take that somewhere and have someone look at it, it should be flexing a lot more than that. Your rear view mirror is barely moving. My temp setup with two walmart pioneer 12's off 400 watts flexes more than that does.
    2003 Land Rover Freelander
    Headunit: Alpine CDA-9847
    Front Stage: Hertz HSK165's
    Rear Stage: Helix HXS 136 MKII
    Front/Rear Stage Amp: Clarion 3200A / Diamond D3 400.2
    Sub: 15" FiQ
    Sub Amp: MMATS D300HC
    Battery Front: Stock Back: Kinetik HC800
    Refs: Jblanford, Jmanpc, lyttleviet, ProjectPechkin, bass_lover1
  9. #564
    Immacomputer's Avatar
    Immacomputer is offline Cloud disappear
    Sep 2006
    Ocala/Oviedo, FL
    28
    4,646
    Quote Originally Posted by mlstrass View Post
    I've seen quite a few threads describing the same sound.
    And GrandCherokee... clear out your PMs.
    Video 1
    I may make you feel but I can't make you think.
    Your sperm's in the gutter -- your love's in the sink.
    Video 2
  10. #565
    MasterOfAllBass's Avatar
    MasterOfAllBass is offline Team Minnesota's Loudest
    Jun 2008
    Minnesota
    24
    2,439
    that a boy!
    (2) Ascendant Audio SMD 18's
    (4) Phoenix Gold Elite.1
    (6) Kinetik 2400 (2) Kinetik 1200
    (2) Dc Power 270XP 390XP
    (12) 2/0 Welding Cable Run's
    (1) Hertz Hi Energy HSK 165XL 6.5''
    (1) Hertz SPL Show ST25 Super Tweeters
    (1) JL Audio XD400/4
    Full OME HD 1 TON 3" Lift w/ Bilstein Struts 1500lbs Air Bags w/ 1 TON Springs Firestone 80psi 10 ply 245/70/17
  11. #566
    ramdaspadhye's Avatar
    ramdaspadhye is offline Senior VIP Member
    Jul 2007
    Memphis, Tenn
    225
    Thread started 7-30-08...
    38 pages...
    D@mn near 3 months and 38 pages of fail :/
    2010 GMC CrewCab Z71 (stock for now)
    =REFS=
    BryanCain (Trade)
  12. #567
    GMCJimmyslt2000's Avatar
    GMCJimmyslt2000 is offline ll Faded ll
    Feb 2007
    South Bend, IN
    1,558
    Quote Originally Posted by Freelander View Post
    what does flex have to do with anything. How are u gonna base a systems loudness off of flex. Some vechiles are built better than others, so they arent gonna flex as much. GTFO u noob@!
    Refs:
    Bought From- Spy, 18inchjeepin, BJ The Man, Jeeper07,
    Pjvoc, lil_italy773, NJTStang11
    Equipment:
    HU- Pioneer 4800
    Speakers- Stock Bose
    Sub Amp- Hifonics Brutus 1100@2ohm
    Sub- 15" Fi SSD w/ Copper Coils
    Box- 3cubes Tuned at 33hz
  13. #568
    Jun 2008
    Minnesota
    24
    2,439
    Quote Originally Posted by GMCJimmyslt2000 View Post
    x2
    my 1999 blazer dose not flex much at all and i have over 4000rms.
  14. #569
    Freelander's Avatar
    Jun 2007
    Jacksonville. FL
    533
    noob? LOL
    His system needs help. If you can't see that then you are the noob.
    Sub: 15" FiQ
  15. #570
    Feb 2007
    South Bend, IN
    1,558
    i no his system needs help....if u woulda read the whole thread i have said that at least 10 times.
    u basically said that his sytem isnt loud cuz it doesnt flex enough. so i said why would u base a system off flex. U dont flex is bad, so the less flex the better the sound stays in and louder on the mic.
    like i said GTFO noob
    Refs:
    Equipment:
    HU- Pioneer 4800
+ Reply to Thread
