Page 10 of 24 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 LastLast
Results 136 to 150 of 358
Reload Thread: Speak Peak
  1. #136
    galacticmonkey's Avatar
    galacticmonkey is offline Wants a button like that.
    Sep 2006
    Tampa, FL
    7,681
    139 Post(s)
    Re: Speak Peak
    No show for me tomorrow. Still gotta work the bugs out and get it playin the way it should be.
  2. #137
    Sep 2007
    Orlando
    29
    55
    Re: Speak Peak
    yeah def. need to post some vids nd finished pics....hopefully il be able to see this monster at a show sooner or later
  3. #138
    mdillon's Avatar
    mdillon is offline ummm......what?
    Nov 2007
    visalia
    772
    Re: Speak Peak
    Quote Originally Posted by galacticmonkey View Post
    Well still havent gotten all the bugs worked out... There is 1 amp that keeps going into protect on low notes, mainly when the doors are open.
    But with the deck just over 1/2, EQ volume on 1/2, and sub level on 1/2, its NASTY. Doors closed and windows down is straight up violent. Even completely sealed up its pretty much just as loud.
    Got a line driver put in today to help boost the signal. After we put the line driver in so far the rear view mirror came off instantly, and after a couple short tones the emblems/badge on my passanger door broke off. Its just a nasty amount of pressure it creates. For some reason the subs are barely even moving... Maybe 1/2" excursion at most. Not sure why, gotta figure that out. As it is the pressure makes it pretty hard to even breathe. Even just sitting on the floor of the cabin I reach for the steering wheel or door pannel to grab onto because it makes you so dizzy. You can actually feel it **** you in on the higher notes and push you out on the lower notes.
    So far Im real happy with the sound it makes, even though its not even playing correctly yet, and hasnt really been turned up much past half. Batteries are sitting at right around 12v, and havent even installed the alt yet or anything like that. So Im guessing if its as loud as it is now, when everything is completely finished, its going to be rediculous.
    your amp has a short my friend. had one do the same exact thing, played until half volume then shut off. you need a new amp
    '01 5.9 Dakota R/T
    HU: Pioneer Premier 680
    Front Stage: highs: B&G neo8 planars
    mid-bass: Hi-Vi Research 8" (x4)
    http://www.caraudio.com/forum/showthread.php?t=304095
    Subs: MB Quart Rwe304(x2)
    ported 4 cubes @ 30
    Amps: MB Quart Reference 4x50
    MB Quart Premium 1200.1D(1ohm)
    Quote Originally Posted by traksta15 View Post
    sad but true.....but remember, fat girls give better head cause they're always hungry.
  4. #139
    Sep 2006
    Tampa, FL
    7,681
    139 Post(s)
    Re: Speak Peak
    But its testing out just fine. The weird thing is when we disconnected that 1 amp and tried playing it, all the others went into protect.
    We have tested EVERYTHING with a DMM and it all checks out fine... Amp output voltage, remote voltage, battery voltage, speaker impedances, load at amp, made sure they were all in phase, etc.
  5. #140
    JEXTEL's Avatar
    JEXTEL is offline CarAudio.com Elite
    Jan 2007
    Bridgeton, NJ
    740
    Re: Speak Peak
    so what happen today????
    http://www.cardomain.com/ride/3042878
    HEADUNIT 9311ts | Pioneer AVIC F-90BT
    FRONT STAGE Rockford P400.4 and T4004 | 2 Audiopipe Super Tweeters | 2 Dayton 5's |4 Kicker ks13 Tweeters | 10 Selenium 6.5's
    THE BASS 2 FI BTL 18's | PG 8V Line Driver | Clarion 7 Band EQ | 2 GP3000d's @ .5ohm | Xquizite Konceptz wall @ 32hz
    ELECTICAL DC 315A 16v alt | 4 Runs of Knu 1/0 | 4 HC16v's| 1 HC2000 upfront
    "GET LOUD OR DIE TRYIN"
    only the loudest will survive.
    2009 Season 140-149.9 Bassrace Class
    2010 Season 150-159.9 Bassrace Class
    Team Deadly Hertz
    Team DC Power
    Maxima MLA Module FOR SALE cheap
  6. #141
    Skip01's Avatar
    Skip01 is offline Diggy
    Apr 2006
    Marrero,LA
    7,189
    20 Post(s)
    Re: Speak Peak
    My 500.1s did that when i had a blown sub
    Would play fine up until about 50% volume than out
    YOUTUBE VIDZ:
    http://www.youtube.com/user/Skip01
  7. #142
    Sep 2006
    Tampa, FL
    7,681
    139 Post(s)
    Re: Speak Peak
    Now we're thinking it might just be voltage... Dont even have my alt in and havent charged the batteries. So thats the guess for now. Going to put it on a real slow charge and let it soak it up for a while and see how that works.
    So If thats the problem, it explains all the "symptoms". I guess that one amp starts clipping out from the voltage (dropping to like 11.2) and shutting off. That would explain that, and also why the subs are barely moving, since if the voltage is sooo low, they wouldnt be getting as much power.
    The more we keep playin it, the louder it keeps on getting. As it keeps loosening up, its just getting rediculous. With a full charge its going to be insane. Eventually when I step it up to 16v.... Yeah.
  8. #143
    jeremiah's Avatar
    jeremiah is offline edit me but not ****? ok?
    May 2006
    Canton Texas
    2,871
    Re: Speak Peak
    what do you think it will bass race?
    subs 1 18" MJ-18
    amps 1 A3000DB
    speakers memphis PR's
    HU some crape pioneer
  9. #144
    Sep 2006
    Tampa, FL
    7,681
    139 Post(s)
    Re: Speak Peak
    No idea.
  10. #145
    JEXTEL's Avatar
    Jan 2007
    Bridgeton, NJ
    740
    Re: Speak Peak
    so g-monk what are you driving daily?
    Team Deadly Hertz
    Team DC Power
  11. #146
    Sep 2006
    Tampa, FL
    7,681
    139 Post(s)
    Re: Speak Peak
    I got 1 car, and this is it.
  12. #147
    Andrew12's Avatar
    Andrew12 is offline Honda.
    Dec 2006
    Pinellas, FL
    28
    3,060
    16 Post(s)
    Re: Speak Peak
    looks loud.
    Bought from: Abell255, chaunb3400, justadork2u, massiveaudiocw, 3kracing, sundownz, terra
    Sold to: Headshothills, Stevey hustle, djeazie, LDW3RD, trailz516
    Traded with: cd6551
    1999 Nissan Maxima GLE
    Pioneer
    Sundown Audio
    Audioque
    Zapco
    Hybrid Audio
  13. #148
    JEXTEL's Avatar
    Jan 2007
    Bridgeton, NJ
    740
    Re: Speak Peak
    whats in the car?
    Team Deadly Hertz
    Team DC Power
  14. #149
    Calikid's Avatar
    Calikid is offline Stack That Paper
    Feb 2006
    Los Angeles
    6,921
    19 Post(s)
    Re: Speak Peak
    Quote Originally Posted by JEXTEL View Post
    whats in the car?
    U haven't been paying attention have u?
  15. #150
    Calikid's Avatar
    Feb 2006
    Los Angeles
    6,921
    19 Post(s)
    Re: Speak Peak
    That's gangsta
