Page 6 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 76 to 90 of 112
Reload Thread: IA Death Row build log!
  1. #76
    orangecounty1's Avatar
    orangecounty1 is offline CarAudio.com Veteran
    Jul 2007
    Tampa, FL
    3,901
    Re: IA Death Row build log!
    lookin good
    i have that same table saw
    whats the relay for in the back? remote wire?
    Quote Originally Posted by galacticmonkey View Post
    Id much rather read a thread about someone getting flamed, even if its me, since it will at least be entertaining.
    Quote Originally Posted by Rawr-DQ View Post
    monkey you're a fat *****.
  2. #77
    audioarsonal's Avatar
    audioarsonal is offline JaMarcus
    May 2007
    close to home...
    4,165
    1 Post(s)
    Thanks everyone...And Thanks to IA2 for the glue!!!Recieved it today.
    Bought from:whiteram,Pyro_by_nature,AudioXtremes,Slab,IA2
    Sold to:annarbor84,ssackett,tapout383
    built for:skeptikal,Raid3r89
    SHADY SELLER:memphisman00
    Subs:4 Incriminator Audio Death Row 15's
    amps: Memphis 4K
    [email protected]
  3. #78
    skeptikal's Avatar
    skeptikal is offline Hold the wheel and drive skeptikal is a Supporting Member of the forum!
    Jul 2004
    Indiana, US
    4,066
    22 Post(s)
    I have to hear this dude. Get at me this weekend sometime.
    2005 Dodge Ram Quad Cab
    Pioneer DEH-80prs
    Image Dynamics X-65
    Image Dynamics XS-28
    PPI 900.4
    Wolfram 1500.1
    Sundown Audio SA-12 D4 (x2)
    Noico deadener
    NVX wiring
  4. #79
    May 2007
    close to home...
    4,165
    1 Post(s)
    Quote Originally Posted by skeptikal View Post
    Hit me up.You got my number.
    amps: Memphis 4K
    [email protected]
  5. #80
    May 2007
    close to home...
    4,165
    1 Post(s)
    I worked on the electrical side a it this week.Since I can't do any testing till the weekend I thouht I would put in some of the 1/0 I got from Kent(thanks).
    I ran two runs of positive for now to the back.I didn't have any voltage drop from front to rear after doing both runs so I should be fine for now.
    FIrst pic
    Here are the 2 runs coming through the fre wall on the passenger side.This is the usual place I try to run most of my power wires on any vehicle.Unless there is a groumet or the battery is on the driver side.
    Here you can see them runnin along the floor board.With the 2 runs it is a little harder to get the carpet to set right.However I was able to make it almost disappear.
    Here I ran it out the latch spot where the seat used to be.I was able to get 2 runs out of 25ft no problem.
    Here is the fuse block under the hood.I had to modihy it a bit seems how it was for 2 4ga wires.
    Here you can see the wires tied together and routed away from the engine to prevent them from melting(has happened to me in the past.)Sometimes I wrap it with some scrape deadener with the aluminum backing for exra insurance.
    On to the alt.this is the connection to the post on the back.
    And here is the Iraggi Alt I got.Its got a custom machined pulley made of aluminum.This lightens the weight by about half.
    amps: Memphis 4K
    [email protected]
  6. #81
    MikeyB's Avatar
    MikeyB is offline CarAudio.com Addict
    Jul 2005
    H-Town, MI
    7,727
    I want a pulley for my Iraggi!!!!!
    Refs- hessdawg, Pepsifiend69, iltoivfe, ownage9, lifted95blaze, Buckshot, da box king, Po.Sic, baseballer1100, vetkilr, dkguitarist, Queball, qtipextra, LaserRed38, 350_regal, RidnClean, BushJ311 and a bunch more...
  7. #82
    May 2007
    close to home...
    4,165
    1 Post(s)
    ^^^PM me.
    amps: Memphis 4K
    [email protected]
  8. #83
    May 2007
    close to home...
    4,165
    1 Post(s)
    Quote Originally Posted by orangecounty1 View Post
    lookin good
    Yep,I like to use them when running alot of things that require a switched source.And with these HK's they don't like to see low voltage on the remote input.
    amps: Memphis 4K
    [email protected]
  9. #84
    May 2007
    close to home...
    4,165
    1 Post(s)
    Well, I got to do SOME testing and tuning today.I am very pleased with the box and output.I installed the second amp and got them all wired up.
    First let me tell you this testing was done with lil jon's "throw it up" as I didn't have a test tone cd on me or avalible at the time.
    So I guess you would call these numbers off music and not a test cd.However I will get a cd and do real testing with actual test tones.
    Now on to the results.I stopped the cd just prior to the very first bass drop on the song right around the 56-57sec mark.I paused it set the volume to 30/62.First test I did was with 1 amp wired to 2 ohms.I burped the song for about 2-3 sec and got a reading of 148.4.Did it a sec time and got 149.2.After that I hooked up 2 subs on each amp wired at 1 ohm.Then I repeated the same test exactaly as before.First burp I got a 150.8.Reset the song and did a 50.9.After that I moved a couple things around then did it again.151.2DB!!!!
    Now keep in mind these results are from burping a song not a test tone but it is results!I will continue with making small changes to the box(rounding corners,bracing,port,etc)
    Any suggestions are welcome.
    amps: Memphis 4K
    [email protected]
  10. #85
    rockmo's Avatar
    rockmo is offline Senior VIP Member
    Jan 2008
    halfway, mo.
    348
    6 Post(s)
    ****ed nice man.
    refs:
    BOUGHT FROM: thegreatestpenn,
    TRADED WITH: Mikey7182,hemi=22's,woofercooker,grimreper912003
  11. #86
    May 2007
    close to home...
    4,165
    1 Post(s)
    Thanks.
    amps: Memphis 4K
    [email protected]
  12. #87
    Sep 2007
    Orlando
    29
    55
    ny flex vids??
  13. #88
    Jun 2008
    USA
    305
    Looks great man, Keep up the good work!
  14. #89
    IA2's Avatar
    IA2
    IA2 is offline CarAudio.com Elite
    Nov 2003
    Killen, AL
    35
    1,162
    3 Post(s)
    updates? finished pics?
    INCRIMINATOR AUDIO: We manufacture the dee bees
    Check us out on Myspace and Facebook!
    Co-owner of Incriminator Audio
  15. #90
    May 2007
    close to home...
    4,165
    1 Post(s)
    God its been a while since I posted up in this thread!!SORRY....
    Anyway, I've been working like crazy for the last couple weeks getting things ready for Slamology!!Haven't had time to snap pics along the way.However I have gotten a lot done since the last photo's.Did some MORE bracing as the **** was flexing like crazy!!!Built the trim panel around the outside to seal it off.Also re-did the wiring inside the box cause it kept rattling inside on certain notes.
    I need to get up some vids but my I can't figure out how to format it to work on my computer from my camera.I had one but it didn't work.
    And this is just with 1 amp!!I found out a couple of my batts are about dead so its time for new ones.
    I will get some vids today and try and post them......
    amps: Memphis 4K
    [email protected]
