Page 2 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 16 to 30 of 112
Reload Thread: IA Death Row build log!
  1. #16
    audioarsonal's Avatar
    audioarsonal is offline JaMarcus
    May 2007
    close to home...
    4,165
    1 Post(s)
    Re: IA Death Row build log!
    I will and if you haven't seen the subs here is the link to my review.Which I will also update with listening tests and numbers.
    http://www.caraudio.com/forum/showthread.php?t=316245
    Bought from:whiteram,Pyro_by_nature,AudioXtremes,Slab,IA2
    Sold to:annarbor84,ssackett,tapout383
    built for:skeptikal,Raid3r89
    SHADY SELLER:memphisman00
    Subs:4 Incriminator Audio Death Row 15's
    amps: Memphis 4K
    [email protected]
  2. #17
    Spud2388's Avatar
    Spud2388 is offline "The Spud-n-ator"
    Apr 2005
    Iron Station, NC
    632
    Quote Originally Posted by audioarsonal View Post
    Yeah its served me well.Its the v6 so its not to bad on gas.But after I put all this **** in I'm sure my MPG will go way down
    It's an inline-6...sorry, fellow WJ owner here. Good luck running wires to the rear...pain in the ***.
    1999 Jeep Grand Cherokee
    Alpine CDA-9857 w/ iPod
    Alpine PXA-H510 (for sale)
    ED NINe.1
    ED NINe.4
    CDT CL-62 (soon to be Rainbow SLC 265 )
    (2) Alpine SWR-1242D (4.5 cuft. @ 32 hz)
  3. #18
    May 2007
    close to home...
    4,165
    1 Post(s)
    ^^^You are correct..As for wires I haven't had any problems yet.However I'm sure 3 or 4 runs of 1/0 will be more of a challenge.
    amps: Memphis 4K
    [email protected]
  4. #19
    DaGh0st's Avatar
    DaGh0st is offline Drill Baby Drill!!
    Nov 2005
    Caro,MI
    33
    7,737
    In for more pics.
    Do not buy from IndoAudio.
    Quote Originally Posted by MasterOfAllBass View Post
    im a feg!
  5. #20
    NeedDirections's Avatar
    NeedDirections is offline alligator toilet seats
    Jan 2007
    Tampa, Florida
    929
    What are you doing electrical wise? Those amps are power hogs..
    2002 Volvo S40T
    Pioneer 780
    PG RSD 6.5
    Kicker 300.2
    Treo SSX 12"
    RD 1750.1
    SPL-C115
    Refs: Pimpedout97x, TreyE, Columbus, 95VolvoSx, oxsign, Pioneerpimp (x2), Bones22, PlushDJ, Reson8, JPD2621, rmdl51, Rollerdj, LS2poweredGoat, Orangecounty1, Iamamp3pimp,Woodels420, SQL4Life ...etc.
    Quote Originally Posted by vforvengance
    Forget all that. Iam a bass head the louder the better, the more windsheilds and sunroofs I blast out my car the happier i will be. I hope I lose my hearing to bass, instead of something crappy like IDK jets engines running at wk or whatever. Is preference dude. Some people like it. Imma do myself a favor and bang as loud as I can....
  6. #21
    May 2007
    close to home...
    4,165
    1 Post(s)
    Electrical consists of 1 Iraggi 300a alt 2-3 runs of 1/0 and 4 deep cycle batteries(will be buying 2 more)plus the one under the hood.
    I have been running my 1 hk for about a year now with just 2 batteries and the alt and haven't seen less then 13.1-4v at full volume.
    I have the electrical to back these amps.
    amps: Memphis 4K
    [email protected]
  7. #22
    .::DuD3::.'s Avatar
    .::DuD3::. is offline EE in training
    Oct 2004
    Chesafreak, Va
    30
    4,530
    Just curious, but fellow wj owner here as well. Where are you making your runs of 1/0 through the firewall? I only need enough room for 1 run. Also, where did you ground the amp, I was going to ground the amp at the battery, but if theres a good spot in the trunk, I'll do it there.
  8. #23
    May 2007
    close to home...
    4,165
    1 Post(s)
    I drilled a whole in the firewall on the passenger side.That is how I ran most of my power wires for the last 12 years.Just easier then trying to find a spot that is useable.However if there is one(rubber graumet) and will work with the wire I am running then I'll use that.
    As for the ground I use one of the rear seat bolts that I cleaned up as the ground.I am still debateing on using this for this application or if I should run a full ground wire.
    If you look at one of the pics you can see where I am talking about.It is the piece of black wire wire I attached the strapping to.
    amps: Memphis 4K
    [email protected]
  9. #24
    ContourSPL's Avatar
    ContourSPL is offline Senior VIP Member
    Jun 2006
    Paoli, IN
    327
    Since I've also had 4 15's in my Jeep, I'll make a suggestion. Keep the port in the middle of the box and not along the bottom. Try and keep the subs as close to the front also.
    Like this:
    I could set off car alarms on a regular basis with only being powered by 2200 watts.
    This box is way louder than my enclosure with the slot port along the bottom. I've also spoke to some competitors about having the subs closer to the front worked better in a Jeep. Anywho, good luck on the build.
  10. #25
    May 2007
    close to home...
    4,165
    1 Post(s)
    Thanks I will keep that in mind.I have done quite a few boxes for this jeep.Subs up ports back,subs back port back,subs forward ports back.I have heard subs back port back was hte way to go in these with the port just off the rear hatch.Personally I like the subs back port back with alot of port area.
    However in this build I am doing a wall just behind the b-pilar.Trying for hair tricks
    amps: Memphis 4K
    [email protected]
  11. #26
    May 2007
    close to home...
    4,165
    1 Post(s)
    Well I got a little more done today.First I picked up a piece of MDF to start the box part of the build.
    Got these new clamps yesterday.48" aluminum clamps from HF on sale.
    Got a couple corner clamps as well.
    These things are life saver when working alone.
    Got the bottom part of the box cut out and seeing if it will fit.
    Then I cut the top pieces and got them to line up.
    After that it was on to pre drilling and glueing the 2 pieces together
    amps: Memphis 4K
    [email protected]
  12. #27
    May 2007
    close to home...
    4,165
    1 Post(s)
    Hoping tomorrow to get the sides and back built.So should have some good progress pics.I keep debating on if I should just do the double baffle like the rest or a triple?I will be using all thread for some bracing and 2x3 for others.
    amps: Memphis 4K
    [email protected]
  13. #28
    5.3bowtie's Avatar
    5.3bowtie is offline CarAudio.com Elite
    Mar 2008
    Detroit, MI
    955
    4 Post(s)
    46 Post(s)
    um......nice cordless drill by the way.....can't go wrong with the ol' craftsmen with the built in light
    2009 Pontiac Vibe
    JVC KD-X340BTS | Stock Speakers | Massive Nx2 | Kicker Comp 12" loaded enclosure.......it'll have to do for now.....
  14. #29
    ContourSPL's Avatar
    Jun 2006
    Paoli, IN
    327
    oh, I guess I should have read the post better. Well, good luck on the wall!!
  15. #30
    2000LaDe's Avatar
    2000LaDe is offline CarAudio.com Veteran
    Aug 2006
    Lafayette, IN
    3,680
    58 Post(s)
    lookin good so far. figured u would have made the base wider to get as close to the sides as possible.
    Great New Forum CLICK ME!
    www.soundcheckcustoms.com/audioforum
