Battery pos is on the bottom and the brace is bolted to the floor and 4 inches away from the distro block that is attached to the side panel. You can push on the bracket and rock the van without it moveing.
Check out MidwestSpl at www.midwestspl.com
Refs - Solo1,Sanman,Hellrzr,Quis,The_Rowlands all bought from on USACI Andrew_as from MidwestSPL
Quis,Andrew_as Sold to
1994 Thunderbird
JVC KD-AV7010
Alpine 6x9 3-ways
Pioneer 6x8 3-ways (rear)
JVC CH-X1500 12-disc MP3 Changer
Alpine Type X 12" 2 cubes @ 30hz
MTX 404 runs the inside
MTX 1501d runs the X
Optima G75/25 RT up front
2x Optima G31 YT in the trunk
200a EA HO Alt (1/0 Big 3)
ALL MY WIRE IS WELDING CABLE
DO NOT SEND ME ANYTHING USING UPS. I WILL NOT DEAL WITH THEM EVER AGAIN
OFFICIAL FEEDBACK THREAD
used hte old trusty seatbelt bolt eh?
'01 5.9 Dakota R/T
HU: Pioneer Premier 680
Front Stage: highs: B&G neo8 planars
mid-bass: Hi-Vi Research 8" (x4)![]()
http://www.caraudio.com/forum/showthread.php?t=304095
Subs: MB Quart Rwe304(x2)
ported 4 cubes @ 30
Amps: MB Quart Reference 4x50
MB Quart Premium 1200.1D(1ohm)
It looks close in the pic, but really isn't. I can try and get a better pic.
I used the back seat belt bolt for an extra ground, had the short piece left over. There is still the other run of neg from front to back as well. Get a reading of 14.32 to the back. With new stock 160amp alt.
kool build looks decent but needs panelsto clean it up that brace is way to close to the distro lets sya u brake realy had brace falls off hits distro block ur unconsions and that starts fire . good luck
MYSPACEhttp://www.myspace.com/eargasm559
MY FEEDBACKhttp://www.caraudio.com/forum/showth...96#post4669596
PM ME IF YOU NEED CUSTOM WORK DONE FOR YOU(E.I, DOOR PODS, PANNELS, KICK PODS, anything FiberGLASS
noice. i get like 13.4v at the rear battery with a g31, a g34 and 200a alt (at idle)![]()
1994 Thunderbird
JVC KD-AV7010
Alpine 6x9 3-ways
The brace is bolted and doesn't move. Rocks the van when you push it from the back. it is farther away from the distro then it looks.
Forgot to add. I did the typical decal thing. But didn't overdo it.
Only problem I have now, is the back side windows. Need three people to man the van when metering.
Have to figure a way to seal them tighter and still be able to show they work. Motorized pop out style.
put deadener on them?
1994 Thunderbird
JVC KD-AV7010
Alpine 6x9 3-ways
Still wouldn't help how weak they are. Has one pivot point for the motor to push the window out. may try to add extra weather stripping. See if that helps. If not, then I am sure someone at a comp would aid in holding the windows.
Yea my van had the same problem, actually was the same color as mine too. I was thinking of removing the or disconnecting the motors and just sealing the windows shut. Or if you still want them to work you could fab a bracket to hold them shut and then just unlatch it when you will not be competing...other then that i dno
That may work. Have to see if that is within the rules and not put me in a different class.
Ty for the suggestion.
No fusing from front to back batteries.
Bookmarks
