Page 5 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 61 to 75 of 81
Reload Thread: Nova Build Log
  1. #61
    Nova76's Avatar
    Nova76 is offline CarAudio.com Elite
    Feb 2008
    Tucson, AZ
    25
    782
    Re: Nova Build Log
    Quote Originally Posted by 07montecarlo View Post
    flooding set your floats on your holley
    did that checked them three times when i was working on her yesterday and the mixture screws are out 1 1/2 i had them at 2 1/4 and it was running rich i played around with the idle dint make a diff
    Car-1976 Chevy Nova
    Engine-350 HO sBc, Holly 650cfm, 1" wide open carm spacer, 470/470 Comp Cam, High Volume Oil Pump, double roller timing chain, Edelbrock RPM Air Gap Intake
    HU- Pioneer DEH-P2900MP
    Inside Speakers- (2)Kicker 6x9s rear (2)Clairion 6.5"s doors (1)Pioneer 4x6 dash
    Inside Amp-
    Sub Amp-1000.1D
    Wire- Lightning audio 2 gauge
    Subs- 12" Lightning Audio VC2 x2
    Box- 2.5cf sealed
    REFS-
    Sold To - DBDRAGGUY
    Traded With - Ravens9322
  2. #62
    Jan 2008
    las vegas nv
    63
    Re: Nova Build Log
    holley are very sensitive to idle mixture,at the most 3/4 out from snug bottom is the most.
    also your idle (air/fuel)circuit is over and done by 800-1000 rpm then your primary kicks in,it should be a smooth transition with no lag
  3. #63
    Jan 2008
    las vegas nv
    63
    Re: Nova Build Log
    also where are your butterfly in conjunction with your transition slots.should look like a tiny square,those need to be set b4 you put carb on then idle then fuel mixture
  4. #64
    speedfreak28's Avatar
    speedfreak28 is offline CarAudio.com Veteran
    Oct 2007
    south jersey
    3,820
    Re: Nova Build Log
    id re route the fuel line, when the car gets hot it can vaporlock and make it near impossible to start. reroute it away from the engine and inside the frame rail away from exhaust manifolds or headers.
    2005 QC dodge ram for now
    UNDER CONSTRUCTION
    Sold To:defj. HowLowd, backthepack, thegreatestpenn, acura2005, headbussaboi, SPY, rc10mike, protown, flipGTO, ECS23, Jeremy M, dt053, r.sosa, blubberbutt, macq32,civicman07, fast85_gt, fatboyracing, cbrei1023, 96tbird, ado, SPL-Master,JHughes, FJF, blackdragonaudi, bnacht, niggz89, ggjeff, SoCalBean420
    Bought From Blunt, Kawasaki SXT-R, Kickinaudio, valant_94gt, HATCHET_WARRIOR, orangecounty1, teh korndog, kmanian, NJAV1, mr_kebo, lilmaniac2, 99grandprixGT, JBLCamry, jh8909
    traded with dropped_mazda,
  5. #65
    Oct 2007
    south jersey
    3,820
    Re: Nova Build Log
    also, just noticed your running 800cfm carb, way too much for mild 350 daily, should honestly probably be about a 650cfm, bigger isnt always better.
    UNDER CONSTRUCTION
  6. #66
    Nova76's Avatar
    Feb 2008
    Tucson, AZ
    25
    782
    Re: Nova Build Log
    i have no idea what your talking about?
    Quote Originally Posted by speedfreak28 View Post
    it has a problem starting when it hasnt been started but once i get it started its ok it will start right back up after a couple mins but when i turn it off fuel will trickel down into the carb i can hear it when the air cleaner is off idk whats wrong with it weather it needz a rebuild or what i was also thinking maybe my fuel pump on my engine is meesing up as its old maybe thats why my car will go to dye is it not getting fuel to it?
    i put the fan shroud back on because when it starts to get at like 180-190 it starts to shut off when i stop.
    Car-1976 Chevy Nova
    Inside Amp-
    Sub Amp-1000.1D
    Box- 2.5cf sealed
    REFS-
    Sold To - DBDRAGGUY
  7. #67
    Nova76's Avatar
    Feb 2008
    Tucson, AZ
    25
    782
    Re: Nova Build Log
    put the fan shroud on and cleaned the wires up a little put some extra wire clamps on em so it looks a little better
    BEFORE
    AFTER
    Car-1976 Chevy Nova
    Inside Amp-
    Sub Amp-1000.1D
    Box- 2.5cf sealed
    REFS-
    Sold To - DBDRAGGUY
  8. #68
    Nova76's Avatar
    Feb 2008
    Tucson, AZ
    25
    782
    Re: Nova Build Log
    well i sold the carb waaaaaaay to big for my engine it was flooding my engine out so i put the smaller one on and with the money imna paint my rims either stright black or black and yellow any sudgestions?
    Car-1976 Chevy Nova
    Inside Amp-
    Sub Amp-1000.1D
    Box- 2.5cf sealed
    REFS-
    Sold To - DBDRAGGUY
  9. #69
    car_lost's Avatar
    car_lost is offline Member
    Mar 2008
    Miami, FL
    117
    Re: Nova Build Log
    forget painting the wheels. put that $$$ towards whatever needs fixing or towards the system.
  10. #70
    Nova76's Avatar
    Feb 2008
    Tucson, AZ
    25
    782
    Re: Nova Build Log
    the only thing thats wrong is the tranny but it still drives i just cant race it but i dont really care bout that and i only got bout 56 bucks after buying some shirst i still gotta get my hair cut so thats bout 12 bucks so ill only have 44 bucks idk i probly could find a used 4 channel off craigslist and get my vocals loud as **** again
    Car-1976 Chevy Nova
    Inside Amp-
    Sub Amp-1000.1D
    Box- 2.5cf sealed
    REFS-
    Sold To - DBDRAGGUY
  11. #71
    car_lost's Avatar
    Mar 2008
    Miami, FL
    117
    Re: Nova Build Log
    do you HAVE to spend it?
  12. #72
    audiobahnuser18's Avatar
    audiobahnuser18 is offline CarAudio.com Veteran
    Nov 2005
    Mi
    29
    10,081
    15
    Re: Nova Build Log
    Very nice man looking great. i told u that nova had some potential. keep up the great work man.
    Refs
    Bigjon47 , JohnnyBussa , Mike Dressure , BTLking , Myjaja , Tapout , prowler573 , mommyvan , R-sosa , Audio Master , 95BlackGA , wu501 , Nismos14 , HawaiianBassHed , ECS23 , Bagged96Chevy, Donpisto , the other mike kmanian bumpin buick dumple wrench , guy , blazinb2000 , teen , phl1ser , Loud3 , Plyer3 , LazyRider , Jk32sho , MacQ32
    TreZ0r Is a lieing piece of sh*t scum bag SCAMMER!!!!
    REBUILDING IT ALL
    REFS:http://www.caraudio.com/forum/showthread.php?t=353034
  13. #73
    MikeyB's Avatar
    MikeyB is offline CarAudio.com Addict
    Jul 2005
    H-Town, MI
    7,727
    Re: Nova Build Log
    Quote Originally Posted by Nova76 View Post
    Dont paint the rims! I think it would look fugly with black or black and yellow wheels.
    Refs- hessdawg, Pepsifiend69, iltoivfe, ownage9, lifted95blaze, Buckshot, da box king, Po.Sic, baseballer1100, vetkilr, dkguitarist, Queball, qtipextra, LaserRed38, 350_regal, RidnClean, BushJ311 and a bunch more...
  14. #74
    MikeyB's Avatar
    Jul 2005
    H-Town, MI
    7,727
    Re: Nova Build Log
    Start saving up for that tranny
  15. #75
    grimreper912003's Avatar
    grimreper912003 is offline <- getting a jAy eL 21W8
    Jan 2008
    WI
    5,596
    1 Post(s)
    Re: Nova Build Log
    with that money and welding wire you could get your name out of my sig
    BTW hell of a car man, looks great.
    Bought/trade: TheLow, Nova76, nate2587, Black3SQ, hessdawg, Rockmo, kovemaster559, GearGuy2001, Bones22, dbman150, notoriousroc1, fasfocus00, canyouhearmatt, pelekeliko, Plyer3, justadork2u, sundownz,kasimo420, Zeuslicious, reynardmc22, Haunz, ciaonzo x2, 350Regal x2, Worstenemy453, woofercooker x2, annarbor84, 99Bonney, K_Schutte + MORE
    Sold to: illbmeubu, MTXman, sctattooer, MTX520, AlexJB, dropped mazda, annarbor84
    Nova76 Scammer
    Quote Originally Posted by Worstenemy453 View Post
    Lmao i texted him to tell him bout a thread and he said, cant lulz, im at a tity bar. You ********* lulz.
