Page 4 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 46 to 60 of 148
Reload Thread: Cadence wire
  1. #46
    Kangaroux's Avatar
    Kangaroux is offline I put on
    Dec 2010
    Maine
    9,487
    81 Post(s)
    Re: Cadence wire
    Quote Originally Posted by Tony30cl View Post
    you can see above why im not a fan of cca period...used the same exact points for the big threee but this time used ofc...no problems
    Guess it's a good thing my big 3 is in 2/0 lol. I'll just make sure to make my connections tight then. Probably just check them every couple months
  2. #47
    CAT MAN's Avatar
    CAT MAN is offline Banned
    Dec 2010
    Roanoke,VA
    8,162
    113 Post(s)
    Re: Cadence wire
    Quote Originally Posted by Kangaroux View Post
    yeah at first i thought it was solder. then i crimped them...same thing. so i didnt try anymore cca
  3. #48
    Kangaroux's Avatar
    Dec 2010
    Maine
    9,487
    81 Post(s)
    Re: Cadence wire
    Hmm that's strange. Idk I've just never had that problem and the temperature up here fluctuates like crazy so I don't suppose that is a contributing factor
  4. #49
    CAT MAN's Avatar
    Dec 2010
    Roanoke,VA
    8,162
    113 Post(s)
    Re: Cadence wire
    yeah i tried everything . someone else told me it was where i grounded to the manifold that it was no good to leave there (BS BTW sh*ts fine) so i moved it . tried it all and the same stuff happens until i used ofc.... but yeah if i ever see any cadence ofc im buyin it
  5. #50
    Kangaroux's Avatar
    Dec 2010
    Maine
    9,487
    81 Post(s)
    Re: Cadence wire
    What battery do you use? Cause the first thing I always do is replace the batt with something that's AGM
  6. #51
    CAT MAN's Avatar
    Dec 2010
    Roanoke,VA
    8,162
    113 Post(s)
    Re: Cadence wire
    its a normal starting batt. and dont go sayin '' you need agm thats why that stuff happened to you'' because it isnt true . the power the battery puts out is the same no matter what kind it is(im talking clean 12v power not AH or anything else). the only thing that differs are internals and how it stores/releases the power.
  7. #52
    Kangaroux's Avatar
    Dec 2010
    Maine
    9,487
    81 Post(s)
    Re: Cadence wire
    I wasn't going to say that but a weak or bad battery could have possibly been the cause of it. Idk just throwing around ideas here
  8. #53
    CAT MAN's Avatar
    Dec 2010
    Roanoke,VA
    8,162
    113 Post(s)
    Re: Cadence wire
    battery tested greaat . i got it recharged before i did this also
  9. #54
    disturbed471985's Avatar
    disturbed471985 is offline CarAudio.com Veteran
    Jun 2009
    Greenwood, La
    28
    6,645
    11 Post(s)
    Re: Cadence wire
    All my wire is CCA. Going on a good 2 years without a single issue. Not saying that crap does not happen but for my car and my needs the CCA is a perfect choice. Cost was low supports the amount of power I want to run. If I decided to ever run more power I will just run a second run of CCA and still come out cheaper then running ofc plus I will have the ability to support 500amps of draw something a single run of ofc could not do.
    RIP Christopher Maynard Martin "My heart"
    HU - Eclipse CD7000 For Sale
    Front Stage - 4 Silver flute 6.5's & 4 Seas Prestige tweets Sold
    Front Stage amp - DB Drive A7 125.4 For Sale
    Subwoofer - 3 Skar VVX 10's (Looking for 4th so I can run amp at .5ohm) Sold
    Subwoofer Amp - Skar SK-2500@.67ohm For Sale
    Box - 4.25cf tuned to 30hz using a 6" internal aero 15" long.. For Sale
    Wiring - Knukonceptz everything, Big 3, Sprinter S12V370F & HC1800 Sold
  10. #55
    CAT MAN's Avatar
    Dec 2010
    Roanoke,VA
    8,162
    113 Post(s)
    Re: Cadence wire
    Quote Originally Posted by disturbed471985 View Post
    All my wire is CCA. Going on a good 2 years without a single issue. Not saying thats crap does not happen but for my car and my needs the CCA as a perfect choice. Cost was low supports the amount of power I want to run. If I decided to ever run more power I will just run a second of CCA and still come out cheaper then running ofc plus I will have the ability to support 500amps of draw something a single run of ofc could not do.
    oh im not saying not to use it im just voicing out why i personally do not use it anymore. i never had any problems before this with cca but so many times of trying to still use cca and then use ofc with no problems kinda ruins the worth of cca
  11. #56
    TnT_Sounds's Avatar
    TnT_Sounds is offline profiling gets **** done!
    Apr 2008
    Colorado
    23
    3,624
    Re: Cadence wire
    Yeah i see nothing in the pics but what looks to be lead solder corrosion...
    3 8's
    39.9 consistently
    Quote Originally Posted by PV Audio View Post
    It will never be proved that loudness is somehow related to SPL because it isn't.
    Loudness, a subjective measure, is often confused with objective measures of sound pressure such as decibels or sound intensity.
    Quote Originally Posted by Pete Kulicki
    Building a stereo just to measure it's sound pressure level is like building a microwave oven for no reason other than to measure it's electromagnetic radiation emissions.
  12. #57
    CAT MAN's Avatar
    Dec 2010
    Roanoke,VA
    8,162
    113 Post(s)
    Re: Cadence wire
    Quote Originally Posted by TnT_Sounds View Post
    you're blind... but i already know what you try and do.
  13. #58
    TnT_Sounds's Avatar
    Apr 2008
    Colorado
    23
    3,624
    Re: Cadence wire
    lol numb nuts.. that black crap is not carbon tracking... It would have melted the insulation completely off.
    Try again
    3 8's
    39.9 consistently
  14. #59
    CAT MAN's Avatar
    Dec 2010
    Roanoke,VA
    8,162
    113 Post(s)
    Re: Cadence wire
    Try again
    try again but it is. and its not lead corrossion. remember it happened to it every time i re did it. even when i crimped/changed grounds.
  15. #60
    CADENCE SOUND's Avatar
    CADENCE SOUND is offline Supporting Vendor CADENCE SOUND is a Supporting Member of the forum!
    CADENCE SOUND is a Supporting Vendor of the forum!
    Jul 2011
    Howell, New Jersey, United States
    470
    6 Post(s)
    Re: Cadence wire
    Glad so many of you have had great experiences with our wires. Too bad for the few mishaps.
    With the various climates, engine temps and other conditions, wires really go through a lot of extremes leading to all kinds of issues.
    Some people have zero issues, for years, while others encounter the same issues over and over again..
    We will be having more spools, and other wiring available soon.
    In the mean time, Tony & TNT..please save your debate for the PMs, thanks
    RyKo@CadenceSound.com
    Marketing/Sales Rep
    Like our page for coupons and updates on Cadence Gear! www.Facebook.com/TeamCadence
