+ Reply to Thread
Page 3 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 31 to 45 of 127
Reload Thread: Problems with TheBatteryMan
  1. #31
    Falcons's Avatar
    Falcons is offline that **** i dont like
    Jan 2011
    Albion, New York, United States
    5,099
    17 Post(s)
    Re: Problems with TheBatteryMan
    Lol how the hell do you Fvck up a battery? Lmao
    Things to look forward to:
    (2) 10" or 12" imperium audio designs subs
    set of PHD MF 6.5" comps
    Completely seal off and deaden my doors
    aquire a 2k amp
    aquire a 2 channel amp for front stage
  2. #32
    NASTY08IMPALA's Avatar
    NASTY08IMPALA is offline CarAudio.com Veteran
    Aug 2012
    LOUISVILLE, KENTUCKY
    2,922
    31 Post(s)
    Quote Originally Posted by falcons03079313 View Post
    Ive seen idiots swell em up like ballons
  3. Thanks av83 thanked for this post
  4. #33
    cdc351jeferson's Avatar
    cdc351jeferson is offline Premium Member cdc351jeferson is a Supporting Member of the forum!
    Jul 2012
    austin tx
    1,582
    12 Post(s)
    if you go to auto zone for anything have them check your alt
    headunit : Sony xab-601bt
    fronts: infinity kappa 60.9's
    subs: 2x dc 12" xls
    box : 3cuft net 33hz ORIGINAL STARR MOUNTAIN SOUND NUTHUGGER
    sub amp: AQ3500.1
    others: Mechman 240amp alt, 3 xs3400batts , all 1/0 knukoncepts kollosus flex, stinger deadener
    REFS: Bradfordp2612 , Double 07 , NASTY08IMPALA
  5. #34
    Mr.G6's Avatar
    Mr.G6 is offline Junior Member
    Dec 2012
    manfield OH
    24
    using a standard wetcell charger for hours and hours on end
    90% of wetcell chargers have voltage right off the bat..as to where every agm charger i own STARTS with the battery resting voltage and slowly brings it up..
    agm chargers clean the plates of the battery too and conditions them..
    wetcell chargers do none of that..
    YES u can charge a agm battery on a basic wetcell charger for a little time..but sustanied or multipul tries at this will swell that Fvuker up like a ball
  6. Thanks audiobaun thanked for this post
    Likes kushy_dreams liked this post
  7. #35
    JoeK's Avatar
    JoeK is offline CarAudio.com Elite
    Apr 2012
    Ringtown, PA
    18
    1,055
    4 Post(s)
    alt is fine. without the powerwqre I get 14.4
    excuse my typing as I'm on mobile
    I'm using an interstate 75 in leiu of the piwerwqre temporarily. may not have the.capacity but it holds 14.4 on idle
    ** NEW VEHICLE AND BUILD ** 2003 Jeep Liberty Sport
    2x SPLAudio DAD BD 12s
    2x SK-1500.1s
    Box 5 cubes @ 29hz
    XS Power D3100 & D2400
    Tenney 270A
    4x PowerBass 3xl 6.5s
    Clarion CZ702
  8. #36
    audiobaun's Avatar
    audiobaun is offline Premium Member audiobaun is a Supporting Member of the forum!
    Jun 2011
    rockwall,Tx
    5,889
    36 Post(s)
    It might be of best interest to take those bats/batt to a local Boat seller,and see if they can charge them up, and get some results..It may be possible that you have already damaged some inner cells due to the time of charging with the reg batt charger, rather than the trickle/digital boat batt charger..id get them checked out though at a local Boat seller,as they have excellent experience of these types of batteries, or a well known Motorhome/travel trailer facility..they will be able to let you know pretty much as soon as they are hooked up..They may charge very little to check out, or nothing at all..just a recommendation for you
  9. Likes Jes 42 liked this post
  10. #37
    JoeK's Avatar
    Apr 2012
    Ringtown, PA
    18
    1,055
    4 Post(s)
    Just to clarify:
    (a) I never put the battery on a charger until after it has been problematic
    (b) The alt is fine. It does 14.4V(14.9 if cold) without the powerware. The instant the powerware is connected, the entire system voltage drops.
    (c) It's been 3 weeks of promises for a return but nothing.
    (d) The battery resting voltage is 11.6 when not connected to anything. Load tester i have indicates full load under 6V
    2x SK-1500.1s
    Box 5 cubes @ 29hz
    Tenney 270A
    Clarion CZ702
  11. #38
    JoeK's Avatar
    Apr 2012
    Ringtown, PA
    18
    1,055
    4 Post(s)
    Quote Originally Posted by Mr.G6 View Post
    ok guys i MIGHT be new here but thats beside the point..
    i recieved a text about this 1st thign this MORNING straight from nicholas about this thread..
    here is EXACTLY what he said.
    dude got the battery was happy as hell to get it ..said his voltage was GREAT.. then he proceeded to charge it like its his religion..with a STANDARD battery charger for a entire week..
    and NOW this guy wants his money back for something HE made happen...
    fact of the matter is the guy got a awesome battery that all rest at 12.7 to 12.8volts and he proceeded to charge it for a week on a standard charger..
    I never attempted to charge it until after it has been proven to be problematic. IT was a great battery, but after one day it went down the drain
    ---------- Post added at 09:30 PM ---------- Previous post was at 09:29 PM ----------
    Also forgot to mention, the battery charger i used was a 10a trickle charger, fully automated and digital.
    2x SK-1500.1s
    Box 5 cubes @ 29hz
    Tenney 270A
    Clarion CZ702
  12. #39
    audiobaun's Avatar
    Jun 2011
    rockwall,Tx
    5,889
    36 Post(s)
    Quote Originally Posted by JoeK View Post
    Just to clarify:
    Hmm, not good,especially C
  13. #40
    Jul 2012
    austin tx
    1,582
    12 Post(s)
    yeah bro that ***** hope it all works out . in the end you did buy a cheap no name china batt
    subs: 2x dc 12" xls
    sub amp: AQ3500.1
  14. #41
    JoeK's Avatar
    Apr 2012
    Ringtown, PA
    18
    1,055
    4 Post(s)
    I understand i **** at everything i do, but i didnt mindlessly kill this thing. The current batteries(stock+interstate megatron) work great, :/.
    If anybody still thinks its my fault, do let me know.
    ON an additional note, i have saved all PMs from and to nicholas mccabe about the whole thing.
    And also, note (D) should be 8.5V, not 6
    2x SK-1500.1s
    Box 5 cubes @ 29hz
    Tenney 270A
    Clarion CZ702
  15. #42
    Jul 2012
    austin tx
    1,582
    12 Post(s)
    save your money next time and buy a xs power
    subs: 2x dc 12" xls
    sub amp: AQ3500.1
  16. #43
    JoeK's Avatar
    Apr 2012
    Ringtown, PA
    18
    1,055
    4 Post(s)
    Quote Originally Posted by cdc351jeferson View Post
    I'm hoping to return this for $150 towards a name brand battery, Kinetik, Optima, or XS Power. Probably Kinetik due to price point
    2x SK-1500.1s
    Box 5 cubes @ 29hz
    Tenney 270A
    Clarion CZ702
  17. #44
    Jes 42's Avatar
    Jes 42 is offline MAF.COM-FEK SKAM AUDIO
    Aug 2012
    O.H.I.O.
    823
    7 Post(s)
    Well whatever you do good luck.Hope this gets resolved to both parties likings.
    "Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, a beer in one hand, body thoroughly used up, totally worn out and screaming "WOO HOO what a ride!"
    http://www.caraudio.com/forums/itrader.php?u=1019171
    Kenwood x996
    Incriminator Audio 20.1
    2-15'' Hifonics Olympus XXV 2415
    JL audio e4300
    Pyle pro ppa 6.5's-rear
    Crescendo pwx 6.5's-front
  18. #45
    Jul 2012
    austin tx
    1,582
    12 Post(s)
    didnt you learn about cheaping out on a battery jsut now and your going with another cause of price point?
    subs: 2x dc 12" xls
    sub amp: AQ3500.1
+ Reply to Thread
  1. Do you guys have problems with alpine ?
    By schrunk in forum General Discussion
    Last Post: 02-02-2002, 06:21 PM
  2. Problem with JVC KD-SH77
    By <Intel> in forum Wiring, Electrical and Installation Help
    Last Post: 01-06-2002, 04:22 PM
  3. What are the problems with bandpass?
    By CheapPyramidStuff in forum Wiring, Electrical and Installation Help
    Last Post: 12-26-2001, 01:53 AM
  4. problems with alternator
    By <jsons2fly> in forum Wiring, Electrical and Installation Help
    Last Post: 12-24-2001, 03:40 AM
  5. Having a problem with Ignition wire
    By sacarap in forum General Discussion
    Last Post: 12-14-2001, 10:39 AM
