Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 52
Reload Thread: Coming soon to Audio Technix - Due in stock late August
  1. #16
    CHEMMINS's Avatar
    CHEMMINS is offline CarAudio.com Veteran
    Aug 2010
    Nevernever Land
    4,091
    479 Post(s)
    Re: Coming soon to Audio Technix - Due in stock late August
    Quote Originally Posted by cthedinger View Post
    This is what it looks like after 4 hours at 300 degree's. The surface was not cleaned before applying and it was applied by hand without a roller.
    Was this laid flat or vertical? Looks great by the way. The wifes Touareg will be screaming for some of it.
    References:
    kmarei, ge_off_me, AudioPipe, slim2fattycake, Louisiana_CRX, ARMed&Bangin, EXTREMECHEVYMAN, Dpc69ss, Psychoacoustics, Shinju, jonny101abc, snoopdan
    BUYING SILVER TOP TRF MOTORS
  2. #17
    Kangaroux's Avatar
    Kangaroux is offline I put on
    Dec 2010
    Maine
    9,902
    3 Post(s)
    1624 Post(s)
    For any of you looking for rollers, you can get a $2 roller from Lowes/HD in the wallpaper section. It's all hard plastic, not a rubber roller. I used it for getting the 60mil on and it worked great, had 0 issues. The roller isn't cheap enough where if you put too much pressure it breaks, it's actually built pretty well.
  3. Thanks cthedinger thanked for this post
    Likes cthedinger liked this post
  4. #18
    cthedinger's Avatar
    cthedinger is offline CarAudio.com Elite
    Jul 2009
    Inglewood, CA
    1,118
    166 Post(s)
    Quote Originally Posted by CHEMMINS View Post
    It was not flat. It was set up at an angle (like a door panel)
    It was set up very similar to this video
    Audio Technix Sound Deadener Heat Test - YouTube
  5. #19
    CHEMMINS's Avatar
    Aug 2010
    Nevernever Land
    4,091
    479 Post(s)
    Sweet. And good to see the multiple layers hold up well. Looks like you have 4 layers stacked on the one piece.
    References:
  6. #20
    cthedinger's Avatar
    Jul 2009
    Inglewood, CA
    1,118
    166 Post(s)
    Can't remember there exact number of layers but wanted to add extra weight to the piece of deadener attached to the metal to make sure it held up in the heat.
    60 mil weighs roughly .5 lbs per sq ft and the 80 mil weighs roughly .75 lbs per sq ft.
  7. #21
    CHEMMINS's Avatar
    Aug 2010
    Nevernever Land
    4,091
    479 Post(s)
    Not bad, especially considering MLV is 1 lb/sq ft.
    References:
  8. #22
    Phoenix Risen's Avatar
    Phoenix Risen is offline OG.... Original Ginger
    Jun 2010
    Dayton/Springfield, Ohio
    4,064
    350 Post(s)
    when will a pre-order be starting.
    R.I.P. 2008 Hyundai Tiburon GS
    2005 Subaru Baja turbo, build in planing stages.
  9. #23
    av83's Avatar
    av83 is offline CarAudio.com Veteran
    Mar 2012
    Illinois
    3,031
    13 Post(s)
    1335 Post(s)
    Quote Originally Posted by Kangaroux View Post
    I just use a super cheap little wooden one I had laying around. A rolller is a roller, lol.... And I'm pretty sure AT's stuff woulda stuck fine even had I done it by hand....
    80prs
    SoundQubed 6.5 Pro's DD T2 Tweeters / new 4 Chan coming / new subs coming / DC Audio 5.0K
    Singer 310 6 phase 2 runs of Monster Cable 1/0 / Exide g78 AGM under hood and XS D3100 in rear
    Plenty of deadener. CCF and fiberglass insulation in doors... thanks to the advice of keep_hope_alive they sound AWESOME! :-)
  10. #24
    Kangaroux's Avatar
    Dec 2010
    Maine
    9,902
    3 Post(s)
    1624 Post(s)
    Quote Originally Posted by av83 View Post
    Yeah you can just use your hand but it gets sore after a while lol
  11. #25
    cthedinger's Avatar
    Jul 2009
    Inglewood, CA
    1,118
    166 Post(s)
    Quote Originally Posted by Phoenix Risen View Post
    Audio Technix Sound Deadener Pre-Order!
  12. #26
    CAT MAN's Avatar
    CAT MAN is offline Banned
    Dec 2010
    Roanoke,VA
    8,131
    2373 Post(s)
    let me know when you get some in i need some by the 26th if at all possible
  13. #27
    rebelfromva's Avatar
    rebelfromva is offline CarAudio.com Veteran
    Jun 2011
    VA
    3,818
    1605 Post(s)
    Quote Originally Posted by CAT MAN View Post
    This but I don't think it will be in before then
    09 Cobalt LT
    Headunit -Alpine CDA-9887
    Front Stage - PHD FB 6.1 PRO SIX M/B, FB 5.1 m/b, FB 1.1b tweets
    Highs amp -Pheonix Gold Xenon 100.4 & 200.4
    Sub stage - 2 DC M2 LVL 5 12s
    Sub amp - 2 DC 5.0Ks
    Electrical - Singer 270 alt, big 3 0/1 & 12g ofc audio technix, 2 XS d3400s
    Deadener - 80 mill Audiotechnix deadener
    "Trunk hit hard like Kimbo Slice"
    TEAM DC AUDIO
  14. #28
    cthedinger's Avatar
    Jul 2009
    Inglewood, CA
    1,118
    166 Post(s)
    It wont be here by then, sorry. It is should be here around August 30 - September 4.
  15. #29
    CAT MAN's Avatar
    Dec 2010
    Roanoke,VA
    8,131
    2373 Post(s)
    hmm if i can get it by the 8th of sept...... if not it will be nov before i order do you have any bstock ?
  16. #30
    cthedinger's Avatar
    Jul 2009
    Inglewood, CA
    1,118
    166 Post(s)
    Due in stock in 6-10 days!
  1. Replies: 75
    Last Post: 12-21-2012, 11:32 PM
  2. Replies: 18
    Last Post: 08-30-2011, 11:58 AM
  3. Replies: 2
    Last Post: 08-24-2002, 03:55 AM
  • You may not post replies
