Results 1 to 2 of 2
Reload Thread: Are Power Acoustik Amps Any Good?
    caraudionewbie's Avatar
    caraudionewbie is offline Junior Member
    May 2002
    Calgary, Ab, Canada
    Icon32 Are Power Acoustik Amps Any Good?
    I am thinking about getting a Power Acoustik MT1600-2 Sterling Amp 1600w.
    What do you guys think about Power Acoustik amps? Are they any good?
    The amp is gonna be pushing 2 kicker solobaric L5 12" with 600w/rms
    here are the amp specs:
    MT1600-2 -Full Mosfet Power Supply -PWM Circuitry -Full Selectable Crossover HI/FULL/LOW -Three Way Protection Circuit -2 ohm Stable Stereo -Tri Mode Capable -Variable Low Pass 40Hz. to 120Hz. -Variable High Pass 150Hz. to 1.5kHz. -18dB Bass Boost @40Hz. -Freq. Response: 10Hz. to 30kHz. -S/N Ratio: 97dB -THD: 0.02% -System Distress Indicator -High/Low Level Inputs w/Floating Ground -4 AWG Power/Ground Connection -Gold Plated RCA Connectors -Line Output -2 Ch. -310x2 @4 ohm, 370x2 @2 ohm -Mono RMS: 740w -Bridged: 1600w -Dim.22"Lx11.25"Hx2.25"W
    abcdefg's Avatar
    abcdefg is offline CarAudio.com Veteran
    Oct 2002
    Clarksville, Tn
    31
    2,330
    power acoustick amps are pretty good i have the 1200watt one but i think u should go towards a jbl 1200.1 that would power them good
