Results 1 to 5 of 5
Reload Thread: Power Acoustiks Amplifiers...What Do You Think
    caraudionewbie's Avatar
    caraudionewbie is offline Junior Member
    May 2002
    Calgary, Ab, Canada
    Icon32 Power Acoustiks Amplifiers...What Do You Think
    I am thinking about getting a Power Acoustik MT1600-2 Sterling Amp 1600w.
    What do you guys think about Power Acoustik amps? Are they any good?
    here are the amp specs:
    MT1600-2 -Full Mosfet Power Supply -PWM Circuitry -Full Selectable Crossover HI/FULL/LOW -Three Way Protection Circuit -2 ohm Stable Stereo -Tri Mode Capable -Variable Low Pass 40Hz. to 120Hz. -Variable High Pass 150Hz. to 1.5kHz. -18dB Bass Boost @40Hz. -Freq. Response: 10Hz. to 30kHz. -S/N Ratio: 97dB -THD: 0.02% -System Distress Indicator -High/Low Level Inputs w/Floating Ground -4 AWG Power/Ground Connection -Gold Plated RCA Connectors -Line Output -2 Ch. -310x2 @4 ohm, 370x2 @2 ohm -Mono RMS: 740w -Bridged: 1600w -Dim.22"Lx11.25"Hx2.25"W
    Durex's Avatar
    Durex is offline Member
    Jul 2002
    TEXAS
    36
    125
    what kind of subwoofer are you going to get?
    May 2002
    Calgary, Ab, Canada
    I have two kicker solobaric L5 12" that have a 600w/rms at 1200w/max rating
    abcdefg's Avatar
    abcdefg is offline CarAudio.com Veteran
    Oct 2002
    Clarksville, Tn
    30
    2,330
    they are pretty good but theres better out there
    F150Matt's Avatar
    F150Matt is offline Senior VIP Member
    Jul 2002
    Houston, TX
    31
    484
    3 Post(s)
    Notice that your 1600watt amplifier has an RMS of 740...thats not even half of what they say for that amp...you could get a much better amp for the same price....
    Matt Sibley
    Dad, Electrical Engineer, MBA
    Used to do these:
    Team S.P.E.A.D. Captain
    Team Kicker
    Team Maxxsonics
    USACi Pro Stock 5001+ World Record Holder
