Results 1 to 4 of 4
Reload Thread: amp power output help
    carmat06's Avatar
    carmat06 is offline Junior Member
    Mar 2005
    WA
    I'm running an older alpine 3554 amp with the following specs:
    4 channel mode:
    50 watts x 4 into 4 ohms
    750 watts x 4 into 2 ohms
    3 channel mode:
    50 watts x 2 into 4 ohms or
    75 watts x 2 into 2 ohms and
    150 x 1 into 4 ohms
    2 channel mode
    150 watts x 2 into 4 ohms
    What I want to do however is run 2 channels at 2 ohms and 2 channels at 4 ohms. (Wiring 4 four ohm rear speakers in parallel) but I don't know if having different resistances in the channels is bad for the amp, or what kind of wattages I would get out. If anyone has any idea on this I wouldn't mind some help.
    Matt
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,300
    Re: amp power output help
    Well, having the two different impedences isn't necessarily bad. Plenty of people essentially do that same thing (by running two channels to their front speakers, and bridging the other two channels to their sub).
    However, I question your wanting to run 4 rear speakers What's that all about?!?
    carmat06's Avatar
    Mar 2005
    WA
    Yeah, well, I've got 4 5 1/4" speakers and thought I might as well use 'em, and that size doesn't fit in my fronts.
    Matt
    squeak9798's Avatar
    Jun 2004
    USA
    26,300
    Eh.....I'd stick with only using 2, at most, back there. Don't need to use them just because you have them.
  1. Which AMP do you think produce more power ??
    By golfreak in forum Amplifiers
    Last Post: 03-13-2005, 06:01 AM
  2. will this amp be enough power for 2 15's?
    By bang hard in forum General Discussion
    Last Post: 03-02-2005, 03:44 PM
  3. Clipping and Power output
    By kw_rock in forum Amplifiers
    Last Post: 02-22-2005, 09:45 AM
  4. Amp get power, but doenst work
    By <MyCarsNamedAlice> in forum Amplifiers
    Last Post: 12-31-2001, 02:13 PM
