Results 1 to 2 of 2
Reload Thread: amps
    agy's Avatar
    agy
    agy is offline Junior Member
    Jul 2002
    toroto, ONT
    14
    amps
    I have 3 alum (audiobahn) 10in subs (dual 3 ) & 1 MAaudio amp (HC2502) 2500 watts at 1 ohm. should i run the subs at 1.3 ohms or 4 ohms? which one well i get more power?
    more_spl's Avatar
    more_spl is offline only have 1, but it's 12"
    May 2002
    Winnipeg
    27
    1,108
    is that 2500x1 ? how many channels is it. if the amp is stable down to 1 ohm, then i'd run @ 1.3 ohms.. you'd get more power flowing to the amp when the load is reduced
    (in MOST cases, in this case it will).. but isn't MA equip over rated? i thought they were a sheetty company?..
    i decided not to have a signature
