Results 1 to 6 of 6
Reload Thread: 4 channel amp 2 different ohm loads?
    puppie_chow's Avatar
    puppie_chow is offline The American Nightmare
    Mar 2002
    Montana
    708
    I've got a 4 channel Viper amp. I want to use the front 2 channels at 4 ohms on some components. I wanna use the rear channels to a set of subs. The subs are each SVC 2ohms. Can you have 2 different ohm loads on 1 amp? Thanks, by the way, Im the man.
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,300
    Re: 4 channel amp 2 different ohm loads?
    Yes, you can do that. Actually.....a lot of people do it that way
    Mar 2002
    Montana
    708
    Then can't I just wire pos to pos and neg to neg from speaker to amp on each speaker?
    squeak9798's Avatar
    Jun 2004
    USA
    26,300
    Quote Originally Posted by puppie_chow
    Can't I just wire pos to pos and neg to neg from speaker to amp on each speaker?
    Yes, you can wire one sub to one channel, and one sub to the other channel. Or, you can bridge the rear two channels and wire the subs in series. Either way should result in the same power output.
    Mar 2002
    Montana
    708
    I knew it! I'm da man!
    Diplexers's Avatar
    Diplexers is offline Logarithmic Robot
    Dec 2003
    Phoenix, AZ
    41
    2,433
    4 Post(s)
    Are you just a slow learner?
    Since you've been here since 2002.
    Eclipse CD5000
    PPI... DEQ-230
    PPI... PC450 4 channel
    Eclipse DA7232 (2000 watts RMS)
    Focal PS130 Front
    Kicker RS6 6.5" comps
    Kicker R5c 5.25" midrange
  1. 2 Channel Amp
    By Hades2004 in forum Amplifiers
    Last Post: 02-17-2005, 05:33 PM
  2. 8 ohm sub w/ 4 ohm amp = 8 ohm load? Yes or No?
    By ActionJ-01-Z71 in forum Subwoofers
    Last Post: 01-20-2003, 11:35 PM
  3. Sub amp + a 5 channel amp? (one small sub up front)
    By xxldeals in forum Subwoofers
    Last Post: 01-05-2003, 12:45 AM
  4. Replies: 31
    Last Post: 12-21-2002, 04:20 PM
  5. 4 channel amp bridging help
    By Unregistered in forum Amplifiers
    Last Post: 02-18-2002, 01:18 PM
