Results 1 to 3 of 3
Reload Thread: Amp Help....(wiring)
    Jax8287's Avatar
    Jax8287 is offline Junior Member
    Jul 2004
    Tampa
    19
    Ok here is the problem, I currently purchased two JL Audio 12" W3's at 2 Ohms each. I am eventually planning on buying the JL 500.1 once i can gather up the money. Well anyways before that I was told to buy this amp that is 400 watt amp at 2 channels or 1. This is a pretty good amp actually it has 400 watts rms so i figured that i can use it temp. for the 2 JL's. The only thing was is that i do not know how to convert this amp into a single channel amp. I lost the instructions and i cannot seem to find any information about this amp online. It is a (Total Moblie Audio Amp by the way) I was told that if i wire the two subs parallel into a mono amp i can get them at 4Ohms. So i guess my question would be is how can i convert this amp to a 400 watt x 1 bridged into 4 ohms.It says that it is cablable so i am just asking for any help that i can get. Thanks
    Kyle
    sumone's Avatar
    sumone is offline CarAudio.com Veteran
    Dec 2003
    Midwest
    3,416
    Re: Amp Help....(wiring)
    1. this a 2 channel amp?
    2. you are trying to get 1 channel?
    what you are trying to do is "bridge" stereo to mono:
    when you hook up the subs, sub- goes to channel1-, sub+ goes to channel2+
    best sig of all time
    Jax8287's Avatar
    Jul 2004
    Tampa
    19
    hey thanx i appreciate that alot! now that u mentioned it... i think i recall someone saying that a while back, but yes that is what im trying to do and thank you for your time and response
    Kyle
  1. Help with wiring for amp
    By Ryknow16 in forum Wiring, Electrical and Installation Help
    Last Post: 11-06-2004, 12:58 AM
  2. wiring in another amp
    By tommybad in forum Wiring, Electrical and Installation Help
    Last Post: 05-13-2002, 10:52 AM
  3. need help with wiring Infinity sub to JBL amp
    By not yet wired in forum Wiring, Electrical and Installation Help
    Last Post: 02-07-2002, 10:13 AM
  4. wiring an Infinity sub to a JBL amp
    By wiring confusion in forum Subwoofers
    Last Post: 02-01-2002, 04:46 PM
