Results 1 to 8 of 8
Reload Thread: Bridging a four channel amp to two DVC 4ohm subs??
    hogger's Avatar
    hogger is offline Member
    May 2002
    Murray, KY
    I am a little confused how I should hook up my speakers/amp. Itll be a four channel punch with my 2 DVC 4ohm JL W3 12"s. They both RMS 250 and the amp says itll push 250x2 RMS. Would I just treat it like I was bridging two seperate amps, each to its own sub????
    chris229's Avatar
    chris229 is offline CarAudio.com Elite
    Apr 2002
    Wilm, DE
    39
    1,107
    the least a 4 channel amp can bridge to is 2 channels. Most likely 2 channels @ 4ohms. with only 2 4ohm subs you could ONLY use 1 channel of the 2 channel set up. This isn't a good idea. You either need 2 more 4ohm DVC subs, a 2 channel AMP or wire in 2ohms and use the amp UNBRIDGED and use 2 channels. It's up to you you could use 1 bridged channel but I don't think it's a good idea. What does anyone else think?
    ramos's Avatar
    Dec 2001
    Virginia
    53
    10,329
    104 Post(s)
    First question Is the amp 2ohm stable bridged to two channels ? Most are only stable at 4ohm when bridged to two channels
    5 % equipment
    90 % install
    5% beer
    chris229's Avatar
    Apr 2002
    Wilm, DE
    39
    1,107
    it would be 4ohm or else the the AMP would have been a 1ohm stable stereo type which is expensive an he would have stated that.
    ramos's Avatar
    Dec 2001
    Virginia
    53
    10,329
    104 Post(s)
    We were posting at the same time. I just wanted my fellow enthusiast to be aware of his situation.
    5 % equipment
    90 % install
    5% beer
    hogger's Avatar
    May 2002
    Murray, KY
    So should I just get a punch 500 that is just two channels instead of four??? Arrgggg!!!!!!!!!!!!!!!!!!!!!!
    chris229's Avatar
    Apr 2002
    Wilm, DE
    39
    1,107
    you can use your AMP. Just one bridged channel @ 4ohms. Which I don't advise you do. Yea either 2 more subs, 2 channel amp or use the other channels for highs
    hogger's Avatar
    May 2002
    Murray, KY
    Aight guys thanks!!!
