Results 1 to 5 of 5
Reload Thread: 3 HE2's and a Punch 800a4???
    Trixter's Avatar
    Trixter is offline Keepin it Simple
    Apr 2002
    Colorado Springs, CO
    39
    2,609
    29
    2 Post(s)
    Icon32 3 HE2's and a Punch 800a4???
    I just got three RF HE2. I am wondering if I can somehow safely hook up my RF Punch 800a4 to them. I believe this amp is only 2ohm stable so I don't think that I can bridge two channels together and run it to one set of coils while I do the same tro the other side.
    If anyone has any suggestions, please feel free.
    (Otherwise I'll just continue using the Punch 200ix to run the three but I wass looking for a little more power. If I could use the 800 for the subs I was going to use the 200 for the MB's.)
    2006 Jeep Liberty
    Adire Audio 15" Brahma running off Cadence A7hc, Clarion hu, MB Quart 6.5s and 5.25s running off old school Punch 800a4
    146+db @ 38hz with 1200w and a single 15"
    Lv = [(14630000 x R^2) / (Fb^2 x Vb)] - 1.463R
    *Vb = vol. in cu"
    **R = sq.rt. A / Pi (for square/slot port)
    JTz62's Avatar
    JTz62 is offline CarAudio.com Elite
    Jun 2002
    Jacksonville, Fla.
    44
    639
    Well, with three 4 ohm dvc's you don't have many options. The "best" load you can make for your situation would be series/parallel, ending up with 2.67 ohms mono. I'm not sure if I would run the 800a2 that low or not.....probably not. Just curious...how do you have the 200ix running them now?
    93 Cougar - under construction...again
    62 Impala....up for sale
    Trixter's Avatar
    Apr 2002
    39
    2,609
    29
    2 Post(s)
    I have the Punch 200ix wired in parallel (1.33 ohms) to the three Crunch Pros. (The ones in my profile). I have had this set up for about four years and I've had no problems. But I think I have just been lucky. I would like to see if the 800a4 would handle the load but then I might not be as lucky. If it worked, I think it would sound pretty good.
    Only one way to find out. ;-)
    2006 Jeep Liberty
    *Vb = vol. in cu"
    kyle.k's Avatar
    kyle.k is offline Member
    Apr 2002
    b.c. canada
    75
    hey i have a question for all of you.
    alright i wanna get 2 boston acoustics 12.5LF's and for the amp i wana get 2 pheonix gold titanium 800.1 amps. my question is would one of thoes bostons be able to handle 1000 watts rms??? or what other amps could i use. also if i had the gain on the amp set very low would that make it so the boston could handle it? thank you very much
    JTz62's Avatar
    Jun 2002
    Jacksonville, Fla.
    44
    639
    Boy you have been pushing your 200ix:p 1.33 mono is quite a load for that amp. If you do decide to try the 800a2 on the He's just monitor it to see if it is getting too hot. If it stays relatively cool, then I guess you will be ok. You could always put a fan or two on it if it does run a litlle warm.
