Results 1 to 11 of 11
Reload Thread: Around 1500 Watts RMS
    Zash's Avatar
    Zash is offline Kicker L7!
    Nov 2004
    Richmond, KY
    31
    79
    I need an amp that can push around 1500 watts RMS at 2 ohms. I have one 12" Kicker L7 right now *DVC 4 Ohm* and I will be purchasing another soon. I was going to use the JBL 1200.1 to power these but for some reason I am kinda doubting that decision. Would the JBL amp make them hit good in a sealed box? I plan on building a ported box later but not right away. Also, would it be back to purchase a refurbed amp *the JBL on sounddomain*? Thanks for the information guys.
    ShakinSupra's Avatar
    ShakinSupra is offline Senior VIP Member
    Dec 2003
    Washington State
    306
    Re: Around 1500 Watts RMS
    With 2 DVC 4-ohm subs, you won't be able to wire them to a 2-ohm load, your choices would be 1 or 4. The JBL is a nice amp, I wouldn't worry about the refurb as it's on SoundDomain, refurbed from the factory with warranty.
    86.5 Toyota Supra
    Nakamichi CD-45z Head
    Kicker KX600.1 Mono Amp
    Eclipse Titanium 12" SW9122 Sub
    2 cu. ft. spare tire enclosure ported @ 33hz
    Sony XPlod 75x4 4ch Amp
    ...hasn't xploded yet...
    Infinity Kappa 6.5 - 60.5cs Front
    Stinger, Tsunami, and PG Wiring.
    00 Celica GT-S
    Project Begins
    nosaj070's Avatar
    nosaj070 is offline CarAudio.com Veteran
    Feb 2003
    Chicago, IL
    32
    2,393
    Are you planning on getting another amp when you get another l7?
    Alpine CDA-7995, A/D/S 3 Series Comps, ED 8A, SoundStream Reference 604, 98 Civic Sedan
    AIM: nosaj070
    JimJ's Avatar
    JimJ is offline Tangled Up in Blue
    Jun 2004
    Hillsborough, NC
    31,706
    97 Post(s)
    PG Tantrum 1200.1
    the JBL 1200.1 will do around 1.3kW at 2, close enough...
    newer Cadence amps
    new Rockford Fosgate Power series
    Zash's Avatar
    Nov 2004
    Richmond, KY
    31
    79
    I appologize. I typed my post completely wrong. My L7's are DVC 2 ohms. I don't know why I decided to type 4...
    My plan was to buy an amp that could push around 1500 watts at 2 ohms and 750 at 4 ohms. Untill I buy the second L7, I would run the one L7 at 4 ohms. You guys think I should just stick with my original decision and get the JBL 1200.1?
    DFW40's Avatar
    DFW40 is offline CarAudio.com Veteran
    Aug 2004
    Keller, TX DFW area
    44
    2,073
    11 Post(s)
    I would stick with your original decision. 1200 or 1500 will not make that big of a difference.
    monte_carlo97's Avatar
    monte_carlo97 is offline Power Acoustik Punk
    Feb 2004
    Central Ohio
    31
    3,509
    How about a Power Acoustik A2400db amp. Very solid yet powerful amp.
    97 Monte Carlo
    H/U - Kenwood Cd\MP3(KDC-MPV6022) - Up For Sale
    The All Power Acoustik System (Removed)
    Amps(2) - Class D 3000watt (A3000DB)
    Subs(2) - 15" MOFO 2600watt(MOFO-15)
    Caps(2) - 2.4 Farad Digital Cap (PC2.4)
    EQ(1) - 7 Band Preamp Graphic Equalizer (PEQ70)
    Rears(1 Pair) - 4-Way 6x9's (XP2K694)
    Fronts(1 Pair) - 2-Way 5 1/4's (XP2K52)
    Comp Set(1 Set) - 5 1/4 Component Set (XP2K50C)
    Comp Amp(1) - 4 Channel amp 960 watts max Plasma Sphere (TS960-4)
    Monitors(1) - 7" Widescreen TFT/LCD (PT713HRS)
    DVD H/U(1) - DVD Player (PADVD610)
    Box - 9 ft^3 box tuned to 35 hz.
    New System Yet To Be Determined. Although It Will Be All MA Audio.
    Dec 2003
    Washington State
    306
    I think that the JBL1200.1 for $200 with a warranty is a steal, I might pick one up for my Ti. I've heard from a few different people that it's underrated, and it's 1-ohm stable, my brother had one with 3 12w6s, I think it was wired to 1.33 ohms or something like that, and it worked great for years until somebody stole it. I know it draws some current and has no SSF though.
    86.5 Toyota Supra
    00 Celica GT-S
    Project Begins
  9. #9
    JimJ's Avatar
    Jun 2004
    Hillsborough, NC
    31,706
    97 Post(s)
    the JBL is one ohm stable, it just doesn't gain any power from 2 ohms...around 1.3kW or something like that.
    Nice amp, just a ***** to install though.
  10. #10
    Zash's Avatar
    Nov 2004
    Richmond, KY
    31
    79
    What makes it a ***** to install?
  11. #11
    JimJ's Avatar
    Jun 2004
    Hillsborough, NC
    31,706
    97 Post(s)
    ever see the crossovers on one of the BP series? When you're upside down in a friend's trunk, with a mini-Maglite in your mouth and a screwdriver in the other, those **** tiny little setscrews and gain knobs that are barely marked get very annoying. On the other hand, my PG's, which have actual "knobs" instead of little tiny screws, are extremely easy to set and adjust.
  1. sub selection
    By DeKaL44 in forum Subwoofers
    Last Post: 12-08-2005, 03:35 AM
  2. Fuse for 1500 +120 watts
    By Geminidj2000 in forum Amplifiers
    Last Post: 12-18-2002, 01:09 PM
  3. 40 watts RMS too much for type r coaxial?
    By beachboy016 in forum Subwoofers
    Last Post: 09-28-2002, 12:45 PM
  4. 1500 Watts RMS = 30Db?
    By evilsaint in forum Wiring, Electrical and Installation Help
    Last Post: 09-14-2002, 12:03 AM
