Results 1 to 3 of 3
Reload Thread: How do i set this up?
    lowcru's Avatar
    lowcru is offline Member
    Mar 2002
    rochester, ny
    34
    45
    how would i hook an amp up to a component set in the front and 6 x 9's in the back. I have 2 sets of preamp's but the rear ones are used for the subs. Running theese speakers off the deck just isn't enough.
    Mar 2002
    S.W. Michigan
    47
    331
    Use the fronts ..
    I'm assuming you have a 4 channel amp.? If you have a 4 channel amp just split your rca's coming from the head unit with y adapters (1female - 2 male) send the 2 right channel rca's to the front and rear rca inputs of the amp. and the same with the left. If you only have a 2 channel amp for these 4 speakers then run the left component in parallel with the left 6x9 and the same with the right channel. You won't lose power that way because it would create a 2 ohm stereo load which pretty much all amps on the market today can handle. By the way, I agree with you on the head unit powr...I havent' used a head to power a speaker since the late 80's. I hope this helps man. Later
    Larry
    beastyle's Avatar
    beastyle is offline Senior VIP Member
    Mar 2002
    Holland, Amsterdam
    39
    272
    www.altavista.com, lookup word = "TRIMODE"
    just do so, u'll find out that you already have all the power you need to power all your speakers straight from the amp but still separated at a later piont
    Humanity my mirror,
    Madness what I see
