Results 1 to 11 of 11
Reload Thread: Amp not turning on
    orioles26's Avatar
    orioles26 is offline Senior VIP Member
    Jul 2004
    Severna park, Maryland
    243
    Amp not turning on
    I had to change the wiring on my subs and add speakers. Now that i did this the amp will power up sometimes but most of the time it wont even turn on. It will usually flicker on when i start the car but sometimes it will never come on or it will play for a little while while im driving then cut out again. What could be the problem because all of the wires seem to be connected and the fuse is not blown?
    bonesninja's Avatar
    bonesninja is offline CarAudio.com Veteran
    Oct 2004
    Lima, Ohio
    45
    14,803
    5 Post(s)
    Re: Amp not turning on
    sounds like a loose wire i would check your remote and power wire again then make sure the fuses are fully seated.
    Quote Originally Posted by chase007 View Post
    if u need a box...I'l taked 3 years of shop class so i know what im doing.
    after i explained to him there's more to a proper box than boards and glue and he should practice before trying to sell boxes to others
    yes personaly if it was some one elce that just starting making boxes but i'v taken shop for 3 years now...Making a lil box is nothing i don't need to pratice on a box to get it right i learned alot of stuff from 1 box and i can fix that in my next box
    after i told him that customers would care about the looks of the box
    if u want some thing that looks pretty why don't u find a black guy with a big d*ck.
    orioles26's Avatar
    Jul 2004
    243
    Thats what i thought to but they all seem to be connected and i looked at the fuse and it looks normal.
    Sleeklsc's Avatar
    Sleeklsc is offline CarAudio.com Veteran
    Jan 2004
    il
    6,938
    856 Post(s)
    check the remote behind the h/u...did you wirie them corredtly?what subs and amp are you using? ohm's would be good to
    Ref's:1. Midwestcustoms 1.5. Desertheat 2. Mjbailey 3. Terryracing86 4. Sickmint79 5. Untouchable11 6. mattj 7. Ssweet96 8. Kool9accord 9.Kristinspapi10. Kmhogan224 11. Alpine3612 -x3- 12. Vectork39 13. Livinlife 14.Chriscivic 15. Violentraptor 16. Ricky616 17. Bassaddictj 18.orioles26 19.Khail19 20. jak3th3snak311 21. Myjaja 22. Springy101 x2 23. Ali1 24. Privatepastry 25. Plus about 10+ more..
    orioles26's Avatar
    Jul 2004
    243
    Two rockford fosgate p3 dual 4 ohms wired to 1 ohm on a hifonics 100d amp. The wiring to the head unit is fine because i did not change that when i redid the wiring of the subs. The only thing i changed was the wiring on the subs.
    orioles26's Avatar
    Jul 2004
    243
    IF the amp is not even turning on is it possible i screwed up the wirnig and messed up the amp?
    Bartak1's Avatar
    Bartak1 is offline CarAudio.com Elite
    Oct 2004
    Nebraska
    593
    Maybe the remote wire got pinched. My friend had that happen a few times. Run a wire from the battery to the amps turn on and see if it turns on, if it does I would just put a new wire in for the turn on and see if that work. Just a thought
    Eclipse CD8053
    Arc Audio XXK4050
    Rainbow ProVandis ran active
    Arc Audio XXK1500
    (2) SI Gen2. Mags
    Refs: FoxPro5, MastaFlex, LeX, Valant_94gt, eBay account too.
    orioles26's Avatar
    Jul 2004
    243
    Are you saying to only run the wir from the battery to the amp and take off the rest off the wires?
  9. #9
    misterio's Avatar
    misterio is offline Senior VIP Member
    Feb 2004
    texas
    227
    no he is saying run a wire from the battery's positive terminal to your amps remote input instead of the one coming from your cd player to see if that is the problem
    1995 Eagle Talon EsI
    H/U: Panasonic Mp3 player
    Amp: Hifonics Brutus 1500
    Capacitor: Audiobahn 5 farad
    Sub: 1 12" XXX at 1 ohm
  10. #10
    Bartak1's Avatar
    Oct 2004
    Nebraska
    593
    Yeah what misterio said. Leave all the other wires connected
    Eclipse CD8053
    Arc Audio XXK4050
    Arc Audio XXK1500
    (2) SI Gen2. Mags
  11. #11
    denim's Avatar
    denim is offline SSAudio.com
    Oct 2002
    SSA HQ East
    40
    29,117
    15
    66 Post(s)
    917 Post(s)
    Off topic, Orioles26 I live fairly near to you and drive to DC every day for work
    CarAudio.com mod(original)
  1. New Amp Install
    By MPNX2 in forum Wiring, Electrical and Installation Help
    Last Post: 01-04-2003, 01:16 AM
  2. Replies: 1
    Last Post: 01-03-2003, 06:23 PM
  3. question about amp with external fuse
    By treefitty in forum Wiring, Electrical and Installation Help
    Last Post: 01-02-2003, 07:40 AM
  4. Replies: 0
    Last Post: 07-28-2002, 05:01 AM
  5. decent amp?
    By drocca in forum Amplifiers
    Last Post: 04-19-2002, 12:55 PM
