Results 1 to 4 of 4
Reload Thread: Amp gains
    FromKrypton's Avatar
    FromKrypton is offline Junior Member
    May 2002
    Montreal
    32
    23
    Amp gains
    I have a 4 channel MTX amp that I'm using to power my highs. The problem is that the back 2 channels are way too loud, be distortion freee. I've already set the gain to zero and they are still louder than the front 2 channels. The front is currently at half gain and the back is off. I'd like to lower the back to even things out but the amp just won't be quiet. It's at the point where my highs are drowning out my subs. Could the amp gains be broken? Any ideas? Doesn't happen that often that an amp puts out more than is wanted.
    Thanks for any tips you might have.
    wesleysh's Avatar
    wesleysh is offline Senior VIP w/large Member
    Apr 2002
    Michigan
    795
    It could be the sensitivity of your speakers. The back speakers probably use power more effeciently than your fronts. Speaker brands such as Pioneer and Blaupunkt can get very loud without a lot of power. What kind and sizes of speakers do you have? Also be sure that you didn't wire the speakers differently than the fronts, which could make the amp put out different amounts of power.
    I'm never wrong, EVER! Just ask me.
    May 2002
    Montreal
    32
    23
    I have my stock 6X9's in the back, wired exactly the same way as in the front.
    taylor's Avatar
    taylor is offline THUNDER TUNES IS A FLAMER
    Jan 2002
    can
    30
    1,509
    2 Post(s)
    switch channels then, iknow some amps have a louder front channel so your front stage is better...
