Results 1 to 12 of 12
Reload Thread: hooking up a 15" solo square to the bx1500d
    dr.beats's Avatar
    dr.beats is offline Bumpin'and Pumpin'
    Aug 2004
    Tulsa
    50
    well, i got my brutus back today, and i want to hook it up.
    (it was being repaired) unfortunately, i have fried this amp twice. i was told it was because i was using a switch for the remote lead, instead of the h.u. remote lead. does this sound right? can it fry an amp? i've had it running that way with all my other systems and it has never fried anything. the brutus is a digital amp though. i've never had a dig. b4.
    i'm going to running a 15" solobaric dvc 2-ohm. i run that parallel and get 1 ohm right? i did run the remote from the h.u. to the other amps in the back, so it shouldn't fry the brutus now right? any help would be sweet. thanks
    NofriendsSpongr's Avatar
    NofriendsSpongr is offline Senior VIP Member
    Sep 2004
    Murrieta ca
    258
    Re: hooking up a 15" solo square to the bx1500d
    how many amps are you hooking up to your HU? You might want to look into a relay for them if you have a few. Its cheap insurance and im sure many people dont have one for multiple amp systems, but for a few bux it COULD save you a huge headache of being w\out a HU. Im not sure about a switch for a turn on lead being the cause for the amp to crap out....maybe it was too high voltage or getting spikes or somthing? Who knows. Good luck and yeah, dVc2ohm subs in parallel make it run at 1ohm. Should be pretty **** loud.
    dr.beats's Avatar
    Aug 2004
    Tulsa
    50
    well, i have a profile 600w, running my mids ands highs, and right now a profile 1200w running a different 15" solobaric. i'm pretty sure the hifonics amp will win between the two. my remote lead does have a max amperage load, but i can't remember what it is. i have a sony cdx-l510x. i think it's like .6 amps. i'm not sure how to figure the draw off each amp. any help, again? thanks
    Sep 2004
    Murrieta ca
    258
    Not really sure how to figure that out. Hopefully someone else can shed some light on it.
    dr.beats's Avatar
    Aug 2004
    Tulsa
    50
    can anyone help me with this?
    jtomsic's Avatar
    jtomsic is offline CarAudio.com Veteran
    Jan 2004
    Washington, Pennsylvania, United States
    32
    5,209
    19
    43 Post(s)
    whats ur gain and bass boost set to?
    Headunit: Pioneer AVH-P2300DVD
    Subwoofers: (2)15" RE Audio XXX(05 model)
    Sub Box: Undecided..
    Sub Amp: Crescendo bc3500
    Speakers: 6.5" RE Audio XXX Components(soon to be 2nd pair in kick panels)
    Speaker Amp: Hifonics HFi100.2(for now...)
    Wiring: 2 runs of 1/0 throughout, XS Power battery in trunk,big 3 done, 270a alt, 1/0 accesories throughout
    Deadner: 75sq ft AT 60mil, 20sq ft Alphadamp
    Security: Crimestopper 2way alarm/remote start
    Phiber Optik's Avatar
    Phiber Optik is offline Senior VIP Member
    Mar 2004
    BC Canada
    374
    These are your options for wiring DVC 2ohm subs
    Parralel will be 0.5ohm
    Series-Parralel will be 2ohm
    Series will be 8ohm
    Dual Parralel will be 1ohm x 2
    Dual Series will be 4ohm x 2
    Thanx, Jon
    Alpine D105 & H701
    DLS A4 + A6
    RE XXX's
    Boston Acoustics speakers
    ighettoboyi's Avatar
    ighettoboyi is offline Shot Caller
    Mar 2004
    mean streets of OC
    2,702
    I have two amps no relays i just use the same power line...its a tiny wire you can fit both in the terminal from which ever amp youre leading the second from
    DTM HATER
  9. #9
    jtomsic's Avatar
    Jan 2004
    32
    5,209
    19
    43 Post(s)
    15L7 will wang off that amp, make sure u get the dual 4 ohm and wire it like #1 to get 1000watts out of that amp.
    Wiring Wizard
    just seen u got the dual 2 ohm.. dont think you'll be able to wire it to 2 ohms. might wanna keep ur gain low if u wire to 1 ohm
  10. #10
    dr.beats's Avatar
    Aug 2004
    Tulsa
    50
    don't have the brutus hooked up yet, tried today. somehow, without my hu on, i get 1.3 volts to all my components remote leads...(x-over,amps). that's where i get confused. why is there any voltage at all with nothing on? like i said in my 1st post, i have a profile ca1200 hooked up to one 15" right now, and have never had a problem with operation. but, with this hifonics amp, when i hook the power-ground up, the amp lights come on and it starts to make a high pitched squeal. i mean maybe it's something stupid i overlooked. i don't know, i've never had a dig. amp before. could it be that i have the power and backup to my hu wired together? that's the only other thing i can think of that's rigged. if anyone can help me out, please do!!! i guess the dr. needs to go back to school!! gotta go fillet my catfish, peace
  11. #11
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,300
    Quote Originally Posted by dr.beats
    How is the Hifonics digital?? And please don't say because it's a class D (refer to sig)
    Do you mean the 12V constant (yellow) and Accessory (red) wired together?? If so, what do you have them wired to (a constant source or ignition switched source)??
  12. #12
    dr.beats's Avatar
    Aug 2004
    Tulsa
    50
    i don't know wtf i've been saying it's digital. i think i may have been thinking of someone elses amp. the constant and accessory are wired together to a constant source. i have it like that so i can turn it on without a key. the wire goes straight (well, it's fused) to the battery.
  1. square inches of a ED SP 15"??
    By bumpin_blazer in forum Subwoofers
    Last Post: 01-25-2003, 01:28 PM
  2. 99' solo barics vs element designs
    By mgaidica in forum Subwoofers
    Last Post: 01-18-2003, 11:08 AM
  3. L7 15" or a Shocker 15"??
    Last Post: 01-08-2003, 02:38 AM
  4. L5 15" Square Kicker
    By lcpunk69 in forum Subwoofers
    Last Post: 09-08-2002, 11:32 PM
  5. L5 15" square kicker & MTX6500D
    Last Post: 09-06-2002, 06:41 AM
