Results 1 to 8 of 8
Reload Thread: JL 500/1 Amp Settings?
    chris0247's Avatar
    chris0247 is offline Junior Member
    May 2004
    Albany, NY
    Hi guys...
    I'm pushing a JL 12W6v2 in the ProWedge sealed box with a JL 500.1 Amp... also have 4 Boston Pro 6.5's running off an Alpine 9833 if that matters at all...
    Anyways, the amp has so many settings I don't know where to begin. Can anyone recommend ideal settings for my sub amp for this setup? Also any settings on the deck for the sub or anything too? Any help would be appreciated!
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,302
    Re: JL 500/1 Amp Settings?
    Please tell me your not running 4 component sets off of your headunit's amp.....................
    chris0247's Avatar
    May 2004
    Albany, NY
    Unfortunetaly, I am, until I save up for a separate amp for them...
    bump
    HAVINGFUN's Avatar
    HAVINGFUN is offline CarAudio.com Veteran
    Aug 2004
    Keller, TX DFW area
    2,030
    17
    OK
    Turn signal sensing off.
    Turn off the infrasonic filter.
    set the Amp LP filter mode/slope whcih has either 12 or 24db to 24db.
    set the LP filter to 70 or 80 hz
    set "Input Voltage" to low
    set the input sensitivity as desired and or recommended
    Do not worry about the PreAmp output section
    Do you have the remote bass Knob for this amp? If you use it set the "Q" to 1.1
    set the center freq to 40hz and using the knob will be you "DB" boost. This enables you to adjust the sub's volume with a quick touch of the knob. Be careful with this because it is a 15db boost which could clip the signal and damage your sub. If you do not have the remote knob I would turn the bass Eq off.
    Let me know how these settings work for you
    squeak9798's Avatar
    Jun 2004
    USA
    26,302
    Quote Originally Posted by HAVINGFUN
    This is going to be completely install/setup dependent. Just play with it till you find the setting that sounds best. You may need to go lower, like 50hz or 60hz for your particular setup.
    chris0247's Avatar
    May 2004
    Albany, NY
    So I tried some of your suggestions and it sounded good until the Low ohm light came on the amp... sorry I don't know much about these things, what does it mean and what could cause it?
    HAVINGFUN's Avatar
    Aug 2004
    Keller, TX DFW area
    2,030
    17
    That amp is designed to run subs between 1.5-4 ohms. The ohms as your amps sees it depends on what the ohms of your sub(s) are and how you have them wired. What subs do you have: are they dual voicecoil 4ohm etc or dual 2 ohm??
    HAVINGFUN's Avatar
    Aug 2004
    Keller, TX DFW area
    2,030
    17
    Those subs come in dual 4 ohm only. You probably have them running total @1ohm which is rather low for that amp and that is why the light is coming on. You need to first wire the subs like diagram "A" on page 3 of the link below which is called series.
    The output of the amp has two positives and two negatives (see the second link). You will run one set of speaker wire from the + and - of the amp to one sub then you just do the same thing and run the other set of speaker wire from the other + and - on the amp to the other sub (just like hooking up two speakers on a home stereo). This will give you a 4ohm load which is within the amps range to produce full power.
    http://jlaudio.com/subwoofers/pdfs/W6v2_MAN.pdf
    http://jlaudio.com/amps/pdfs/500_1.pdf
  1. JL AUDIO 500/1 Questions an Comments
    By Atvnut2065 in forum Amplifiers
    Last Post: 09-20-2004, 03:50 PM
  2. Alpine mrd m500 vs. Jl audio 500/1
    By boominbass in forum Amplifiers
    Last Post: 01-16-2003, 01:10 AM
  3. Which amp for 2 JL 10's with 4 OHM load?
    By beachboy016 in forum Amplifiers
    Last Post: 09-15-2002, 09:27 PM
  4. JL box or cutom box and amp
    By downsouthstud in forum Subwoofers
    Last Post: 04-05-2002, 12:30 AM
