Results 1 to 15 of 15
Reload Thread: Full Range Class D amplifier
    Cathlock's Avatar
    Cathlock is offline Member
    Jan 2004
    Utah
    46
    43
    Question?
    What is a "Full Range" Class D amplifer and what is the best aplication for it?
    ANeonRider's Avatar
    ANeonRider is offline teamSSAudio.com
    Aug 2004
    Saskatoon, SK, CAN
    36
    2,811
    Re: Full Range Class D amplifier
    A full-range Class D is called a Class T I believe. Best application is well, to run at full-range.
    Cathlock's Avatar
    Jan 2004
    Utah
    46
    43
    OK I am new at this what do you mean run at full range. I thought class D amps were for subwoofers. Does this mean you run your mids and high with kind of amp? Soryy if I sound like an idiot...
    ANeonRider's Avatar
    Aug 2004
    Saskatoon, SK, CAN
    36
    2,811
    full-range = full range of sound 20 hz - 20khz.
    The full-range Class D is not a Class D, but a Class T. It uses digital circuits to amplify more efficiently.
    EFFENDI's Avatar
    EFFENDI is offline CarAudio.com Veteran
    Jul 2004
    Los Angeles, CA
    34
    2,429
    Best application for them is in a situation where you want the least amount of current draw/highest efficiency plus the wow factor of having a highly efficient full-range amp. They are commonly known as Class T, or Tripath, as Tripath Technologies were the first to pioneer the full range Class D amp, and to produce the technology (Digital ICs) for it. They are true digital amps, unlike the misconception that Class D amps are digital. I believe that the first true Class T amps were the Blaupunkt PA series, released in 2002 (IIRC). They are amazingly small amps. Amazingly expensive as well.
    References: rattlebrain, dabossofbosses, sampson, Netherland24, cjjackson85,cheeseburger85 abcheng, bumpin_beamer, BigRick31, AudioPLaya368
    Cathlock's Avatar
    Jan 2004
    Utah
    46
    43
    Thank you.
    I notice Eclipse has a new "Full Range" class D amp on there web site.
    Thanks again.
    3.5Max6spd's Avatar
    3.5Max6spd is offline yo mama no wear no draws
    Jun 2004
    Dirty Jersey
    40
    3,767
    Quote Originally Posted by EFFENDI
    My Arc 1500D is a class T and I recall it being released prior to 2002- actually theres a documented review of it on 6/01- plays 20hz- 20khz
    Not saying it was the first....but that date seems off perhaps
    rainbow....homemade sounds best
    DYNAUDIO E S O T E C....Mobile Fidelity
    Panasonic Vacuum Tube
    TRU Technology SSLD6
    TRU Technology STEEL S44 & S500
    DYNAUDIO Esotec System 362
    Dynaudio MW190 12" (x2) IB
    Stinger Expert/Esoteric Audio Isopath/Cascade
    Refs-NE14MX , jdavis37, anarchy57, mj121983 , ll kadoy ll, TheBigDu , cdj ,Kawasaki STX-R ,Fdeez ,Ksin291,meangta, lil azn 06, HAVINGFUN, Loud1500, Flipx99 , jjunior887 ,mastarecoil ,slammed , T3mpest ,westerbud, Airman21, bconn587, LexNBimmer,namike, alphakenny1, HebrewHammer,chadillac,remiserg, purerx7tt, OCURIEL, coneO,Igno,Iluvzmzm,godzukiduce,CrazedCat,skylar11 2,
    bose301s,qwertvt
    jlaine's Avatar
    jlaine is offline Vaporware
    Apr 2002
    Morris, MN
    2,607
    Quote Originally Posted by ANeonRider
    Incorrect
    Full range class D amplifiers have been out long before the Tripath chip was even stable to 100w, let alone the current 1kW + you see from them these days.
    The ONLY reason class "D" has been associated with 'subwoofer amplifiers' is because of the way the current market designs them.
    Switching frequency of the supply for class D's is the limitation of the high end of the bandwidth. It's cheaper for manufacturers to build a slower switching supply and put it in their 'subwoofer' amplifier than to build a higher switching supply and have a 'full range capable' unit.
    Class T is NOT a class D full range amplifier. It never has been, it never will be.
  9. #9
    jlaine's Avatar
    Apr 2002
    Morris, MN
    2,607
    The amplifier stage in a Tripath unit still uses analog components. Therefore digital is simply just a misnomer like it is for the class D.
    Those "high output" tripath models out today use a tripath driver, similar to this one here - and still use output transistors to generate all that power potential.
  10. #10
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,300
    Full range Class D's is hardly a new concept.................
  11. #11
    jlaine's Avatar
    Apr 2002
    Morris, MN
    2,607
    Quote Originally Posted by squeak9798
    And I'm positive I've repeated myself on this very subject at least once...
    I don't understand how this falsehood keeps getting regenerated.
    Backtracking and actually researching shows the two topologies are not the same and that full range class D's have been around since the '70s.
  12. #12
    ANeonRider's Avatar
    Aug 2004
    Saskatoon, SK, CAN
    36
    2,811
    Well looks like I was confused, thanks for correcting me.
  13. #13
    denim's Avatar
    denim is offline SSAudio.com
    Oct 2002
    SSA HQ East
    40
    29,121
    15
    68 Post(s)
    917 Post(s)
    Alpine, US Amps, and some other company I am forgetting make class "T" amps
    Xtant has that little full range class "D" amp that does 100w or something
    CarAudio.com mod(original)
  14. #14
    imready77's Avatar
    imready77 is offline The Beast
    Dec 2002
    Home of the Pro Football Hall of Fame
    35
    702
    Lanzar has a full range class D amp too. Do they sound the same as a A/B does?
    I'm seein' more than the average human eyes can see
    I live in darkness God please shine light on me
    In poverty is where I sleep not closing these,
    Ghetto eyes, ghetto eyes ah mine
    The only scenery I see that's fascinating to Fly
    The shinin' sun, moon, clouds and the stars in the sky
    Some heavy heavenly medicated treat me for my,
    Ghetto eyes, ghetto eyes, yeah yeah
    So many visions put incisions in my stizate ah mind
    But Fly gon' take it like a man doin' time for crime
    Get behind me, and Fly will lead the line
    Using my ghetto eyes, ghetto eyes, yeah yeah
    Playa Fly-Ghetto Eyes
  15. #15
    EFFENDI's Avatar
    Jul 2004
    Los Angeles, CA
    34
    2,429
    Yeah that CD-case sized one made by Xtant. (Waste of money in my opinion). Yes I was off with that date, based on some quick googling, it looks like the first Tripath chips were starting to be integrated into car amplifiers around 1998. The TA2022 which is used in car audio applications consists of three main operational blocks, the signal processor, MOSFET driver, and power MOSFETs. You are absolutely right, I neglected to mention that the only digital component is the signal processor, which operates from a 5V CMOS. Of course the power amplification components are still analog. More info at www.tripath.com/audio.htm
    Now if they could only increase power output levels, and lower costs, we'd all be swithing to Class T amplifiers.
  1. Kicker DX350 350W Class D Mono Amplifier
    By chaz7979 in forum Amplifiers
    Last Post: 06-13-2002, 12:24 AM
  2. are mid ranges important for full range speaker?
    By crzybob77 in forum General Discussion
    Last Post: 04-30-2002, 06:10 PM
  3. Can I and should I amplify cheap full range speakers?
    By JonBoy in forum General Discussion
    Last Post: 04-16-2002, 04:20 PM
  4. Replies: 3
    Last Post: 02-06-2002, 03:23 PM
  5. Amp Class Question
    By CheapPyramidStuff in forum Amplifiers
    Last Post: 01-10-2002, 07:12 PM
