Results 1 to 3 of 3
Reload Thread: confused on what amp id need
    hky001's Avatar
    hky001 is offline Junior Member
    Aug 2004
    cali
    i havent decided for sure what sub i want to get yet, but im still confused as to what amp id need to get. for example if i find a sub that is rated at 250 RMS then i am looking for an amp that puts out 250W RMS. ive been looking on ebay and when i find an amp i like, i cant seem to find out the wattage or whatever. for example, this amp http://cgi.ebay.com/ws/eBayISAPI.dll...714310899&rd=1
    and what does this mean:
    Output Power Rating
    4 Ohm Load - 150 x 1
    2 Ohm Load - 250 x 1
    1 Ohm Load - 500 x
    thanks a lot
    Norcalracer283's Avatar
    Norcalracer283 is offline 4 more years of hell....
    Jun 2004
    Danville, Ca
    1,800
    Re: confused on what amp id need
    Ok, that is your RMS power...which is the important wattage rating. Max means nothing. As for ohm loads... depending on what sub you get and how you wire determines what ohm load you get out of the amp. Someone can link you to the wiring thread if that helps. If your looking to put 250 to a sub...hmmm i dont want to advise you on a sub. But i will tell you now, that amp is good. Very versatile, 1 ohm stable.
    1995 Nissan Maxima
    Alpine 9847
    CDT CL-61A components
    Alpine Type R 2 way Coax's
    2 10" Alpine SWR1041D
    Audiobahn A8002T
    Hifonics TX4405
    Edead v1
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,300
    Don't buy an amp yet.....wait till you know for sure what sub you are going to buy. You may buy a sub that won't work with well with the amp you previously purchased or you could be limiting your sub selection to only subs that will work with your amp instead of buying an amp to match the sub you want (maybe you can't get the power out of it you want due to the ohm loads, etc etc).
    So, IMO wait till you know which sub before you buy an amp.
  1. Amp Fuse/Gain Help
    By fury in forum Wiring, Electrical and Installation Help
    Last Post: 08-08-2004, 09:12 PM
  2. Blowing Fuses. AAAAGGGGH!!
    By c_hayhurst in forum Amplifiers
    Last Post: 07-29-2004, 07:18 PM
  3. Directed 1100D Amp is over heating?
    By Tupac2413 in forum Amplifiers
    Last Post: 07-21-2004, 06:05 PM
  4. HELP!! no output from NEW concept amp
    By bobo244 in forum Wiring, Electrical and Installation Help
    Last Post: 02-08-2004, 02:28 AM
