Results 1 to 3 of 3
Reload Thread: Power Acoustik PA2-1600
    fresh's Avatar
    fresh is offline Member
    Apr 2003
    Vancouver, BC
    65
    do you guys know anything about this amp?
    I would like to get it and power 2 10" Alpine Type-R subs (dual 4 ohm). What do you guys think?
    I have attached the specs below for your reference.
    thanks
    Power Acoustik PA2-1600 2 Ch 1600 Watt Power Series Amplifier
    Full Mosfet Power Supply
    PWM Circuitry
    Full Selectable Crossover Hi/Full/Low
    Three Way Protection Circuit
    2ohm Stable Stereo
    Tri-Mode Capable
    Variable Low Pass 40Hz-250Hz
    Variable Hi Pass 40Hz-250Hz
    18dB Bass Boost @ 45Hz.
    Frequency Response: 20Hz to 20Khz
    S/N Ratio:97 db
    THD: 0.02%
    System Distress Indicator
    High/Low Level inputs With Floating Ground
    4 Gauge Power/Ground Connection
    Gold plated RCA Connectors
    Line output
    4 Ohm Rms : 310W x 2CH
    2 Ohm Rms : 370W x 2CH
    Mono Rms : 740W
    Briged Max : 1600W
    Dimensions(WXHXL)mm : 22 x 11.25 x 2.25
    fresh's Avatar
    Apr 2003
    Vancouver, BC
    65
    Re: Power Acoustik PA2-1600
    anybody???
    BugMan53's Avatar
    BugMan53 is offline Junior Member
    Aug 2003
    North carolina
    27
    19
    I have one and it does very good for the price. Its is considered a lower end amp. I’ve had mine in my Daily driver for a long time and it works great. I personally don’t like the crossovers on the amp so I am using External crossovers. It probably put out closer to 300-320rms at 2 ohms i would guess B\c that are a little over rated.
    Pioneer DEH-P4400
    Pioneer TS-w304dvc's
    old skool sound stream amp reference 604
    Power acustik ov2-1600
    JBL tweeters
    Pioneer Mids
  1. Power Acoustik A3000DB
    By TooLowTooGo in forum Amplifiers
    Last Post: 07-29-2004, 06:16 PM
  2. Power Acoustik PA2-520
    By hifi_homeboy in forum Amplifiers
    Last Post: 04-18-2004, 03:23 AM
  3. opinion of power acoustik mofo 12" subs
    By footballfreak16 in forum Subwoofers
    Last Post: 01-29-2004, 09:14 PM
  4. power acoustik?
    By forgotten_candy in forum Amplifiers
    Last Post: 10-28-2003, 09:22 AM
