+ Reply to Thread
Results 1 to 12 of 12
Reload Thread: PRV Audio 3500.1 going into protect
    evilmonstertruk's Avatar
    evilmonstertruk is online now Premium Member evilmonstertruk is a Supporting Member of the forum!
    Sep 2014
    Virginia
    1,133
    3 Post(s)
    336 Post(s)
    Woke up today. Got it in the car. No bass!!! Went and looked and my prv was in protect. So I obviously stopped at the gas station to troubleshoot. And no matter what I did couldn't get it. Its a year and week since I bought it. And wouldn't you know it. Only a year warranty. What are the odds! Opened it up and only saw one possible burnt area. The little red square. It may be the protection itself but I have no idea.
    Any suggestions?
    Thanks
    Sent from my SM-N950U using Tapatalk
    youdoofus's Avatar
    youdoofus is online now Well, hello Mr.Fancypants
    Dec 2014
    the void of space called the midwest
    2,351
    6 Post(s)
    1036 Post(s)
    Re: PRV Audio 3500.1 going into protect
    that thing is tiny!!
    2002 Honda Accord sedan V6 (automatic slushbox)
    2 Rockford p3 12s (dual 2 ohm)
    Pioneer AVH-2300NEX
    2 PPI PC275's running 1 sub each atm, waiting to put the SQ 2200.1 back in and add the PhoenixGold Elite.4 once my electrical is up to snuff
    Front stage:PRV Audio 6MB200 6.5 and Massive Audio CT2 tweeters
    Rear speakers: stock
    I just added 5 SoundQubed stickers, and despite having no equipment upgrades, it added 76 DB!!!
    Sep 2014
    Virginia
    1,133
    3 Post(s)
    336 Post(s)
    PRV seems to be willing to cover it under warranty. Or at least fix it for a fee
  4. Likes SUPER_YOCOM, Hertz Mafia liked this post
  5. #4
    AddicLee's Avatar
    AddicLee is offline Junior Member
    Apr 2018
    US
    13
    4 Post(s)
    Looks good
  6. #5
    audiobaun's Avatar
    audiobaun is offline CarAudio.com Veteran
    Jun 2011
    Tx
    9,452
    27 Post(s)
    2202 Post(s)
    Id check your subs as well with an Ohm Meter to see if you have any issues with any Coil. Wrong Ohm load on a bad coil will send an amp into protect quickly/ instantly. Check your subs. 9xs out of ten everyone thinks automatically that hen an amp goes into protect that each coil on ea.sub are just fine
    2)American Bass VFL Mini Hybrid [email protected] Ea 4)American Bass XFL DVC 4ohm [email protected] Ft [email protected] CDT 6,5 HD6 Briax.,CDT CL60,CDT 25 tweets,Kicker KS25 tweets Autotek Mean Machine [email protected],Autotek BTX [email protected] AlterStarts Alt 255A/Dallas,Tx,2)Orileys Super Start AGM batts(1more coming)Cadence CCA 0ga on Big 6,AudioTechnix 0ga CCA Kicker Kq9 Eq,Eclipse CD3000(lookingfor upgrade)StingerPro Distro,3)XS Scorpian 8in Scroll Fans 1998 3dr Xcab Chevy(under construction,but operational)
  7. #6
    Sep 2014
    Virginia
    1,133
    3 Post(s)
    336 Post(s)
    Quote Originally Posted by audiobaun View Post
    Sub is good. Have it hooked up temporary to the 5/6 channel on my Audiocontrol. Couldn't go a hour and tens mins without bass. The amp goes into protect without the speakers or the RCAs hooked up.
  8. #7
    hispls's Avatar
    hispls is online now CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    10,264
    15
    39 Post(s)
    4236 Post(s)
    Pretty much any component on that amp could have failed and not be visibly burnt. This sort of thing is why lowest cost per watt isn't the end-all-be-all criteria for choosing an amplifier.
  9. #8
    Sep 2014
    Virginia
    1,133
    3 Post(s)
    336 Post(s)
    Quote Originally Posted by hispls View Post
    True. But all electronics have this risk. I have super high end stuff go bad and cheap **** last forever. And the other way around. I have a Kenwood two channel home theater amp from the 80s going strong in my theater room.
  10. #9
    hispls's Avatar
    Sep 2009
    10,264
    15
    39 Post(s)
    4236 Post(s)
    Quote Originally Posted by evilmonstertruk View Post
    And all vegetables contain some arsenic. The point being the rate of failure of cheap stuff, and of course Brazilian amps are notoriously unreliable.
  11. #10
    Sep 2014
    Virginia
    1,133
    3 Post(s)
    336 Post(s)
    Either way. I think I'm the only one that bought one of these prvs. There discontinued now. Hopefully they fix it under warranty.
    Any idea how much it might cost to fix?
  12. #11
    hispls's Avatar
    Sep 2009
    10,264
    15
    39 Post(s)
    4236 Post(s)
    That's the other thing with Brazilian amps is a lot of shops refuse to repair them (because they're unreliable) and parts can be difficult or impossible to find. The Amp Lab up in Maine does some Brazilians, not sure if they mess with PRV
  13. #12
    Sep 2014
    Virginia
    1,133
    3 Post(s)
    336 Post(s)
    Ok cool. I'll see what PRV says then look around. I called one of the places and they said they didn't.
    I have my Massive Audio 4000.2 which is a nice amp. Hooked it up today and didn't lose a thing. I know that one massive audio got killed in the Dyno, I think this one is different. But hard to say
+ Reply to Thread
  1. Wanted to buy aq/sq 3500 dc3.5k cresendo 3500 sundown 3500
    By Jason19 in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 04-11-2014, 08:09 PM
  2. Crescendo bc 3500/ dc 3500/sundown 3500
    By kykendall54 in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 03-21-2013, 01:17 AM
  3. WTB sundown 3500, or dc 3500 or audio que 3500 or higher
    By dwhite in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 02-29-2012, 11:45 PM
  4. WTB sundown 3500, or dc 3500 or audio que 3500 or higher
    Last Post: 02-27-2012, 09:17 PM
