+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 16 to 28 of 28
Reload Thread: Do I need an amp for my speakers?
  1. #16
    BOOMINGRANDPA's Avatar
    BOOMINGRANDPA is online now CHEAP A/F
    Jan 2017
    NC
    6,744
    17
    30 Post(s)
    2692 Post(s)
    Re: Do I need an amp for my speakers?
    Quote Originally Posted by 2xarchonxx View Post
    Right on, ill check the classifieds here, I didn't even think about that. Class D amps are good to use on speakers? I heard that they distort on higher frequencies and should only be used on subs.
    Also, I might need to use the speaker level inputs from the HU because getting more RCA cables through the dash of that bus might not be possible. Do all amps allow speaker level inputs, or just some? It's the high level input connector on the amp right?
    rcas are better but most amps do have hi level input just look at amp good before u buy..
    KENWOOD X301 HU, PRECISION POWER Phantom 1000, FU 750 12, 2.1cfad ported, soundqubed 6.5" coax/doors, hp & lp xover on hu, AGM starting batt...
    2 ohms rule
  2. #17
    2xarchonxx's Avatar
    2xarchonxx is offline Junior Member
    Jun 2018
    Louisville ky
    11 Post(s)
    Quote Originally Posted by LosIsATool View Post
    That is BS.
    So I should actually look for class D?
  3. #18
    LosIsATool's Avatar
    LosIsATool is online now CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    18,380
    110 Post(s)
    7897 Post(s)
    It doesn’t matter. Class D is more efficient and smaller. But a junk class D will be just as bad as A/B.
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    Zapco ST-4X SQ, ST-1000XMii
    IDQ12v4 1.8cu sealed
    Alpine SPX Pro ring radiators
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
  4. #19
    youdoofus's Avatar
    youdoofus is online now Well, hello Mr.Fancypants
    Dec 2014
    the void of space called the midwest
    2,355
    6 Post(s)
    1040 Post(s)
    That is BS.
    i think what he is referring to is the old school class d amps that were incapable of playing higher than, what weas it... something like 200 hz?
    2002 Honda Accord sedan V6 (automatic slushbox)
    2 Rockford p3 12s (dual 2 ohm)
    Pioneer AVH-2300NEX
    2 PPI PC275's running 1 sub each atm, waiting to put the SQ 2200.1 back in and add the PhoenixGold Elite.4 once my electrical is up to snuff
    Front stage:PRV Audio 6MB200 6.5 and Massive Audio CT2 tweeters
    Rear speakers: stock
    I just added 5 SoundQubed stickers, and despite having no equipment upgrades, it added 76 DB!!!
  5. #20
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    18,380
    110 Post(s)
    7897 Post(s)
    Quote Originally Posted by youdoofus View Post
    That’s just a mono bass amp. If it can’t play 20k it’s not full range.
    JBL MS-8
    Hertz HV165XL
  6. #21
    youdoofus's Avatar
    Dec 2014
    2,355
    6 Post(s)
    1040 Post(s)
    correct, and when class d amps hit the scene back in the early 2000's, they werent physically capable of playing full range
    Pioneer AVH-2300NEX
  7. #22
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    18,380
    110 Post(s)
    7897 Post(s)
    Sorry I misunderstood. Yeah they couldn’t switch high enough.
    JBL MS-8
    Hertz HV165XL
  8. #23
    2xarchonxx's Avatar
    Jun 2018
    Louisville ky
    11 Post(s)
    I'm not having any luck finding anything locally or on classifieds. You guys think that one you linked earlier would be fine?
    https://www.amazon.com/dp/B01KKHT3KU...U&linkCode=asn
    That guy
  9. #24
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    18,380
    110 Post(s)
    7897 Post(s)
    That guy
    That would be fine. Just don’t overdrive it. It will cook them kickers.
    JBL MS-8
    Hertz HV165XL
  10. #25
    n2audio's Avatar
    n2audio is offline OPTIDRIVEN
    Dec 2001
    Lawrence, KS
    5,027
    1 Post(s)
    267 Post(s)
    40w on 100w speakers -- amp wins? That'd be hard to do even if you were trying.
  11. #26
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    18,380
    110 Post(s)
    7897 Post(s)
    Quote Originally Posted by n2audio View Post
    Wouldn’t be hard at all. How do you think people blow speakers with boss amps?
    JBL MS-8
    Hertz HV165XL
  12. #27
    n2audio's Avatar
    Dec 2001
    Lawrence, KS
    5,027
    1 Post(s)
    267 Post(s)
    A 40w pio can't generate 100w fully clipped. If the guy prefers music over distortion so extreme music is unrecognizable -- everything will be fine.
    A 100w speaker should be able to dissipate 100w of power (any kind of power) indefinitely. I guess you don't have much respect Kicker.
    I suppose MAYBE running w/o HPF and trying to get bass out of them could contribute to mechanical failure -- even then, gain adjustment would have to be off the chart. Besides that, nothing to worry about IMO.
    Have speakers as low quality as their amps.
  13. #28
    Jcsaudio's Avatar
    Jcsaudio is offline Senior VIP Member
    Sep 2017
    Worcester, MA
    394
    3 Post(s)
    177 Post(s)
    This is a better amplifier for the money. https://www.amazon.com/dp/B01LSEQ8NY/ref=dp_cerb_2
    Don’t forget the wiring kit. https://www.amazon.com/KnuKonceptz-K...+amplifier+kit
    2014 Sienna 2-way active SQ system. SB Acoustics SB29RDCN Tweeters. Focal PS165V mid woofers. Pioneer D9500F 75 watts RMS x 4. Pioneer BHS 5800 HU. AudioControl EQX. 10” Alpine SWS sub in custom ported box tuned to 35 hz on JBL GTX 500.
    2014 F-150 XL WT 2-way active budget SQ system. Tang Band 25-302SH 1" tweeters. Dayton Audio ND140-4 mid woofers. Pioneer D8604. JBL Club 5501. JL Audio Twk 88 DSP & FIX 86. Sundown SD3 10” sub ported/ 33Hz 1 cube.
    2014 CX5 3-way active SQ system. Pioneer 1330 NIX HU. Dayton AMT tweeters. Celestion AN2775 2-3/4 midrange. NVX XSP65 mid woofers. Pioneer PRS D4200F 75 WPC x 4. Infinity K1000. JL Audio Twk 88 DSP. Sundown SA 12” 2 cube/33Hz.
+ Reply to Thread
  1. Static noise from speakers and front speakers popping/clipping after the amp install?
    By Falloutkid90 in forum Wiring, Electrical and Installation Help
    Last Post: 03-23-2013, 06:49 PM
  2. How to wire Infinity Kappa speakers to an amp and also include factory dash speakers
    By Mimic in forum Wiring, Electrical and Installation Help
    Last Post: 01-10-2012, 11:26 PM
