+ Reply to Thread
Results 1 to 6 of 6
Reload Thread: lowest voltage an amp should see
    youdoofus's Avatar
    youdoofus is offline Well, hello Mr.Fancypants
    Dec 2014
    the void of space called the midwest
    2,040
    5 Post(s)
    902 Post(s)
    i know that this will vary across amp brands and build houses, but what is the danger area one should be looking out for before damage to an amp occurs? From what i understand, some of the korean and really the brazilian amps really dont like less than 12.4, but i see 11.6 on my voltage meter at stop lights every so often, and i immediately either turn it down, or pop into neutral and rev to about 1000 or 1100 to bring the voltage back up, not the best solution i know. But until i get an AGM and 0 gauge, itll have to do.
    From what i hear, some of the older american amps couldnt really care less if you give them 8 volts, 5.635 volts (im kidding, of course) but theyll take low voltages without as much of a concern as these newer amps. Just curious if there is a modicum of truth to this theory.
    Ever since i got a volt meter in my car, ive obviously been able to OCD out on the raw numbers more, and yes ive calibrated it several time to make sure its at least pretty darn close to what the amps are actually seeing
    2002 Honda Accord sedan V6 (automatic slushbox)
    2 Rockford p3 12s (dual 2 ohm)
    Pioneer AVH-2300NEX
    2 PPI PC275's running 1 sub each atm, waiting to put the SQ 2200.1 back in and add the PhoenixGold Elite.4 once my electrical is up to snuff
    Stock front and rears (theyre actually squirrels listening to headphones that ive trained to sing what theyre hearing)
    I just added 5 SoundQubed stickers, and despite having no equipment upgrades, it added 76 DB!!!
    giltyler's Avatar
    giltyler is offline Senior VIP Member
    Jul 2013
    DFW METROPLEX
    307
    1 Post(s)
    90 Post(s)
    Re: lowest voltage an amp should see
    Old Zed stuff was supposed to be ok 11-15 volt range but that type of build usually dose not have big dynamic headroom.
    1987 THUNDER ON WHEELS NATIONAL CHAMPION 0-100 Watt class
    Avatar Tony Mannino "The Godfather" M&M Electronics with me at Finals
    Reference amedeuce papermaker shizzon
    Mayhem's Avatar
    Mayhem is offline Tiddies
    Feb 2017
    Gainesville, VA
    744
    10 Post(s)
    389 Post(s)
    Heat is the killer my friend
    Team Fi 12
    CT 4000.1
    CT 125.4
    CT 60.4
    Crescendo PWX Mids / STS Tweets
    80PRS
    CES 270 Alt
    D3400 and 2 Kinetik HC2400s
    Maxwell supercap banks x2
    Urwifeinthepassenger
    youdoofus's Avatar
    Dec 2014
    2,040
    5 Post(s)
    902 Post(s)
    Quote Originally Posted by giltyler View Post
    i think you could probably run old zed stuff at 3 volts and it would just shrug it off LoL
    Quote Originally Posted by Mayhem View Post
    for sure, heat is cancer for all electronics. But the voltage question is still there.
    Pioneer AVH-2300NEX
    Hertz Mafia's Avatar
    Hertz Mafia is online now FEATHER RUFFLER
    Jul 2016
    Michigan
    2,113
    43 Post(s)
    1364 Post(s)
    Most amps shut off around 10v... I don’t play lower then 12v
    Dec 2006
    New orleans LA
    32
    13,692
    70 Post(s)
    2 Thread(s)
    5721 Post(s)
    12.5 and below is hairy but if it's music and the voltage jumps up fairly quick most good amps will tolerate 11.5. Just remember current is 25 to 30% higher..
+ Reply to Thread
