+ Reply to Thread
Page 4 of 4 FirstFirst 1 2 3 4
Results 46 to 56 of 56
Reload Thread: Looking for amp recommendations
  1. #46
    ikpthegame's Avatar
    ikpthegame is offline Member
    Jan 2008
    MN
    102
    12 Post(s)
    Re: Looking for amp recommendations
    Ok question on the Wolfram amp, I'll be running it at 1ohm, how hot does it get? I might only be able to install it under my seat and the seat will be resting on top of it. Do you think it would do ok?
  2. #47
    BOOMINGRANDPA's Avatar
    BOOMINGRANDPA is offline AKA MR. 2OHM
    Jan 2017
    NC
    5,304
    18
    27 Post(s)
    2112 Post(s)
    Quote Originally Posted by ikpthegame View Post
    that ain't gonna be great for any amp., need to see if u can add a fan or 2 under there..
    KENWOOD X301 HU, PRECISION POWER Phantom 1000, FU 750 12, custom 2.11 cf ad ported tuned @ 36hz 30.375 port area, soundqubed 6.5" coax, hp xover (hu), AGM starting batt... FU 750 destroying my spoiler https://www.youtube.com/watch?v=joeeCIZJpUs pioneer 3003 videos https://www.youtube.com/watch?v=rTcgVGvuFX8 https://www.youtube.com/watch?v=WI4yGDqN27g
    2 ohms rule
  3. #48
    bigblank69's Avatar
    bigblank69 is offline CarAudio.com Elite
    Oct 2006
    Huntley, IL
    953
    27 Post(s)
    473 Post(s)
    It will do fine if you don’t beat the thing to death for hours on end... my Orion’s are underseat mounted
    Head Unit: Pioneer Avic-5201NEX
    Amplifiers: Orion XTR1000.4, Orion XTR2500.1Dz
    Front Speakers: Infinity Perfect 600 Components
    Rear Speakers: Image Dynamics ID6.5
    Subwoofers: 2 JL Audio 12TW3-D4
  4. #49
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    13,488
    39 Post(s)
    5689 Post(s)
    Quote Originally Posted by bigblank69 View Post
    Same here...as long as air gets around it, your fine. And don't cover it with anything.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
  5. #50
    shredder2's Avatar
    shredder2 is offline CarAudio.com Elite
    Nov 2017
    az
    911
    13 Post(s)
    337 Post(s)
    Foxbox on 1500 watts?.. id go sealed first. I'm not sure where you'll be tuned once the displacements in the Foxbox are accounted for and the last underseat Foxbox I saw had pitiful port area... certainly not enough for a 1500 watt amp
    I could be wrong but IMO sealed would be preferable to that Foxknocks (at 45hz).
  6. #51
    Beentown's Avatar
    Beentown is offline Member
    Mar 2016
    Central, OH
    142
    60 Post(s)
    Quote Originally Posted by shredder2 View Post
    I disagree. I run two in my work trucks. They perform excellent. One has 1200 watts to it (NVX 1200.1) and the other has 500 watts to it. Both are excellent.
    Worst part is the port points towards the cab vent. Bzzzzzz.....
    Sent from my SM-G950U using Tapatalk
  7. #52
    Beentown's Avatar
    Mar 2016
    Central, OH
    142
    60 Post(s)
    Also, the Foxbox is 1.55cuft per sub. Tuned at 35hz.
  8. #53
    shredder2's Avatar
    Nov 2017
    az
    911
    13 Post(s)
    337 Post(s)
    Quote Originally Posted by Beentown View Post
    is it 1.55ft3 net ad?.. I suppose I could be wrong but the volumes and tunings given are before displacement unless I'm mistaken
  9. #54
    Beentown's Avatar
    Mar 2016
    Central, OH
    142
    60 Post(s)
    Before displacement. The problem he will run into is finding subs that fit. SA's fit but anything with a large magnet or designed deep will not fit.
    But that is always the case for underseat applications. Especially those using the storage compartments as the main area to get air volume.
    The only downside I have for mine are the loss of the cup holder area. Not that I need the holders but that it looks...weird without the cutouts matching.
  10. #55
    shredder2's Avatar
    Nov 2017
    az
    911
    13 Post(s)
    337 Post(s)
    Could you link the box you've got thats 1.55ft3 per?.. Im curious if you'd measure the port area and length for me... I'd like to check tuning ad if It's not too much trouble, what sub are you using btw?
  11. #56
    Beentown's Avatar
    Mar 2016
    Central, OH
    142
    60 Post(s)
    Yeah, not measuring ports as I would have to remove the subs to do so.
    One has JBL gt-10's on 500 watts. It is the original box for 10's which was 1.15 cu ft (I believe, it's been a while) per sub.
    The other has SA-12's now. It has had others.
    The 12 and 10 box is the same now, just use adapters for tens. Haven't used the new version.
+ Reply to Thread
  1. Looking for a recommendation for a sub and amp
    By fenderbendr in forum Subwoofers
    Last Post: 06-05-2017, 10:15 PM
