+ Reply to Thread
Results 1 to 15 of 15
Reload Thread: Quantum Amplifier Impedance Mix
    titanbangle's Avatar
    titanbangle is offline Junior Member
    Nov 2017
    mx
    3 Post(s)
    Icon32 Quantum Amplifier Impedance Mix
    Good day Friends of Caraudio, today I am upset because I have a question with the audio of my car, I have a QE2400.4 Quantum Amplifier, it is a 4-channel amplifier, I am currently using it with 2 speakers 6x9 pioneer 230W max @ 4 Ω and I was thinking about acquiring a pair of Pionner subwoofers ts-w260d4 of 350 W RMS and double coil and 4 Ω, but when reading the characteristics of the Ampli I am a doubt, the information is the following:
    4 x 125 Watts @ 4 Ohm Stereo
    4 x 250 Watts @ 2 Ohm Stereo
    2 x 750 Watts @ 4 Ohm Bridged
    my question is, can I leave the speakers working as usual until 4 Ω at 125W on two channels and on the other two add the subwoofer at 2 Ω and work with the 4 at the same time? Is it possible to work like this? What do you recommend me to do?
    Thanks in advance.
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    13,487
    39 Post(s)
    5689 Post(s)
    Re: Quantum Amplifier Impedance Mix
    You might be better off getting a mono amp to power those subs with and just use that 4 ch amp to power your speakers with.
    Btw, those Quantum amps are a joke for ratings.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
    los33's Avatar
    los33 is offline Car Audio G
    Apr 2014
    Houston, TX
    3,474
    29 Post(s)
    2211 Post(s)
    Quote Originally Posted by titanbangle View Post
    Thanks in advance.
    To use the bridge for your subs you need to run 4 ohm.
    2 ohm will kill your amp.
    DB Drive junk lmao.. its just a db drive amp with cheaper internals.
    Sent from my Moto G (4) using Tapatalk
    n2audio's Avatar
    n2audio is offline OPTIDRIVEN
    Dec 2001
    Lawrence, KS
    5,013
    1 Post(s)
    264 Post(s)
    Yes, you can. having different impedances on different channels of a multi-channel amp is never a problem as long as none of them are below their specified minimum.
    But don't get caught up with power ratings on an amp like that.
    Judging by the 40A of fuse protection it is drastically over-rated. Figure on 100x4 at 2 ohms. Probably ~75x4 at 4 ohms.
    So if you have a pair of 4 ohm speakers on 2 channels and a pair of dvc 4's on the other two you'd be looking at about 75w per speaker and about 100 per sub.
    Don't run the subs at 2 ohms per channel. Wire them for 4 and bridge those two channels.
    https://www.the12volt.com/12voltimag...m_dvc_4ohm.gif
    BOOMINGRANDPA's Avatar
    BOOMINGRANDPA is offline AKA MR. 2OHM
    Jan 2017
    NC
    5,304
    18
    27 Post(s)
    2110 Post(s)
    yes 2 ohm stereo will work but u can also run 2-4 speakers off 2 channels and bridge other 2 channels to 1 sub ported., more power to 1 sub in louder box.. i suggest u get a mono amp (let us help u pick one) and u can get 1 pioneer 3003 pro much better sub ($75 ebay) or sound qubed hds $85 on sale now and run maybe 500 rms to it from the mono amp at 2 or 1 ohm depending on sub u get..
    KENWOOD X301 HU, PRECISION POWER Phantom 1000, FU 750 12, custom 2.11 cf ad ported tuned @ 36hz 30.375 port area, soundqubed 6.5" coax, hp xover (hu), AGM starting batt... FU 750 destroying my spoiler https://www.youtube.com/watch?v=joeeCIZJpUs pioneer 3003 videos https://www.youtube.com/watch?v=rTcgVGvuFX8 https://www.youtube.com/watch?v=WI4yGDqN27g
    2 ohms rule
    Jul 2005
    WA
    13,487
    39 Post(s)
    5689 Post(s)
    Quote Originally Posted by BOOMINGRANDPA View Post
    Why are you suggesting subs when he has some already??
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
  7. Likes hispls liked this post
  8. #7
    Jan 2017
    NC
    5,304
    18
    27 Post(s)
    2110 Post(s)
    he said i'm thinking about getting these..... not that he has them.. why don't u worry about reading op post instead of mine?
    2 ohms rule
  9. #8
    Nov 2017
    mx
    3 Post(s)
    Icon12 Re: Quantum Amplifier Impedance Mix
    Thanks for your answers, at the moment I can not add another amplifier, so it would be more advisable to leave the speakers and add only a subwoofer in bridge mode? what dou you recommend?
  10. #9
    Jul 2005
    WA
    13,487
    39 Post(s)
    5689 Post(s)
    Post#4 is the perfect answer for ya.
    I would get a single DVC then use the channels 3& 4 from amp to power it.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
  11. #10
    Nov 2017
    mx
    3 Post(s)
    Icon7 Re: Quantum Amplifier Impedance Mix
    I do not understand the diagram very well, but I will review it and put it to the test, thanks for your help.
  12. #11
    Jul 2005
    WA
    13,487
    39 Post(s)
    5689 Post(s)
    It's very easy...I can break it down for ya. Say You have a DVC sub. You wanna wire it to achieve a certain ohm load. Simply take a piece of speaker wire and connect it to the - of one terminal and either - or + to the other. Same with the other coil terminal. Then take speaker wire and wire it to the sub, doesn't matter which side, then to amp.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
  13. #12
    Nov 2017
    mx
    3 Post(s)
    Sorry friend, is that my English is not very good, I understand then that if you can do what I need? Making the connection as you just explained it would be working at 2 ohms? Could I connect both subwoofers and keep my other two speakers?
  14. #13
    Jul 2005
    WA
    13,487
    39 Post(s)
    5689 Post(s)
    If those subs don't exceed the amps' ohm ratings.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
  15. #14
    n2audio's Avatar
    Dec 2001
    Lawrence, KS
    5,013
    1 Post(s)
    264 Post(s)
    I agree with the suggestion of going with a single sub instead of a pair.
    You have ~200w rms available which is a good amount of power for a lot of low/mid level subs. And the extra work/cost/space requirement to get a pair of subs up and running wouldn't be worth it.
    Since bridging two channels needs a 4 ohm load to work best you want a sub with either a single 4 ohm voice coil or dual 2 ohm voice coil.
    https://www.sonicelectronix.com/item...Impedance.html
    https://www.sonicelectronix.com/item...DB1242SVC.html
    https://www.sonicelectronix.com/item...h-P2D2-12.html
    https://www.sonicelectronix.com/item...-12-m4-D2.html
    many other options.
  16. #15
    Nov 2017
    mx
    3 Post(s)
    I will go better with the option of a single subwoofer, thanks for your help.
+ Reply to Thread
  1. Help with amplifier impedance
    By jasondupree1980 in forum Amplifiers
    Last Post: 10-28-2013, 12:12 PM
  2. Amplifier impedance question
    By Patthehat033 in forum Wiring, Electrical and Installation Help
    Last Post: 01-27-2012, 12:30 AM
  3. Quantum Audio amplifiers
    By mustangowner in forum Amplifiers
    Last Post: 01-13-2009, 01:58 PM
Tags for this Thread
