+ Reply to Thread
Page 4 of 4 FirstFirst 1 2 3 4
Results 46 to 49 of 49
Reload Thread: Amplifier recommendation
  1. #46
    BOOMINGRANDPA's Avatar
    BOOMINGRANDPA is offline YEAH I'M A CHEAP BAST*RD BOOMINGRANDPA is a Supporting Member of the forum!
    Jan 2017
    NC
    2,545
    15 Post(s)
    1008 Post(s)
    Re: Amplifier recommendation
    Quote Originally Posted by mattman2040 View Post
    Any agm battery brand reccomendations?
    Sent from my SM-G935P using Tapatalk
    dude i got mine on advance website 30% off 1 day they had a sale but they always got 20% off go to the site load batterys for your car see if discount don't pop up.. some other are better but advance will install it and easy to get replaced if a problem in 2 yrs..
    KENWOOD X301 HU , PIONEER CHAMP PRO 3003d4 12, 1.65 CF SLOT PORTED TUNED TO 35 HZ, PRECISION POWER P1000, SOUNDQUBED 6.5" coax, xover (hu) AGM starting batt. https://www.youtube.com/watch?v=rTcgVGvuFX8 https://www.youtube.com/watch?v=WI4yGDqN27g
  2. #47
    youdoofus's Avatar
    youdoofus is offline Well, hello Mr.Fancypants
    Dec 2014
    the void of space called the midwest
    1,300
    5 Post(s)
    556 Post(s)
    xs power https://www.sonicelectronix.com/cat_...wer-cells.html
    kinetic https://www.techbatterysolutions.com...erm=HC1800-BLU
    northstar Northstar AGM31 Car Audio Battery Group 31
    was it jeff who had some agm batteries for sale in another thread too?
    edit: nvm, that was just a link he shared to some lithiums
    2002 Honda Accord sedan V6 (automatic slushbox)
    2 Rockford p3 12s (dual 2 ohm)
    Pioneer AVH-X4500bt
    SQ 2200.1
    Stock front and rears (theyre actually squirrels listening to headphones that ive trained to sing what theyre hearing)
    I just added 5 SoundQubed stickers, and despite having no equipment upgrades, it added 76 DB!!!
  3. #48
    mattman2040's Avatar
    mattman2040 is offline Junior Member
    Aug 2017
    US
    27
    12 Post(s)
    Ok guys so i purchae tge sq2200.2 very excited to set the system up. Given that my amp is going to be much more powerful than my speakerd i want to make sure i tune the amp correctly. What would be the best way to test the wattage output so i dont blow my speakers.
    Ive been reading all these different ways like using a dummy load.
    Cant you just amp probe the output wires going to the speakers and do the calculations to get the wattage. Why so much complexity
  4. #49
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    13,636
    156 Post(s)
    6350 Post(s)
    better method, turn it up until you hear a change in bass tone or if it stops getting louder, then back off a few clicks, then do 5 mintue to 15 minute tests and check the heat of the sub and amplifier. Heat is what kills your equipment. A voltmeter can also help, when you drop voltages really quick thats a good sign of clipping as well. After 10-30 minute sessions If the equipment is hot, back it off. If the equipment is slightly warmer than room temp, you are good. If the equipment is ice cold, you got some more left in the tank. Always monitor heat along with a keen nose and you'll never blow anything.
    Those watt calculations are useless because it'll be a different load when real music is played. Best you'll get is a ballpark but its a waste of time compared to the method i described.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
+ Reply to Thread
  1. 5 or 6 channel amplifier recommendations?
    By Hercules in forum Amplifiers
    Last Post: 05-31-2006, 11:24 PM
  2. Replies: 9
    Last Post: 08-05-2005, 03:16 AM
  3. Amplifier Recommendation
    By GReddyBooSTer in forum Amplifiers
    Last Post: 07-25-2005, 10:25 PM
  4. Amplifier Recommendation
    Last Post: 03-28-2005, 05:41 PM
  5. Need Amplifier Recommendation
    By jinetix in forum Amplifiers
    Last Post: 07-21-2004, 10:18 AM
