+ Reply to Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 33
Reload Thread: Gain matching taramps hd15k's
    Spldecendant's Avatar
    Spldecendant is offline CarAudio.com Elite
    Mar 2012
    Ny
    516
    163 Post(s)
    I have 2 taramps hd15k's what the best way to go about gain matching
    staan's Avatar
    staan is online now Senior VIP Member
    May 2016
    new orleans, la
    463
    306 Post(s)
    Re: Gain matching taramps hd15k's
    play a sine wave, throw a voltmeter on it and match numbers
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    15,316
    220 Post(s)
    7367 Post(s)
    wing it.
    I got worse results from several multi-meters than winging it. The multi meters didnt read proper AC voltage. tried out several, just didnt read anything proper.
    as for winging it, have them at the same position on the gain knob, then make fine adjustments after testing aka seeing which subs move more, which sub coils get warmer when you really really push it then lower/raise accordingly. Multi meter gain matching made me lose a **** ton of output and had one sub hotter than the other.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
    Papermaker85's Avatar
    Papermaker85 is online now Better built than bought!
    Dec 2006
    New orleans LA
    32
    12,494
    68 Post(s)
    2 Thread(s)
    5100 Post(s)
    Quote Originally Posted by Jeffdachef View Post
    wing it.
    ****** meter or wrong frequency.
    Insidious Audio
    But you at 2ohm it's all good!
    yeah i told wife guy on here pm'ed me wanting to buy my amp she said tell him it not fs (cause she knows i'll spend more $ on new one) and told her i wanted d2 sub for bday next week she said tell ya'll i'm to old to go down to 1ohm lol..
    Jeffdachef's Avatar
    Feb 2013
    15,316
    220 Post(s)
    7367 Post(s)
    Quote Originally Posted by LosissaTool View Post
    it was a fluke multi-meter along with 3 other multi-meters, same sh*t. 40 or 50hz doesnt do ****. The amp doesnt like multi-meters. Even with the gain maxed the ac volts didnt change much at all. literally just throw that multi-meter idea out the window and you'll do much better. with these hd 15ks. Its not my first rodeo gain matching two amps bud. it works with other amps just not the hd15ks
    Jeffdachef's Avatar
    Feb 2013
    15,316
    220 Post(s)
    7367 Post(s)
    but quite literally my amp gains are identical to each other on the position. Both at 5% mark and they are loading evenly, subs are same temperatures, system is healthy, stuff gets loud, sounds good. With the multi-meter it had one at 4% and the other at 7% which is completely off sounded out of phase, improper loading, output su cks, uneven coil temps after a harsh session. its not as drastic as i make it but i do hear differences when things sound off.
    Dec 2006
    New orleans LA
    32
    12,494
    68 Post(s)
    2 Thread(s)
    5100 Post(s)
    Because ive said this and got laughted at. Its a pwm signal. You used the auto setting or the AC setting?
    You need a reactive load and you are much better off using a clamp meter and volt meter.
    Insidious Audio
    Jeffdachef's Avatar
    Feb 2013
    15,316
    220 Post(s)
    7367 Post(s)
    every setting in the book I took a massive amount of time trying to tune it with all "proper" gain setting techniques. subs hooked up, subs unhooked doesnt matter.
    Like i said you are waaay better off winging it. Also using the clip indicator on the amp works great as well whenever i have the electrical to go up to 30% gain at +0 sub level which is when it starts flashing. Right now, still at 5% gain and -7 sub level atm and at -6 sub level, i drop to 10.3 volts lmaoo that lack of electrical is holding back soo much potential.
  9. #9
    Dec 2006
    New orleans LA
    32
    12,494
    68 Post(s)
    2 Thread(s)
    5100 Post(s)
    Thats not to say the voltmeter wasnt more accurate. Two drivers might have been loaded slightly more so putting a tad less power on the other two could have helped..
    Insidious Audio
  10. #10
    Dec 2006
    New orleans LA
    32
    12,494
    68 Post(s)
    2 Thread(s)
    5100 Post(s)
    every setting in the book.
    I want to see said amp.
    Full bridge. Meter works on averaging.
    You need to use a peak reading not mean..
    If that dont work the i want to know wtf kind of electricity that thing puts out.
    Insidious Audio
  11. #11
    Jeffdachef's Avatar
    Feb 2013
    15,316
    220 Post(s)
    7367 Post(s)
    either its a lot of interference or some wierd stuff is going on. Other amps read the multi-meter fine. this just flat out reads wierd numbers. The ampere tfe read 91 volts while the taramps read 60 volts at 3% gain and 69 volts at max gain. However in a listening test the taramps was waay louder even at 5% gain on the old setup.
  12. #12
    Dec 2006
    New orleans LA
    32
    12,494
    68 Post(s)
    2 Thread(s)
    5100 Post(s)
    I realy think its the operation of the outputs and the meter trying to use an average. Ill bet its only reading one set of pulses at one given polarity. If you double the number is it more accurate?
    Id use a clamp meter. Measure impedance and use the clamp if that is the case..
    Insidious Audio
  13. #13
    Jeffdachef's Avatar
    Feb 2013
    15,316
    220 Post(s)
    7367 Post(s)
    its good where its at atm. No access to a proper clamp at this time.
  14. #14
    Dec 2006
    New orleans LA
    32
    12,494
    68 Post(s)
    2 Thread(s)
    5100 Post(s)
    Amperage^2×impedance=power.
    I do this to test motors as well.
    Insidious Audio
  15. #15
    Dec 2006
    New orleans LA
    32
    12,494
    68 Post(s)
    2 Thread(s)
    5100 Post(s)
    Not you money. Lol you breaking windshelds you good. Not to mention if you wheren't close you would know it
    Insidious Audio
+ Reply to Thread
  1. Gain matching required for strapped SAZ-1500D's?
    By timma100 in forum Amplifiers
    Last Post: 12-31-2011, 04:04 PM
  2. Replies: 5
    Last Post: 06-13-2011, 11:47 AM
  3. How to Gain match Strapped amps with meter?
    By Bass911 in forum Amplifiers
    Last Post: 04-24-2008, 11:32 PM
  4. Amp Gain Matched To Head Unit Voltage
    By Obscure in forum Amplifiers
    Last Post: 11-12-2005, 07:43 PM
  5. Gain Matching Amps
    By havoc06 in forum Amplifiers
    Last Post: 07-23-2003, 09:31 AM
