+ Reply to Thread
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 33
Reload Thread: Gain matching taramps hd15k's
  1. #16
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    14,486
    193 Post(s)
    6870 Post(s)
    Re: Gain matching taramps hd15k's
    Quote Originally Posted by LosissaTool View Post
    Amperage^2×impedance=power.
    I do this to test motors as well.
    doesnt explain why at 3% gain to max gain there was only a 9 volt difference. However when you have subs hooked up, THERES a major AUDIBLE difference as you go up. Definitely not 9 volts
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
  2. #17
    Papermaker85's Avatar
    Papermaker85 is offline Better built than bought!
    Dec 2006
    New orleans LA
    32
    11,499
    58 Post(s)
    2 Thread(s)
    4722 Post(s)
    Quote Originally Posted by Jeffdachef View Post
    Its probably not the actual outputs being limited. The input section might be to blame..
    30^2 is 900
    39^2 1520
    Plus its averaging so 60 and 78
    3600
    6084 respectively
    Honestly its a guess. Id really have to get my hands on it.
    Insidious Audio
  3. #18
    Jeffdachef's Avatar
    Feb 2013
    14,486
    193 Post(s)
    6870 Post(s)
    30^2 is 900
    39^2 1520
    3600
    6084 respectively
    3600 watts only and its way louder than 8281 watts on the ampere? Yeah dude its wierd as fk.
  4. #19
    Dec 2006
    New orleans LA
    32
    11,499
    58 Post(s)
    2 Thread(s)
    4722 Post(s)
    Double the voltage. Then square it multiply by id probably use .8 since its low frequency
    Insidious Audio
  5. #20
    Dec 2006
    New orleans LA
    32
    11,499
    58 Post(s)
    2 Thread(s)
    4722 Post(s)
    Insidious Audio
  6. #21
    Dec 2006
    New orleans LA
    32
    11,499
    58 Post(s)
    2 Thread(s)
    4722 Post(s)
    Insidious Audio
  7. #22
    Dec 2006
    New orleans LA
    32
    11,499
    58 Post(s)
    2 Thread(s)
    4722 Post(s)
    You welcome. Problem solved.
    But in short you need to know duty cycle and the peak voltage of the dc pulse. Its easier and more accurate because you have much more time when the voltage peaks its drastically reduces the sampling rate..square wave has a much longer peak voltage to sample from..
    Insidious Audio
  8. #23
    gotgixers's Avatar
    gotgixers is offline CarAudio.com Elite
    Jan 2015
    Athens, TN
    50
    1,165
    12 Post(s)
    396 Post(s)
    This is the DMM I use .....
    Refs;Bought from: Boomsday, special_k_1999, BAD_MAYEM, C1500Martin, roko, Michaellane
    Sold to: sam_b03, Nate121, Smaxor5, Boomsday, unrealii, paulluap,technobass,gmc123
    TN State Champion MECA M4 - 2017, 2nd place World Finals - 2017
    #Boominburban
    Four JS Ult 300 amp alts
    One 75ah agm under hood - Four 126ah agm's out back - 8 runs of 2/0 royal excelene
    80 prs HU - PPI DSP -88R DSP - PPI E.7 EQ for fine tuning
    Four PPI p600.2 on front stage
    4 CDT HD-M6's / 2 DS18 6.5 neopros / 2 DS18 tw210 tweeters
    Two Taramps HD 15000's on 6 FU Audio 1250-15's
  9. #24
    Dec 2006
    New orleans LA
    32
    11,499
    58 Post(s)
    2 Thread(s)
    4722 Post(s)
    Quote Originally Posted by gotgixers View Post
    The brizillians use pwm outputs while zenon uses a modified sinewave.
    I told fucktards that last year over on www.caraudio Classifieds.com
    Watch me find the thread and you can confirm i was again correct. Lol
    Insidious Audio
  10. #25
    Dec 2006
    New orleans LA
    32
    11,499
    58 Post(s)
    2 Thread(s)
    4722 Post(s)
    I can show you how with almost any dmm and its better to use tge peak function and calculate rms because of the nature of the output waveform..
    Insidious Audio
  11. #26
    gotgixers's Avatar
    Jan 2015
    Athens, TN
    50
    1,165
    12 Post(s)
    396 Post(s)
    Use a TL Magnum in split screen, with two sets of amp probes and clamps. It reads the output voltage also. You should be up around 135vac+ ...
    #Boominburban
  12. #27
    Dec 2006
    New orleans LA
    32
    11,499
    58 Post(s)
    2 Thread(s)
    4722 Post(s)
    Since the pulses are 180degrees out of phase at peak as long as you use the peakhold function you should be pretty accurate.. im gonna look at how they get a "contunious" figure after all contunious means the rise/fall of the sine wave is linear in fashion and can be calculated easly.when you account for lag/lead.
    This is more realiant on modulation and duty cycle.
    To answer your question @Jeffdachef
    The gain in voltage and duty cycle is proportional to output.
    In other words voltage has little change but the duty cycle decreases while increasing the switching speed instead of peak voltage.
    The meter won't read the negetivity charged pulse because its an inverse flow of current so they basically absorb each other.
    phase shifts as outlput increases from higher switching speed to use the mean rating and the higher sample rate. Which prbably went for 500hz to 5khz so even though you had a substantual gain in voltage the meter couldnt measure it because the switching speed was way to high.
    Escentually it was starting to cancel out in the meters eyes. Lol.
    Insidious Audio
  13. #28
    Dec 2006
    New orleans LA
    32
    11,499
    58 Post(s)
    2 Thread(s)
    4722 Post(s)
    @adulbrich
    Remember the thread over on ca? Proof i was right and i NEVER TOUCHED THE AMP I KNOW THEY OUTPUT TOPOLOGLY WITHOUT EVER TESTING ONE.
    Insidious Audio
  14. #29
    Jeffdachef's Avatar
    Feb 2013
    14,486
    193 Post(s)
    6870 Post(s)
    thats nice but i'm not gonna drop that much money just so i can "set my gains" when its already at a level i'm fine with. I'd rather put that money towards electrical where it actually matters.
  15. #30
    Dec 2006
    New orleans LA
    32
    11,499
    58 Post(s)
    2 Thread(s)
    4722 Post(s)
    Did you say you needed some compacators?
    Insidious Audio
+ Reply to Thread
  1. Gain matching required for strapped SAZ-1500D's?
    By timma100 in forum Amplifiers
    Last Post: 12-31-2011, 04:04 PM
  2. Replies: 5
    Last Post: 06-13-2011, 11:47 AM
  3. How to Gain match Strapped amps with meter?
    By Bass911 in forum Amplifiers
    Last Post: 04-24-2008, 11:32 PM
  4. Amp Gain Matched To Head Unit Voltage
    By Obscure in forum Amplifiers
    Last Post: 11-12-2005, 07:43 PM
  5. Gain Matching Amps
    By havoc06 in forum Amplifiers
    Last Post: 07-23-2003, 09:31 AM
